Question about Husqvarna Garden
Hi my Husqvarna moves fine but each time I try to turn on the mower blades it conks out
When I have my leg on the clutch and try press un the handle to put the bladed on it start to conk out and about when i have moved the handle half way up it does conk out. any ideas
  • 472 Answers
You have a bad switch could be the ingament sw
Posted on Apr 18, 2014
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
wadembly
  • 462 Answers
SOURCE: Craftsman LT1000 tractor not moving
hello otto i would check the belt that runs to the rearend but the brakes could be also froze up i would try to jack it up & see if it will move then go from there
Posted on Jun 08, 2009
  • 636 Answers
SOURCE: craftsman riding mower blades won't disengage
Sounds like the shear bolt is broken, Do you have and owners manual to show you the location of shear bolt? They are easily replaced.
Posted on Aug 15, 2009
  • 146 Answers
SOURCE: turn off mower blades the electric clutch spins and the two green
There should be a metal "anchor" that bolts to the chassis or engine. It has a rod that sticks downward, fitting into a notch in the clutch to keep it from turning. It must be missing or broken, or maybe the clutch is the wrong model, and that's why the clutch itself spins and rips out the wires. Good luck! Please rate if you found this helpful, thanks!
Posted on Jun 05, 2010
wadembly
  • 462 Answers
SOURCE: Bolens clutch wont engage
check to see if there is something caught around the blades that won't allow to turn
Posted on Jun 27, 2010
The blades will not disengage when the PTO switch is pressed on my 54" mower.
sounds like the PTO is stuck on
does it make a clicking noise when you put swtch on?
remove clutch and bench test to see if it moves
Oct 21, 2015 | Husqvarna Garden
Zero turn will not move forward reverse or turn
These units use Hydraulic pumps for motivation. If the unit stopped all at one time, I suspect a drive belt came off.
For both pumps to fail at the same time would be very odd. Check the v-belt driving the wheel pumps.
Apr 12, 2015 | Husqvarna Zero Turn Mower RZ4619
Engine conks out when blades engaged
maybe safety switch in seat
also check to be sure blades move freely
no stuck belts or pulleys
Sep 21, 2013 | Husqvarna Garden
Bracket clutch anti-rotation
Without the anti-rotation arm installed when you engaged the PTO the clutch spun and probably ripped out the wires connecting it to the harness. This can be repaired but is tricky. If you have a Husqvarna dealer close by, it will save you several hours of labor to have them correct the problem.
Mar 07, 2017 | Husqvarna Garden
Husqvarna YTH 2448 shuts off when I let out clutch or engagae mower blades
Hi, check or replace the switch on the seat, basically its not telling the safety system that you are on the seat. Regards Phil.
Jul 07, 2012 | Husqvarna Garden
Husqvarna zero turn runs great but after about 30 mins the blades stop turning
when this happens you need to see if it you loose power to the clutch to see if the clutch is failing or the circuit feeding it power
Apr 27, 2012 | Husqvarna Zero Turn Mower Z5426
Blade wont start
Check the linkage on your hydro drive.Follow shift lever from handle to trans axle and see if linkage is ok. :)
Sep 07, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
Jul 31, 2009 | Husqvarna Garden
Garden Logo
43 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
