Question about Vizio E420VO 42 in. LCD HDTV
Vizio tv wont turn on
I turned the tv on this morning and it was working fine. I reached for the remote and it shut off. Now when I try to turn it on, the VIZIO screen comes up then it shuts back off.
  • 3 Answers
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
  • 267 Answers
SOURCE: 46" LCQ VIZIO WON'T TURN ON ALL OF A SUDDED
IT SHOULD BE UNDER WARRANTY. TAKE IT TO AN AUTHORIZED VIZIO SERVICER.
Posted on Feb 06, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
  • 13 Answers
SOURCE: VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Posted on Jan 22, 2010
I have a Vizio SV48OM. It is hooked up to Dish. this morning I couldn't change channels or anything with my dish remote but could turn the tv on and off. Called dish and was trying to see what the...
About the only thing you could try would be to reset both the dish receiver and the tv. Disconnect both from electrical power source, (unplug) after a minute or so, plug them back in and try again. if neither works then you may have had some type of power surge.
Be certain your tv is in the right source, however the tv has been connected to your receiver.
Oct 29, 2013 | Vizio SV470M LCD TV
When I turn on my 42" vizio all I get is the vizio screen no sound and the remote will not work to turn it off.after being unplugged for awhile (days) i tried it again and it worked fine until i shut
You will need to get a diagnosis done on the set. It could be a power supply issue or a main board issue. Your problem is between one of those two boards.
Apr 04, 2013 | Vizio VW42LF 42 in. LCD HDTV
Vizio VO47L FHDTV10A wont turn on, logo goes from amber to white, tv clicks once and wont turn on. remote will try to turn the tv on. suggestions?
check your inverter board and wires 2 make shure there not arking. then check your six transformers on your inverter with volt meter
Jan 31, 2013 | Televison & Video
I have a vizio vu37l tv..about 2 years old. Last night on its own it started switching to av1...comp...hdmi...all by itself..it even shut itself off. It also switched this morning....why is it doing this...
Vizio Has a big issue with all models working with each other, if either you have another vizio product in your home or a close neighbor, the remote signal is probably reaching your TV,
Jul 06, 2011 | Vizio VU37L 37 in. LCD TV
32" Vizio Flatscreen TV will not turn on.
I had a lot of problems with the same TV but i'll be watching it and it will go full volume with static and turn off by itself then i would have to unplug it from the wall. then it would work fine for a day or a week then do it again. but today it did it and it wont work the yellow light is on but wont turn on.
Sep 09, 2009 | Vizio VW32L 32 in. LCD HDTV
47" Vizio Flat screen HD LCD freezes up and remote will not work.
could it be Ch 9's digital signal is not broadcasting right? what is your refresh rate on your tv? 60 or 120hz? if its 120hz, then its more then likely the digital broadcast, if its 60hz I think its your tv can't keep up with their signal that may be at 120hz. Make since??
Jun 16, 2009 | Vizio VO47L 47 in. LCD TV
Jan 30, 2009 | Vizio L32 32 in. LCD HDTV
Both TiVo and Vizio remote aren't working right. Has to be TV.
my remote is not responding to new battery not showing green light.
Nov 16, 2008 | Vizio L32 32 in. LCD HDTV
Lcd sanyo
Could be main or power board
Dec 30, 2017 | Sanyo DP23625 23 in. LCD Television
Vizio E420VO 42 in. LCD HDTV Logo
44 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
