Question about Marantz CC-4300 5-Disc CD Changer
Cd tray will not open, no error message comes up
Numark cdn450 has tray error message in left well
For all kind of brands cd or dvd players There is in every cd or dvd tray in the front bottom or under the tray so crazy you can not think an microswitch necessary that will be by mechanic close of the tray detect if the tray is closed and give a timed signal (close or open) to focus laser for reading of table of contents if the belt is bad it can take to long by a slipping tray drivebelt for the detection , or the microswitch or brass plate contacts are have a little corrosion on it or even it can be broken by a missing timing.
Dec 23, 2013 | Numark Industries Numark CDN450 Rack Mount...
FL 8350 CD Player. Disc drawer will not open. Getting error message
Most likely a belt has stretched and will not now move the tray. This happens of units more than 2 years old usually.
Dec 26, 2012 | Harman Kardon FL8350 5-Disc CD Changer
Tray error on a denon dn 4000
The cd transport is up the swanny (broken , kaput).
take it to your nearest registered denon repair/service centre
Sep 05, 2012 | Audio Players & Recorders
Hi - the CD tray cannot open. It is empty - no CDs in there. I hear a buzz, but an "error" message comes on. I tried pushing on the tray while turning on; I unplgged the CD player, I put it on...
The loading tray belt has more than likely stretched or snapped.
The buzzing you hear will be the motor spinning freely.
The 'ERROR' message will show up because the tray isn't opening
and activating the 'tray open' switch, therefore the 'tray closed' switch
is permanently activated after the 'open/close button is pressed.
Aug 20, 2011 | Marantz CC-4300 5-Disc CD Changer
Player will not play a loaded CD and No CD message comes up Also CD drawer opens and shuts on it`s own !!!
the tray opening by itself could be a faulty limit switch on the tray mechanism
the switch tells the system if the tray has reached the open or closed position.
if it closes then opens itself then this is the most likely
check that first
could be closing then opening without actually loading due to the switch
you will need to open it up to find the switches
usually at the bottom front were the tray goes in
darren
May 28, 2011 | NAD C542 CD Player
Epson 220 not printing cd labels anymore
Clean the white areas on the tray with a light solvent cleaner like windolene/windex liquid. Also try giving the tray a helping hand as it is started to be fed into the printer
Nov 08, 2008 | Epson Stylus Photo R220 InkJet Printer
Deneon UD M50 - Tray jam
It sounds like the cd tray has been forced shut and has been damaged when you got the CD's out. If it was me I would of unscrewed the casing and retrieved the CD's that way instead of trying to force the try open which I'm assuming you have done.
It could just be a simple matter of just slightly adjusting the internal CD mechanism so that it can open and close properly without jamming. The error message comes up because the tray cant eject properly. The worse case scenario is that the CD mechanisam would need to be replaced. Not a hard job for a service engineer, if you dont fancy taking the thing apart yourself then a service centre is your best bet.
Nov 01, 2008 | Denon D-M50S CD Shelf System
Cd tray error Canon Pixma MP810
Sorry a little late only just read your problem.
The location is not the bottom tray feeder but the disk tray. In settings change your media type to "Printable Disk" the paper scource should automatically change to "Disk Tray" and hopefully every thing will work OK.
May 19, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
CD printing
there is a small,square button near the right,front corner. think of it as the button for the refrigerator light. It must be depressed by the closed top or maybe something to wedge it down. Duh
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Marantz CC-4300 5-Disc CD Changer Logo
47 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
