Question about Comfort Products 60-5800t Commodore II Executive Oversize
I need replacement parts
One broken wheel needs to be replaced
BLOWER WHEEL BROKEN
In your instruction manual you should find a parts list, purchase a new blower wheel and install it. If it is an older unit it may be best to just replace it.
Feb 12, 2014 | Frigidaire Dehumidifiers
Plate wheeled support broken
You will need to go to Sunbeam to get that part, if it were a plate easier to find. ebay is a very good source for microwave parts, also check out a microwave repairman.
Mar 08, 2012 | Sunbeam Microwave Ovens
Broken radio controls,(steering wheel)
easy and not so easy the part you need is the clock spring underneath you steering wheel.to replace it is the not so easy part,you will need a steering wheel puller and some tools.its doable.purchase new one so you will know what you are looking for.
Nov 24, 2010 | 2005 Pontiac GTO
Two left side front wheel studs nuts broken.
They are replaceable.
You can knock the broken studs out with a point chisel (wear safety glasses). Take the pieces and nut to an auto parts store in order to get the same nut size (don't want to use two tire tools/wrenches).
Sep 25, 2009 | 1996 Nissan Quest
Broken rear wheel on graco duo stroller
You can order replacement parts from the Graco website.
http://www.gracobaby.com/
Go to the Help Center, then Order Replacement parts. You'll need the model number and serial number or manufacture date. Site helps you locate the information on your product.
Jun 09, 2009 | Graco DuoGlider 7444 Twin Seat Stroller
Where can I find replacement parts - front wheel assembly
Call perego at 1800-671-1701,they havy any parts you need in stock.
May 18, 2009 | Peg Perego A3 Newport Standard Stroller
Wheel broken for chicco DJ walker
I have the same problem and contacted Chicco UK directly. Provided that you live in the UK contact the company Storktalk on 01159306700 and the will send you a pair of replacement wheels for £5 including delivery.
Hope that helps
P
Mar 31, 2009 | Toys
GRACO STROLLER FRONT WHEEL BROKEN
I have the same problem, the airline broke ours the last time we flew. I just found on Graco's website that you can order replacement parts. Here is the link, http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
You'll need the model number and serial number. I found ours on a sticker under the footrest. For our stroller it's $19 plus shipping for the front wheel assembly.
Hope this helps.
Jan 13, 2008 | Baby Gear
Comfort Products 60-5800t Commodore II Executive Oversize Logo
380 people viewed this question
Top Comfort Products Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Comfort Products Office Equipment and Supply Expert? Answer questions, earn points and help others
