Question about Flight Dental A10E Patient Chair
Chair is stuck in a raised position
All other functions work on the chair. The chair will not fully return to the floor position.
  • danny tan
    danny tan Apr 04, 2017
    check the limit switches , see if can trigger or not.
    Sergeant:
  • 181 Answers
Hello. The chairs lift needs to be cleaned from the inside and the hydralic fluid changed.
Posted on Apr 18, 2014
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 575 Answers
Cleaned from the inside
Posted on Apr 10, 2017
I just purchased a new hand control for my lazyboy sit to stand recliner - it works for heat, vibration but will not raise or lower chair.
The control may be the wrong model for your chair or possibly not connected firmly underneath.
Jan 13, 2018 | Furniture
The chair will not hold it height after raising. Is there an adjustment that can be made to hold the desired height
Gas lift chairs are made to automatically lock in the position they have been raised to, sounds like your chair is faulty.
Jan 29, 2016 | Timberland Chippewa Mens 8 Inch Tan Rodeo...
Nikon coolpix camera 9500 - pop-up flash not fully raised
hi,
the popup mechanism has a motors and gears switches etc in, this must be in a synchronous position if this mechanism is misplaced, it should re set in proper way, open the cam fix it.
Sep 30, 2015 | Nikon COOLPIX Cameras
Why does it make a crunching noise?
Your chair is NEW! So, return your chair to the store where you bought it and complain!
Aug 01, 2015 | Furniture
What can be doene with our executive office chair as it will not remain in the raised position. After raising it, then sitting, the chair slowly sinks down? What is the problem or what can be done.
The hydraulic gas lift is broken. If you want to fix it, you will need to find/buy a replacement. This is a common problem that happens with most all chairs, even if they are rated for heavier weight/long term use, they still do not seem to last more than 1-2 years of use at the most.
Sep 06, 2014 | Serta Big & Tall Executive Chair, Black...
Can I or how can if possible return the Pride Lift Chair to normal seating position manually.Thank you.btrapp@sasktel.net
The easiest way to do this is to tip the chair forward so that the top of the chair and the arms are on the floor. The weight of the chair will be off the lift frame in this position. Look at the motor and you will see it connected to the frame with 2 hitch pins.
It is easiest to remove the top hitch pin which will now be on the bottom because the chair is upside down. Pull the clip (looks like half of a paper clip) from the pin that goes through the square chair frame and motor round tube. Pull out the pin by lifting the bottom of the motor slightly(now at the top because the chair is upside down)with your left hand and pulling the pin out with your right hand. Find the two nylon washers that have fallen out when you do this.
Swing the motor tube out of the way toward the front of the chair. Hold on to the pin, clip, and 2 nylon washers for re-assembly. Hope this helps.
Dec 26, 2010 | Pride Mobility Products Casual CL30KD Lift...
On hoveround teknique fwd chair, showing 8-bar trouble code with all functions locked out. i need to a) raise the seat so it can be removed and b) restore function to the chair. any suggestions apart from...
An 8 Bar Flash on the controller of a Teknique FWB indicates: Possible Control System Trip
A control system trip is indicated. Make sure that all connections are secure. This means that one of the wires attached to the junction box, or the umbillical, may have come disconnected.
Is your power chair equipped with an optional power seat lift? If not, raising or lowering the seat will not restore function to the power chair. Have you tried doing a brake reset just to see if that will help? The manual brake levers are under the bottom front of the chair base; turn off the controller, pull the levers down then push them back up until the pop into place. This reset will clear many issues.
If you are able to check the wiring for the junction box and wish to remove the seat, you can do so, but the Teknique series is terribly difficult for the average end-user to work on and is recommended that a Hoveround Technician do it. Hoveround will not even ship batteries for self-installation to owners of any of the Teknique power chairs because they are such a pain to work on. The seat must be fully removed to gain access to the batteries under the motor cover and most power chair owners do not posses the kind of strength and dexterity needed to do it.
The seat post can be removed by removing a bolt underneath the seat, you will also need to unclip the black umbilical cord leading from the controller to the motor cover so that you do not yank it out when you remove the seat. The motor/battery cover can then be unbolted to allow you access to the batteries and junction box. I cannot give you details on how to do this, because as a Hoveround Tech Support Rep, we are instructed to dispatch a technician for the customer's safety and I have never done it myself or even seen it done.
If your Hoveround was purchased via your Insurance, they will most likely pay for the repair, but it may take time to schedule the appointment if the Insurance requires documentation or verification before allow the repair to take place. If you are in need of additional assistance, please contact Hoveround Tech Support at 800-964-6837 on Wednesdays or Thursdays when the call volume is lower. It's worth a shot.
Dec 23, 2010 | Health & Beauty
How do you raise the metro to make it sit higher off the floor? Is it adjustable
This mnaual wheelchair has dual position rear axles and caster forks to allow seat to floor height changes with no additional components. What this means is that the wheelchair is adjustable in height based upon the position of the front caster wheel axles and rear wheel axles. Raising the axles lowers the chair. Lowering the axle postion raises the chair. If the rear axles of the rear wheels are in the top position you can lower the wheels and raise the chair. Likewise, if the caster axles of the front wheels are in the top hole of the fork then put the wheels and axles in the lower hole to raise the chair. It is easy to accomplish this with basic tools.
If the front and rear wheels are already in the lower holes (the chair is in its highest position) you have another option. This option is a more expensive way to raise the chair by buying 4 new wheels. Lets say for example you have 24" diameter rear wheels. If you purchase new 26" diameter wheels you will raise the chair 1". If you have 6" casters and put on 8" casters this raises the chair 1" in the front. Hope this helps.
Nov 23, 2010 | Everest & Jennings 18" Metro Ic3...
Chair is stuck fully extended foot rest up and back down, Switch doens't seem to work
Providing you have power to the chair, this will be a faulty handset or a faulty limit switch inside the actuator assembly.
Feb 26, 2010 | Pride Mobility Products Casual CL30KD Lift...
Flight Dental A10E Patient Chair Logo
1,661 people viewed this question
Top Flight Dental Medical Experts
Andrew Taylor
Andrew Taylor
Are you a Flight Dental Medical Expert? Answer questions, earn points and help others
