Question about iLO (2 GB) MP3 Player
Please help me to repair me device.
My MP3 player does not work at all after it was accidently formatted in the windows.
    President:
  • 828 Answers
Are you sure that you format your mp3 player by using its own utility program because this might be the reason if you format it in My Computer.. please tell us... more...
Posted on Jun 19, 2009
My philips gogear 4gb mp3 player is nt startin what 2 do??
I'd suggest that you format your player or repair it using Philips songbird or device manager. Contents may be removed by using this function. So make sure to back up your contents.
Format:
On your computer desktop, double-click "My computer". Double-click on the MP3 player's icon. Right-click on the Internal Storage icon and then select "Format".
Repair using Device manager:
Launch Device Manager and click the Tool menu and select "Repair", then follow the instructions to perform the repair process. Make sure all other applications such as Philips Plug-in, Windows Media Player or Windows Explorer that access the device are closed or else Device Manager will not recognize the device.
Hope this works.
Mar 16, 2011 | Philips GOGEAR SA6045 MP3 Player
What do i do... i have been getting a system error file... cant play music or anything...please help me
Firstly, I'd suggest that you do a soft reset of your player. You will find the reset button next to the 'power on' button on the side of the player. Please hold the Reset button using a pen tip or other sharp object for 10 seconds. Now turn it on.
If that doesn't work, I'd suggest that you format your player or repair it using Philips device manager. Contents may be removed by using this function. So make sure to back up your contents.
Format:
Hope this works.
Mar 14, 2011 | Philips GOGEAR SA6045 MP3 Player
The media converter does not reconize my gogear vibe 4 gb
It could be because your player is frozen. Firstly, I'd suggest that you do a soft reset of your player. You will find the reset button next to the 'power on' button on the side of the player. Please hold the Reset button using a pen tip or other sharp object for 10 seconds. Now turn it on.
Format:
Hope this works.
Mar 13, 2011 | Philips GOGEAR SA6045 MP3 Player
Will not power on will not recharge
If that doesn't work, I'd suggest that you format your player or repair it using Philips songbird or device manager depending on which software is used on your MP3 player. If your model number starts with SA1..... your player supports device manager. If it starts with SA2.... then it uses Philips Songbird. You can install them from the CD that came with your player or download it from Philips support site.
Format:
Repair using Songbird:
Launch Songbird and then connect your player to your computer. Select "Repair" under the "Tools" menu. Follow the instructions given by the pop-up windows to perform the repair process.
Hope it helps.
Feb 27, 2011 | Philips GoGear ViBE Digital Media Player
The formate
Ok, if you need to format the player, please connect it to the PC.
If that doesn't work, I'd suggest that you repair it using Philips device manager. Contents may be removed by using this function. So make sure to back up your contents.
Hope this helps.
Feb 12, 2011 | Philips GOGEAR SA6045 MP3 Player
I accidently reset my vibe and it wont play or show anything except the gogearvibe deal?
Ok, in this case you can format the player. Contents may be removed by using this function. So make sure to back up your contents. Here is how to format:
Connect your player to PC. On your computer desktop, double-click "My computer". Double-click on the MP3 player's icon. Right-click on the Internal Storage icon and then select "Format".
If that doesn't work, repair it with Songbird or Device manager. Whichever application your player uses.
For Songbird:
Launch Songbird and then connect your player to your computer. Select "Repair my Philips GoGear" under the "Tools" menu. Follow the instructions given by the pop-up windows to perform the repair process.
For Device manager:
Launch Device Manager and click the Tool menu and select "Repair my Philips GoGear", then follow the instructions to perform the repair process.
You player should work correctly now. Hope this helps.
Dec 15, 2010 | Philips GoGear ViBE Digital Media Player
Mp3 player is reading "No Files". I left my mp3 player connected to my PC and accidently turned off the PC, when I returned all of my files were removed. But when I try to download the old music it won't...
This is from Sansa Website at http://www.sansa.com/support/sansa_e200/faqs
SOLUTION 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
SOLUTION 2 – If the problem was not resolved, download and Install the Sansa Firmware Updater.
SOLUTION 3 – If the problem was not resolved, format the device
WARNING: Formatting will DELETE all content in the player. Please backup all your data.
Please use Windows Explorer or Windows Media Player to format your device.
Mar 07, 2009 | SanDisk Sansa e250 MP3 Player
Formating the mp3 player
Don't format the player. Run a Repair in the Philips Device Manager. If you have lost your installation CD, you can get the Philips Device Manager from Philips website.
-Tha Mp3 Doctor
Feb 11, 2009 | Philips SA2310 GoGear Mp3 Player
Lost Music
Try to format your device using windows media player if you have not done so...do not use my computer to format the device because you will delete the firmware also...should you need help formatting the device inside windows media player, let me know...
Jan 25, 2008 | SanDisk Sansa Clip MP3 Player
System files - windows doesnt seem to now be able to detect iriver
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Jan 31, 2007 | iRiver H10 MP3 Player
iLO (2 GB) MP3 Player Logo
54 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Jon Piercy
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
