Question about Blublocker Clothing Accessories
Lose rubber from arm pad
Sun Glasses have two prongs to hold rubber part on.
  • 28 Answers
Hi
This is a very common problem and unfortunately there are not universal pads that be easily put on for a quick fix. A cool trick I learned years ago is this..Go to your local hardware store and pick up some heat shrink tubing. Make sure the tubing is just larger than your ear piece. All you do is place the tubing over the area where the rubber is coming off and heat it up. This will secure the loose rubber to your frame.
Posted on May 08, 2014
How to split the outer cv joint to replace the rubber boot
lose the central nut of your wheel first,remove the brake caliber loose two bolts holding your suspension arm in one peace and the lower arm bolt and loose the steering arm ball joint pull the hub up and the shaft out is one peace ,loose rubber boot clean housing and look in side you have sir clip with two holes one on etch site remove it with sir clip players grease the joint fit the new boot good luck.
Sep 09, 2012 | 2004 Kia Sedona
Top rack not cleaning dishes. model # FDB1050RES2
Hello, check the sprayer arm on the top of the dishwasher inside and to see if it spins. Don't block this spray arm with glasses or dishes that could block the operation of this sprayer cleaning arm.
Now, if it not spinning, check out the fitting arount hing bolt. If this wore out then you will have water pressure lose. Replace if need be. Also, check the feeder water spout that runs the upper spray army, it could be pluged. GB...stewbsion
Aug 31, 2011 | Maytag Dishwasher
How to start it up
Hold down the middle button on the left arm until the green light on the inside right arm comes on...to pair the glasses to a device,hold down the middle button on the left arm until a solid red light comes on the right arm on inside of the arm if your device asks for a code its 0000 that's all zeros
Jul 05, 2011 | Oakley O Rokr Pro Sunglasses
Hello, I have Just Cavalli JC225 glasses. They were too tight and the arms were widened, to stop the glasses being pushed forward. Now they rest too heavily on my nose, causing red marks and...
There are a couple of things that can be done to fix this problem. One of the easiest solutions is to have the nose pads replaced with larger and/or softer nose pads. Alternatively, a saddle shaped nose pad can be helpful in distributing the weight across your nose. Most local optometrists should have nose pads available that they can change out for you.
Furthermore, if the nose pads are set at a bad angle they can dig into your nose also. Adding some curl to the end of the arms can bring the glasses closer to the face if they are sitting too low. If you are careful you can attempt some of these adjustments yourself.
Feb 25, 2011 | Roberto Cavalli Just Cavalli JC225 097...
A pin that holds the side folding arm on is broken. how do you fix it?
hi
since the pin is broken only the authorized dealer who deals with your brand can get it fixed if your sun glasses is under warranty period then you can get it done for free . if not you need to approach other dealers to get the work done .i shall give you site address try checking it out
http://www.sunglassreplacementlenses.com/
If you are happy with my answer please vote four thumbs up. Thank you
Dec 16, 2010 | Oakley Oil Rig Sunglasses
Both lenses have developed straight horizontal lines in the bottom half of the lenses. They have just appeared and have not been scratched. The glasses were purchased about 2.5 years ago.
hi
i think these problem usally occour when the glasses get old and the lenses of sun glasses get reached with the sun rays which is one of the cause for it .so i request you to replace it
If you are satisfied with my answer please vote three thumbs up.Thank you
Nov 17, 2010 | Electric Eyeware Hoy Sunglasses
Why is it important to purchase special sunglasses for ski?
Whether the sun is out or not, a good pair of glasses is crucial. They will help protect your eyes from UV rays and the glare of the sun on the snow - which can cause snow blindness. Think about protecting the whole of your eye from potentially harmful rays - choose 'wrap-arounds' or glasses with protective side-panels.
You should check that the glasses are well suited to the contours of your face - there is nothing worse than the feeling of the frames gradually sliding down your nose as you are cruising/racing along. If you are a champion bumps skier, jump specialist or just extremely accident prone then it may be an idea in invest in a pair of glasses that attach themselves securely to your head - either by wrapping around your ears or with a band around the back of your head. You should never skimp on glasses - you only have one pair of eyes.
Nov 07, 2010 | Clothing Accessories
My right trigger button dosent work
This is common with this unit. there's a rubber contact pad that can lose its structure during long term usage.when you press this button it contacts the rubber pad and the rubber pad makes contact with the circuit board creating action or movement on the screen. this pad can breakdown and lose its integrity.
Feb 14, 2009 | Nintendo DS Console
When i turn the front wheels left or right i hear a loud sqeaking
you need to get grease into pittman arm there is no grease fitting so get a needle fitting for your grease gun and poke thru the rubber ive done twice on 97 f150s and fixed the problem
Dec 02, 2008 | 1997 Ford F150 Regular Cab
Clothing Accessories Logo
93 people viewed this question
Top Blublocker Clothing Accessories Experts
Da Doc
ray gallant
Are you a Blublocker Clothing Accessory Expert? Answer questions, earn points and help others
