Question about Epson Stylus CX5400 All-In-One InkJet Printer
Epson CX5500 with CISS ink supply not printing
I am using ciss ink supply for my epson cx5500. 2 red lights keep on flashing and I can't print now. Can anyone help me out here?
Ive replaced all the cartridges on my epson 5500 but still nothing prints. Any help gratefully received
Posted on Jun 22, 2010
    President:
  • 2,678 Answers
It sounds like the waste ink counter needs resetting. Unfortunately the SSC Service utility does not yet support the CX5500 specifically but as there is support for some of the 5000 series it may work. As with any other 3rd party software it is "at your own risk" I've used it many times in the past with no problems. Failing that you will need to take or send it to a service centre for them to reset it.
You can download SSC from here http://www.ssclg.com/epsone.shtml Don't forget to read the help file before you use the utility (you have to install it first).
Hope this helps.
Posted on Jun 19, 2009
    Scholar:
  • 70 Answers
If this was not your problem, has the CISS system ever worked? When you first install it you need to still have some ink in the Epson Genuine cartridges before you install the CISS cartridges.
Posted on Sep 16, 2013
Epson stylus dx7400 will not work with ciss - lights keep flashing
this mean that the waste pads full and you need software to reset the printer
Feb 11, 2013 | Epson Stylus Office Equipment & Supplies
Epson 1390 red ink light remains on
we have a r1390 power on carries move laft or when carries home possion than red led balking same time
Aug 25, 2012 | Epson Stylus Office Equipment & Supplies
I have an epson stylus tx115 multifunctional printer with the continuous printing system installed . there is plenty of ink in the printer . A red light is flashing telling that there is not ink , I...
You must reset the cartridges chip. About " there is plenty of ink in the printer " you mean ink leakeage in to printer ? If yes, first thing is to clean the printer ( the ciss is not instaled corectly) and reinstall the ciss. The ink tank of ciss should stay at the same level with the printer.
Dec 31, 2017 | Epson Stylus Photo R320 InkJet Printer
Help .. problem on my epson c90 with CISS
Check for status monitor. Flashing alternately mean need to reset waste ink counter, using epson resetter. Just googling for resetter, or contact me for free resetter.
Mar 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How to reset 73/91 Cartridges for Epson CX5500
SSC utility is used for resetting waste ink counter, not for ink level counter (chip at ink tank). If you wish to reset ink level counter (chip), you must use hardware resetter, or use CISS chip with autoreset function.
Oct 18, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Im using ciss for my epson cx3700 and the magenta wont print anymore
Make sure there is not an airlock in the magenta ink line. This is best achieved by fitting a syringe to the flow line and sucking through some ink. Also you may be able to use a syringe and needle to inject some in into the cartridge to prime it. You may need to run several cleaning cycles to get the ink through - I had a similar issue with and Epson R300 using CISS and carried out over 10 cleaning cycles to get the yellow ink to flow again. It may also be worth removing the cartridge and leaning the exit area with a cotton bud soaked in isopropyl alcohol as residue can build up in this area. If the problem persists you can fill the cartridge with cartridge cleaning fluid to flush it through and then empty it and reconnect the CISS ink supply. If you disconnect the CISS Supply a good tip is to use a bulldog clip to prevent the ink from siphoning out of the supply line while you are attending to the cartridge.
Oct 08, 2009 | Epson Stylus C88 InkJet Photo Printer
Add sublimation ink to cartridge for epson c88
The CISS are auto resetebale? If not, you must get a CISS with an autoreset button to get the printer work with the CISS
Oct 06, 2009 | Epson Stylus C88 InkJet Photo Printer
Error massage not compatible ink cartrage when using ciss supply
Solution?the solution is never to buy an epson printer ever again! i bought mine early last year with the CISS and since then have give me that same red lights problems like .. forever ! the solution is to sort of take off the carttridge and put it back again. u might have to do this a few times before it actually work . and oh yeah , you have to print everday with epson cause otherwise the ink will clog !! mine is already clog, i have to buy the original ink now to unclog it but still it produce lines! Since then i have give up hope and put my epson in the box to end my misery . i;m using Canon Pixma MP142 with CISS and till now no problem !!
Jan 02, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX5400 All-In-One InkJet Printer Logo
1,864 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
