Question about Canon PIXMA MP780 All-In-One InkJet Printer
Wrong cartridge message always on
Wrong cartidge
    President:
  • 2,306 Answers
Wrong cartridge means you need a new printhead. qy6-0049-000. Around $59.00. Cartridge in this case refers to printhead, not ink cartridges.
Posted on Jun 19, 2009
Epson printer will not print any copies. I get the message "change cartridges 98/99." I did change both cartidges and can't clear the message and print copies.
i assume that everytime you try to print you get the same message. i sometimes get cartridge unrecognised on my epsom. I have to remove the cartridge, wipe the chip on the cartridge and reinsert.
If this doesnt work please specify printer model and if using original epsom cartridges.
Nov 15, 2011 | Office Equipment & Supplies
In my printer hp 1600c always cartidge light is flashing but all the cartidge is inserted properly.
in that case you will have to reset the printer;
Follow the procedures below to successfully reset your printer:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the printer.
3. Wait for the "Insert Cartridge" message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Good luck.
Nov 30, 2010 | HP DeskJet 1600C InkJet Printer
Printer won't print, message says ''wrong cartridge'' I have the correct cartridges installed and it still will not print.
Would I be correct in thinking that you have just changed the cartidge?
If so, then remove the cartridge and check that you have removed all the transit seals that are fitted to prevent leakage in transit.
Mar 15, 2010 | Canon Office Equipment & Supplies
Won't accept color cartridge
Is this a manufacturer cartridge or a knockoff? Knockoff cartridges can for sure cause that message. If it is a new one, it is possible it may be the wrong one. Check your manual. If this is also not the problem, then your printer has an internal problem and needs repair. Hope this helps. Cheers.
Oct 06, 2009 | Lexmark X5470 All-In-One InkJet Printer
I am trying to install a new black ink cartridge #23 and it keep giving me an error message saying left cartidge is installed wrong. I have replaced these cartidges many times and never had this problem.
you may not have it seated properly just take it completely back out and reinstall it and it should work fine if not unplug it and try again
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | Lexmark X4530 InkJet Printer
Still getting message empty cartidge lexmark x2650
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 26, 2009 | Lexmark X2650 All-In-One InkJet Printer
MFC-235C Print Message Problem
Using copy cartridges this is a common issue. Always use genuine cartridges.
May 17, 2017 | Brother DCP 115C All-In-One InkJet Printer
Window shows "remove color cartidge and check" On screen dialog box states " color cartidge in wrong. I have had the HP V40 series since 2002 and never had this problem before. I have...
2 possible problems.
1 cartridge faulty or just needs a wipe
2 carriage ribbon damaged
Take the cartridge out and gently rub the gold contacts on the side with a piece of tisue. This might clear it. Take a look at the cartridge carriage in the printer and make sure the ribbon where all the gold contacts meet up with the contacts on the cartridge is not damaged in any way. sometimes the little metal spring which holds the cartridge pierces the ribbon at the back of the carriage and then the printer is unserviceable.
if rubbing the cartridge does not work and the ribbon is not damaged then assume you have a faulty cartridge - rare but it does happen
May 09, 2008 | Office Equipment & Supplies
Print Cartridge Missing
yes ı have your problem help me please
Mar 23, 2008 | Lexmark Z735 InkJet Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
344 people viewed this question
old marine
old marine
