Question about General GEM120 - 20 qt Mixer
The mixer dosent turn on
I need the manulal where can I download it? Please
  • 67 Answers
Normally if you google the make and part number, it should find the product.
Here you go
https://www.etundra.com/pdf/gen0002pdf1.88943.pdf
Posted on Apr 18, 2014
Wher can i find a manule for a 5 quart artisan standmixer to print
You should be able to find a manual here:
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KA_EN_CA
Note that your model number seems to be incomplete; I found 63 manuals for this model number; there should be 3 more characters in the model number.
Feb 06, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I have lost the manual and need the directions for use of the Kitchenaid mixer 5 quart
HI JWPERCY14223. It is very easy to download the
The inspection and troubleshooting of the mixer transmission is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. If you're lacking one, you can download it from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and select “Consumer” for User Type, then enter the 6 character model number, in this case K45SSW, and then select the first file under Owners Manuals (2) K45SSWH-0.pdf (2730.37 KB) (be sure to check that it matches your mixer).
The first file is the full 86 page ‘Instructions and Recipes’ manual in English that was originally included with your mixer. The second file is a 60 page multi-lingual (English, French and Spanish) Instruction manual without recipes.
While you’re downloading the Owner’s Manual, I would recommend downloading the accompanying Part List Manual, too. Select the file under Parts List (1) K45SSWH0.pdf (341.41 KB) and save that on your computer. If your ever have to troubleshoot or repair your mixer the Parts List manual will be an invaluable document to have on hand when taking your mixer apart and reassembling it.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer for your future reference, too.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! – hslincoln
May 03, 2010 | KitchenAid K45SS Classic Stand Mixer
I need the manual for my K5SS mixer my
Hi WWW_SOCRAFTI, you can easily download both the Owner’s Manual and Parts List manual for your K5SS mixer online from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this model range), and then select this file: KSM50PPWH0.pdf (5156.65 KB) from the Owners Manuals (9) list and this file: KSM50P.pdf (438.31 KB) listed under Parts List (4). Check to verify they match your mixer model. You can save them to your PC hard drive, and then you can print a hard copy if you wish, or just refer to it when you need to use it.
The reason I suggest downloading the Parts List manual is that should you decide to try and troubleshoot and fix your KA mixer, this manual will be invaluable in the disassembly and reassembly of your mixer along with listing all the part names and numbers. Having the correct part names and numbers is critical when reordering replacement parts when your mixer eventually will stop working.
Good Luck with your mixer, I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! -hslincoln
Feb 14, 2010 | KitchenAid K5SS Heavy Duty Commercial...
The wisk is hiting the bowl how can i adjust
Hi FMOINIZ, by the symptom you are describing, you need to adjust your mixer’s Bowl to Beater Clearance. This is quite an easy task, and is explained in your Users Instruction manual that came with your mixer. If you do not have one, you can easily download a PDF version from the KA website at: ’t have the original manual you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM150 and select the file listed for your model that appears under Owners Manuals (4) KP50PSWW0.pdf (2930.74 KB) and save that file to your PC. Turn to Page 11 and you will find the instructions for adjusting the Bowl-Lift model mixer head height.
But to save you some time, I have extracted the instructions below:
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 26, 2009 | KitchenAid KP50PS Professional 5 Series...
I need to raise the head of the mixer. The wire whip is hitting hard the button
Hi LEDAVETTORI, you don’t provide the model number or say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, which would helpful, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number and select a file listed under Owners Manuals and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater. •Make adjustments with flat beater, so it just clears surface of bowl.
If you find the adjustment screw missing, you’ll need to replace it. But now you’ll need
Dec 18, 2009 | Food Mixers
NO POWER TO UNIT, NO POWER TO SWITCH.
Hi all. Goto mendingshed.com and download the free kitchenaid repair manual for free. These older mixers were well built, unlike the new ones. They are well worth repairing. The repair manual is very comprehensive and will assist you greatly should your mixers need repair at a later date. Good luck!
If this solution has assisted you, please rate it. ricardok45
Mar 29, 2009 | KitchenAid K45SS Classic Stand Mixer
575 watt 6qt stand mixer. start out on low speed
Hi. If your mixer is still under warranty, call Kitchenaid, they are usually very good at replacing mixers under warranty.
If you're out of warranty, you'll need to order a new speed control board. Use the following link to download the parts catalog for your mixer.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212278.pdf
You can remove and replace this board yourself. Use the drawings to assist you with the project.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 16, 2009 | KitchenAid KP26M1X Stand Mixer
MOTOR SPINS ON MY CLASSIC STAND MIXER BUT GEARS DON'T ENGAGE
Hi all. There is damage to the transmission caused by overloading the mixer with bread or cookie dough, or by dropping a spoon or measuring cup into the mixer while it was working.
Go to mendingshed.com and download their free kitchenaid repair manual. This manual has all you, or a repair person will need to repair your model's mixer. Mending Shed also sells needed parts.
Mar 06, 2009 | KitchenAid K45SS Classic Stand Mixer
KitchenAid 2671 onmly run Stir and Second at high speed
Hi. Goto kitchenaid.com and download the parts catalog for your mixer model, these drawings will assist you in the disassembly and reassembly of your mixer.
You'll need to replace the speed control in your mixer. This is a common problem. Be prepared to wait at least a month for your parts to arrive. Unplug your mixer before you open it up.
If you're still under warranty call kitchenaid!
Jan 28, 2009 | KitchenAid KP26M1X Stand Mixer
General GEM120 - 20 qt Mixer Logo
57 people viewed this question
Top General Food Mixers Experts
eyecam
Are you a General Food Mixer Expert? Answer questions, earn points and help others
