Question about Kitchen Appliances - Others
How do i service drum on an sd-100 compactor - Kitchen Appliances - Others
How do i service drum on an sd-100 compactor roller?
Service manual for a terex tc 550 compactor
how old it that
may have to contact Terex themselves
http://www.terex.com/construction/en/products/loaders/index.htm
not any e manual type copies
no ideas why it isnt on the Terex repair/service manual site
http://automanual.co/cars/terex-Repair-Manual.htm
May 17, 2016 | Kitchen Appliances - Others
I have a whirlpool gas dryer. One of the drum rollers keep getting shredded and breaking only after a couple of hours of use. I have now replaced both drum rollers 5 times in the last 6 weeks.
Did you lube the bearing surfaces of the new rollers with a good lube? Is the shaft surface for the bearing smooth? Do the new rollers wobble on the shaft (very bad)? Do your have the drum on straight and is it riding on the felt surface in front ok? Do the rollers turn easily after you install them or are they jammed up for some reason? What does the surface on the drum where the rollers ride look like? Does the idler pulley for the belt hold the belt steady in the correct place on the drum or does it wobble around? I have serviced these rollers on many occasions and they last a long time. The felt in front should be both in front of the drum and reach across the outer front edge of the drum. Sometimes it get all bunched up at one spot in front of the drum without wrapping around the outside too. I put the bottom in first and then use a J shaped piece of bent tin to guide it in on top where I can't see it.
Dec 12, 2015 | Whirlpool Dryers
How do I choose the right compactor for the job I'm planning to do?
It all really depends on what you want to do. There are three main types of plate compactors.
1. single-plate compactors only go in the forward direction, this is good for a small project like a laying asphalt.
2. Reversible plates are able to go forward and backwards.
3. High performance and heavy duty plate compactors which are usually used for deeper compaction projects.
For your at home project you should be fine with a single-plate compactor.
Nov 11, 2013 | Tools & Hardware - Others
My ge profile 15" compactor stopped compacting. I
The "wheel" has a cracked center that you can not see unless you take the whole gear off.( I am assuming the "wheel" is off the motor and should be driving the chain that goes to the side gears ) There is a tension washer looking thing that holds it on and you can force it off with a flat screwdriver. Once off, I'm sure you'll see the center of the gear( hex shaped) is not engaging the hex gear shaft for being broken somewhere. An appliance repair store should have that part for less than $50. Sure beats the $85 the service people start with for just a service call.
Dec 11, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
E0067-0110
E067 High voltage-related error
0100 The measured current of the primary
transfer ATVC is abnormal twice in
succession.
Check on the primary transfer roller spring, Clean
the position where the primary transfer roller
contacts, Replace the primary transfer roller,
Replace the drum unit Check a value
of COPIER> DISPLAY> MISC> DRM-LIFE, and
replace the drum unit if the value is near 100
because the drum may have reached its life
expectancy.
0110 The measured voltage of the primary
succession.
Turn OFF and back ON the main power
Jun 07, 2010 | Canon iRC3100 Printer
Kitchenaid compactor KUCS03FTSS makes banging sound at end of cycle
I bought a Kitchen Aid trash compactor the end of Sept/2008. By July/2010 I have spent $528 on having it fixed! It only cost $623 new so I called Whirlpool customer satisfaction line where after waiting 15 minutes was told that "With all due respsect mam, Whirlpool owes you nothing" Then " as a courtesy" they offered me 50% off an $80 part that I still need to pay $60 in labor to install! So,that would be an additional $100 on an appliance that has been trouble from the get go...I have had numerous compactors before this brand and have never had any trouble...Do NOT buy anything made by Whirlpool as they have apparently, a NO customer satisfaction policy.
May 17, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Ricoh aficio 2018d error sc302 can someone please advise what the problem is
The manual says that this is a chage roller leak.
Means the the high voltage is arching to ground or drum somewhere....usually pinhole in chage roller
Feb 17, 2010 | Ricoh Aficio 2018D All-In-One Laser...
A 1" wide band of black ink continues to to mark copies when printing. Even after roller is cleaned, issue persists
Try printing in single color mode found in the drop down menu - top left corner of the screen. If the line is not present in cyan or magenta etc, then you are probably looking at the black drum unit being faulty. If it happens in every mode, it could be your ITB cleaning assembly that needs replacement. Check the drum life counter in service mode - if the black is very high - over 100% this is another indication (not proof) that the black drum is faulty and needs replacement.
Jan 28, 2010 | Canon imageRUNNER C3220 Color Copier
Our compactor does not work. It makes a humming noise but will not function.
motor jamed . try removing basket . ( pull out and lift up ) ck for plastic of other things in or around drive and rollers .both sides and in back .. ****
Dec 07, 2009 | GE Profile GCG1580LSS 15" Built-In Trash...
Kitchen Appliances - Others Logo
65 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
