Question about Nokia 6234 Cellular Phone
How hard reset bluetooth - Nokia 6234 Cellular Phone
    Sergeant:
  • 181 Answers
Hello. The best thing to do is rest to factory settings.
Posted on Apr 18, 2014
Parrot ck3100 stuck on goodbye screen any way to reset it ,thank you
Found this on the net, not sure if it works or not:
"Hard reset the CK 3100 by pressing all three buttons for two seconds and then pressing them a second time (warning initializes factory settings)
2. hard reset thisback to factory settings"
Straight copy paste out of fixya website
and the link to the source:
Parrot CK3100 Bluetooth car kit hard reset
Oct 08, 2016 | Parrot SA Parrot Ck3100 Lcd Handsfree...
How do I reset my samsung hm1500 bluetooth headset
Please anyone who has samsung bhm1500 bluetooth headset manual,upload it to a file sharing server.
Thanks
Aug 01, 2012 | Samsung HM1500 Bluetooth Headset
My blackberry curve recognizes the LG HBM-570 headset, but the headset keeps telling me it is terminating. It has worked for 3 months and just started doing this.
Hi, to solve this problem, you will have to do some troubleshooting.
First you will need to disconnect the pairing of both the blue tooth headset from your black berry phone.And pair again with the below instruction.
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
After that if still does not work that means you will need to test if the bllue tooth headset is really not damaged by using it on another phone to confirm.
You can also reset the blackberry cell phone if still not working. Blue tooth might be corrupted and will not connect to headset. You can use the below instruction to reset cell phone:
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry Below.
software112.com/products/blackberry-desktop-software.html
When you are through with that and still nothing happens, then you blue tooth headset needs replacement..
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
Feb 18, 2011 | LG HBM-760 Bluetooth Headset
Unable to performed bluetooth operation
check *#2820#
if your able to get bluetooth address then its software problem,hard reset your mobile,
Hard reset-*#7370# and press Yes to confirm initialization. Back up your data plz.
else its hardware problem
change bluetooth IC 100% solution
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 26, 2010 | Nokia Cell Phones
Got a message on my Nokia N73 'unable yo perform
sir just hard reset your phone hard reseting code is *#7780# type this on your phone`s keypad it will not delete your any data
Sep 09, 2009 | Nokia N73 Cellular Phone
Audiovox smartphone stuck in Flight Mode
You can Hard Reset the phone by either of two methods. Start/Settings/Clear Memory, or power on while holding both left and right softkeys down.
This resets and reloads the phone software system its ROM and you will lose any and all personal data and apps you put on it since receiving it. Back up all you can before hard resetting.
Apr 12, 2008 | Audiovox SMT5600 Smartphone
Bluetooth problem
often i find that programs are to blame for using lots of memory. a hard reset generally closes most of them but i use ClearTemp to remove the registry dregs and unused shortcuts. http://www.pda-ppc.com/download/utilities/content/cleartemp.html hope that helps!
Jul 05, 2006 | HP iPAQ H2210 Pocket PC
Bluetooth after ROM-Udate
I had contact to helpdesk: I made again an hard-reset, and now i can use the Bluetoth again with no problem. Now i have only one Icon for bluetooth and wireless on the desktop. Bevor i had also two Icons. The helpdesk said, that at running the Rom-Update you have to shot down firewall and virus-software on your maschine. Then make a hard-reset and run the rom-update again.
Sep 11, 2005 | HP iPAQ hx2410 Pocket PC
Nokia 6234 Cellular Phone Logo
15 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
