Question about Kenmore 505 sq. in. Cooking Area Gas Grill 463350505
I have a Kenmore natural gas grill, model # 141-17227. I need the woners manual. The side burner will light but very low flame, cannot get the grill to light.
  • 43 Answers
Owners manual can be gotten through the internet- Sears.com find parts,type in model# of item, select manual sounds like valves are clogged- propaine and natural gasses are dirty gasses-no filter, it comes up out of ground,through dirty pipes, all the way to peoples homes- and thats why they have to replace valves on hot water tanks/furnuces........
Posted on Jan 07, 2010
Natural gas grill low flame
Did you change the reg , lpg burns at 14 inches wg nat gas burns at 4inches wg
Feb 16, 2013 | Char-Broil Commercial Stainless Steel...
Low flame - doesn't heat enough
Hi, Patty. The low burner flame on a natural gas grill an be caused by several things.
1. The gas line shutoff valve is not fully open.
2. The burners are clogged and need to be removed and properly cleaned
3. The venturi valve(s), which has spider screens may be clogged.
The things listed above are the top 3 reasons for the low burner flame problem on a Natural Gas Grill.
To help you accomplish the cleaning of the burners and the venturi valves, I have included a link to your Owners Manual, that you can download & print for future reference. It has detailed instructions and diagrams in the Maintenance section, that will show you how to accomplish this.
http://help.weber.com/manuals/pdf_files_2011/Gas/Spirit%20ES%20Series%202007newer/OwnersGuides/Spirit_210310_NG_OwnersGuide_89961_022811.pdf
Hope this helps you to solve the problem. Please let me know. Thanks and Happy Grilling!!
May 14, 2011 | Weber SPIRIT E-210 (NG)
I have a fire Magic A660 drop in grill (natural gas) and when I light the burner (2 of the 3 burners) the flame doesn't travel all the way around the burner. Gas is coming out of all the ports. I can light...
I don't know how old your grill is, but as grills age, the gas ports in the burners begind to clog and corrode. Flame travesl around the burners like dominoes when you stand them up and knock them down, one port lights the next, etc. All burners light on just one side and there are ports that are designed to take the gas from the outside of the burner to the inside and from one side to another. Depending on how clogged the ports are, you can clear them using a straightened paper clip, or a drill with a bit. Be careful not to make the gas ports larger.
Mar 18, 2011 | Fire Magic Grilling
The first two burners on the left light and have good gas flow. When I light the middle and the left two burners the flames flicker and go out, like there is not enough gas. I cleaned the burners, tried...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 22, 2010 | Kenmore Elite 900 sq. in. Cooking Area Gas...
I have a Kenmore 4 burner grill that I purchased about 3-4 weeks ago. 3 of the 4 burners have nice blue flames and work very well but the left middle burner gets a huge yellow flame no matter what temp it...
does the same burner flame turn blue if other burners decreast in flow-with that burner on high and others low-is it still yellow? if so Gas Valve needs to be replaced.
Oct 05, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Low pressur on gas grill
orfices are possibly clogged with spider web
and the check to see if your dial on tank is fully open and check to see if your tank is almost empty...
Jun 01, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
One burner has low flame
Try looking for webs back to where the burner tube meets the valve. Otherwise you need to remove burner tube to access back of valve to clean with a torch tip cleaner or compressed air, (remember to disconnect grill from gas source first) inside valve orifice.  Usually the back of valve can be removed with a wrench. Worst case you always get a new valve off internet if you can't resolve the plug. Hope this helps, good luck.
Mar 21, 2009 | Weber Genesis Silver B Grill
Kenmore Master Flame Grill
Burner will not light:
Here is a couple things you can check:
1. Gas injector not insert in venturi tube.
2. Clogged gas injector
3. Obstruction in gas line.
4.Spider webs in venturi tubes.
5. Misalignment Of collector box and burner.
6.Dead Battery.
7.Check hose to make sure it is not kinked
8.Check Hose to make sure it wasn't chewed by squirrles
9. If it is LP gas, Could be out of gas.
Other Issues:
Could be the way the grill was turned on and off, that also can be an issues. In your manual it will tell you how to do it proper, this could make it not light or have a low flame. If there is not hing in your manual, I will be happy to assist you.
Fireplace-Girl
Mar 16, 2008 | Kenmore 16225 Grill
Kenmore 505 sq. in. Cooking Area Gas Grill 463350505 Logo
140 people viewed this question
Top Kenmore Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
