Error code f17 Bosch WAS24460uc what does it mean?
  • 116 Answers
SOURCE: error code f17
Sears are a department store not a manufacturer, they contract other manufacturers to build the appliances for them and these are then sold under the Sears/ Kenmore brand.
To find who made your appliance, check the first three digits of your model number against the list below and this will give you the manufacturer of your appliance.
There is a site to help identify you washers "real" maker
The Link is here to cross reference it.then look up f17 and f25 on that make and model for better results
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html
the Sears/Kenmore part is almost in the middle of the page. Then keep me posted by adding comments if you have any other questions
I hope this helps you out
8-)
Posted on Jun 07, 2009
canbruce75
  • 1776 Answers
SOURCE: I have a WAS24460UC Bosch washer. It won't drain.
Check the drain line for kinks or obstructions. You can take a flashlight, remove the hoses from the pump and look into the suction port of the pump. Check for anything clogging the pump. (like the occasional stray sock). Also check the pump impellers for broken or missing blades and ensure that the pump impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective and will need replaced. Hopefully it is just a clogged pump or drain line. Hope this helped and best wishes.
Posted on Sep 10, 2009
Testimonial: "I appreciate the feed back. Thanks, Howard"
SOURCE: keep getting error f17 on my bosch classixx 6
My old Bosch only had a filter in the machine (where the hose attaches. My Exxcel has a filter IN THE HOSE at the tap end too. I removed that one and it made a big difference !
Posted on May 07, 2010
  • 414 Answers
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Posted on Jul 12, 2010
  • 6277 Answers
SOURCE: F17 error, what does it mean?
My list for Siemens/Bosch states 'F17' as being 'inlet valve problem'. Sorry- service call ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Sep 13, 2011
Bosch washing machine error code f17.any solution ?tks
The F17 error code is generated by the computer when there is a problem with the water supply.
Check to see if any of the valves are shut off or the filters on the hoses or where the hoses connect to the washer are blocked or restricted. Clean if needed and try it again.
If all that checks out, then you have a problem with the inlet valve on the washer, where the hoses are attached to the back of the machine.
Aug 22, 2016 | Bosch Washing Machines
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
What does F43 error code mean will I need to get a technician
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 12, 2014 | Bosch WAS24460UC Front Load Washer
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
John C
Sep 13, 2011 | Siemens Washing Machines
Bosch classixx 6 1200 express has F17 on display
fault F17 error code appearing. What does this mean ? thanks
Jun 27, 2009 | Bosch Washing Machines
I HAVE NO INSTRUCTION MANUAL -WHAT DOES CODE f17 MEAN PLEASE
F17 code refers to "low water pressure"...check the water inlet valve.
Dec 23, 2008 | Bosch 24 in. SGS43C12 Classixx...
Bosch error message
F17 is a water pressure error not enough water pressure.
Sep 25, 2008 | Bosch 24 in. SGS43C12 Classixx...
Bosch wae24363 washing machine, coming up with f17 error code please help
I had this same message last week. It is to do with the water intake (i.e. the water coming in to the back of the machine). If you have checked that the hose isn't trapped or kinked, unscrewed it and checked the filters at each end for blockages (rinse out if necessary), and you still get the F17 message, it may be because your water pressure is too low, in which case you need to contact your landlord (if you rent) or thames water if the problem is external (especially if there are any works going on near your house). Hope this helps!
Mar 08, 2008 | Bosch 24 in. SGS43C12 Classixx...
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
