Question about Philips 42PF9631D 42 in. Plasma Television
Philips dcr pixel plus model#42pf7320a/37
Red light blinks 7 times nothing goes on took off back panel caps look good 1 panel blinks 1 green light another blinks 2 green lights then goes off
4 Suggested Answers
  • 138 Answers
SOURCE: philips 42pf7320a/37 dead
I do agree with the tech but if the green led don't come on and the 7-blink error code is still there. check the connector from the logic board that will be the board under the small signal baord. The small signal board have the AV input on it. Check the connector from the logic board to the power supply there should be one connectore btween those 2 boards. On the power supply side second pin from the left it will say Vs_On if the set has 0 volts the proble is the SSB or the logic board. how to determain that is to Use 2 Jumpers to short J8003 & J8004 on the left edge of the PSU (see figure below).
Use 1 Jumper to short CN2012 on the lower left part of the Logic PCB (this will supply a 100% White signal to the Display).
Plug in the AC to the PSU thru CN8001.
If PDP panel operates with White field screen then problem may be the SSB.
Posted on Aug 20, 2008
CAYPIANAN
  • 227 Answers
SOURCE: Philips 42PF7320A/37 blinking red light
hello, amigo if the all the caps are godd then you have to replace the power supply board. don't try to fix it this is not an easy task. you are looking at almost $200.00 with tax an shipping. just go to google and type your tv model # and ask for the power supply board or just look for the part# on the board itself. good luck
Posted on Jul 29, 2009
jdvillanueva
  • 2098 Answers
SOURCE: phillips model#42PF7320A/37 no picture
Hi tileman5,
Your 7 blinks (error code) means that your 8.6 vdc in the power supply section is faulty.This was sense by the standy-by power supply's initial test. This voltage is easy to locate in the power supply board, each output voltage is written in the board itself. Concentrate in its regulator circuitry. Look for open fusible resistor, shorted transistor and leaky/dried capacitor. The unit is disable unless you fix this 8.6vdc fault.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 09, 2011
Philips dcr pixel plus no picture red light how to fix?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Apr 26, 2014 | Philips Televison & Video
Red light flashes 7 times no pic or sound
This is a known issue on this television. The troubleshooting steps require that you have a DVM. If you dont have a DVM and just want to take a shot at fixing it, replace the MF power supply board. http://www.shopjimmy.com/catalogsearch/result/?q=37PF7320A+
Apr 07, 2014 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv will not come on. Red light blinking on bottom left front. Red light blinks 7 times
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them. My tv just blinked red lights, had the clicking sound at first power on, but then goes black. No sound. No picture. Nothing. Just blinking red lights.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.comj
Nov 01, 2011 | Philips 42PF7320A 42 in. Plasma HDTV
We have a Philips plasma 42PF7320A/37 tv. When we plug it in, all we get is a red blinking light. We took the back panel off and looked at the capacitors and they look fine. What else should we check...
cOUNT THE NUMBER OF RED BLINKS AND MAKE NOTES OF THE SEQUENCES. Third will tell tou what is wrong with the tv during it's self diagnostic.Google the make and mogel numbr and seaqrch you anwers from ther.
Jul 09, 2011 | Philips 42PF7320A 42 in. Plasma HDTV
I have a 42" philips plasma with 8 red blinks
90% of the time this is capacitor related in the power supply, Remove the back and check for capacitors that are domed shaped on top, Replace these and all should be ok.
Mar 05, 2010 | Dell W2600 26 in. LCD Television
Jul 29, 2009 | Philips 42PFP5332D 42 in. Plasma...
FLASHING POWER RED BUTTON 7 TIMES
I believe that is a bad power supply board. You can unplug set ,open the back access panel and look for swollen electrolytic capacitors they will most likely be slightly rounded on top instead of flat top like the others.Not sure if just replacing caps is enough we mainly swap out whole board.Some models' replacement power supply is slightly different from original in that a couple of the plugs are in different spots and require an extension cable.
the tv dude
Apr 01, 2009 | Sony KDS-R50XBR1 50" HDTV
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF7320A blinks 3 times every time i hit the power button
The SSB is small self contained board that u connect your Antenna, and HDMI to. An error three is a communication error between the SSB and to Logic board ( located underneath the SSB on the back fo the plasma panel that is just below the power supply. U can check parts.com and see if u want to purchase a SSB for this TV. Is the 3blinking lights coming from the front of the TV. Also check the power supply and see how many times the green led blinks on the upper left of the power supply and let me know.
Apr 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF9631D 42 in. Plasma Television Logo
87 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
