Question about Philips 50PFP5332D 50 in. Plasma Television
Screen down and clicking, power light on
Getting ready to open up, whats the most likely cause?
  • Philips Master
  • 1,525 Answers
Hi, capacitors, they usually swell up or a shorted diode/ transistor and may be a bad dry solder joint, good luck with the repair
regards
shaun
Posted on Apr 19, 2014
My TV screen appears for a second then turns black, then a few seconds later appears again and the turns black again. The channel sound is perfectly fine. My Cable company tried everthing and it still...
If the tv isn't fully shutting down. but just flashing on and off then it
sounds like a backlight supply fault.
All LCD screens have what can only be described as micro flouro lights inside the screen module.
it is possible that the power supply is faulty causing them to flash on and off every now and then. or the tubes themselves are damaged.
to confirm this..
Lay the tv down flat on its back and power up in a well lit room
get down close to the screen and look across it at a acute angle
now if the black screen looks like it is still displaying an image then it's definatley your backlights!
in which case it could be a simple fault in the power supply.
so if your feeling confident in yourself i can talk you through what to look for in the supply..but try this first and get back to me.
hope this helps,ben :-)
Jan 06, 2011 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
When I plug up the monitor and power it on, the gateway sign appears and then the monitor just shuts itself down again but the power light is still on what's wrong?
f7476e0.jpg597f7d2.jpgfdb9d8d.jpg1ad0e84.jpga405f1b.jpg6e6f6c3.jpg2be5895.jpgWhypaythem is correct....again. The bad capacitor is C862 on the inverter board ( power supply ). The bad capacitor is a 1000uf, 25volt.b970f86.jpg
Oct 15, 2009 | Gateway FPD2275W LCD Monitor
NEC PX-42VP4G Power supply
Check to be sure that there is no voltage on the input line. You don't indicate what input you are using. Since the set appears to work without an input connected, try looking at the input cable. Also, if the problem is internal to the set, shorting the input jack would cause the same behavior. Please update this with what you find.
Dan
May 13, 2008 | NEC PlasmaSync 42VP4D 42 in. HD-Ready...
SCreen turns red then shuts off
The 46H84 has 3 CRTs instead of a lamp. Red, Green and Blue. Your red CRT is shorting out shutting down the set.Here is how you test that theory. Remove the speaker grille, there will be an access panel behind the grille remove that and you will see the CRTs red is usually on the left. hit the power momentarally to locate which tube is red. then power down and unplug the power cord. Carefully remove the tubes Circuit board. ( you may have to carefully slice the glob of silicone applied at the factory to get the circuit board off) Once you have the circuit board off the Red CRT make sure it isnt touching anything and try powering up the set. If the set stays on and the other 2 CRTs light up. That tells you the RED crt is shorted and thats whats shutting your set down. Let me know if I can assist you further.
Mar 25, 2008 | Toshiba 46H84 46" Rear Projection...
Computer shuts down but does not turn off
Mchem, you actually have 2 separate issues going on there.
  • Open control panel > open the system control panel
  • in the system properties, click on the advanced tab
  • in the startup and recovery section, click the settings button
  • In the startup and recovery dialog box, under system failure, remove the check from the automatically restart option
  • click ok
  • click ok
  • Open control panel > open power options
  • in the power options properties, select the advanced tab,
  • in the power buttons section,
  • When I press the power button on my computer: click on the drop down menu and select the shut down option
  • click ok
Sebastien123, you only need to run the first part of this solution.
Dec 20, 2007 | EliteGroup ECS PF5 EXTREME...
Relays click. That's about it
try unhooking the wires coming off the power board you should be able to unhook every thing except the switch wire and se plug if the green lights stay on and the red don't come on then you have something loading down your power supply if it still shuts down you need a new power supply
Nov 20, 2007 | SVA-USA HD4208TIIIBU 42 in. HD-Ready...
Lexmark E238 Laser Printer
Here are the steps to reset the page count on a Lexmark E234, as described here:
  1. Power the printer on and get it to the Ready state.
  2. With the printer on and in the Ready state, open the front cover.
  3. Press and hold the Cancel button until all of the lights begin flashing up and down.
  4. Release the Cancel button and close the door. The photoconductor count should now be reset.
Hope that helps!
-MetaB
Aug 12, 2007 | Lexmark E238 Laser Printer
No power
Is there any sound coming from the speakers at all? Might be a power supply that failed or lamp/ballast issue.
Mar 05, 2007 | RCA L32W11 32 in. HD-Ready LCD Television
Philips 50PFP5332D 50 in. Plasma Television Logo
19 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
