Question about Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System
Water does not drain during spin cycle. Tub spins, but water remains in the tub.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 10 Answers
Water pump is out. Will need a new pump.
Only other possibility is your drain hose is clogged check that first.
Drain Pump Part #: AP5684706 Runs about $95:
Frigidaire 137221600 Drain Pump AppliancePartsPros com
Posted on Apr 18, 2014
5 Suggested Answers
  • 1738 Answers
SOURCE: Help: knocking noise (during spin cycle) and inner tub removal
It is your motor.
Posted on Nov 24, 2009
  • 401 Answers
SOURCE: washing machine tub is jamed and wont spin.
Sounds like either the brake or the transmission is locked up. Either way it is a major teardown.
Posted on Jan 03, 2010
Testimonial: "Very helpful."
  • 1531 Answers
SOURCE: tub doesn't spin during spin cycle; motor is
does the unit agitate?
is it does and it will not spin then the transmission is bad.
if the unit does not spin or agitate then check the belt.all assuming that the motor is running.
Posted on Mar 14, 2010
FitzOriginal
  • 842 Answers
SOURCE: my mastermind 708 dosen't spin
Your empty pump filter is blocked with debris. If it can't evacuate all the water then it wont allow the spin cycle to start. Locate the filter (probably behind a little door at the botton of the front of the machine). Remove, clean and remove the debris, re-fit and all will be well
Posted on Jul 01, 2011
I have a Whirlpool duet front load washer model # GHW9150PWD. I have an error code of F 02 and SUD. I have so far cleaned the filter and the lines, replaced the pump, replaced the water pressure swith and...
6 - 1
DIAGNOSIS & TROUBLESHOOTING
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1.
The Remaining Time counter is stopped.
2.
The digital display shows Sud.
3.
The Drain Pump is turned OFF.
4.
The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5.
While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6.
Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7.
After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE:
If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses MANUAL
Oct 31, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Washer is not completing the spin/drain cycle. Stops spinning and draining.
does it drain out all the water? after it stops or is there still water sitting in the tub?
Mar 22, 2011 | Kenmore Elite 45986 Front Load Washer
Washing machine stopped and says "sud". What does that mean?
SUDS DETECTION
Kill-Foam Routine
1. The Remaining Time counter is stopped.
2. The digital display shows Sud.
3. The Drain Pump is turned OFF.
4. The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5. While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6. Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
7. After the five (5) minute rest, the remaining time counter will restart and the digital display
NOTE: If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
subsequent uses.
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My LG front loading washer makes a train noise during the rinse cycle. What could be the cause?
if it is right after the drain cycle; it then goes into a spin. It then starts to fill with water for the rinse while the tub is still turning. The water entering the tub while the tub is spinning, cleans the tub of soap and the water going through the holes in the tub are causing the noise. It is normal if only in the rinse cycle.
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Water overflow when tub is emptying during spin cycle
It sounds more like you have a drain problem that a machine problem. Try draining into the laundry tub and check that the tub drains quickly enough. If not, you have a plumbing problem...Good luck...Nomess
May 14, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
During the spin cycle the washer does not drain the water. The cycle ends but the water remains in the washer. This happens in all of the spin cycles. I have a kenmore model heavy duty extra large capacity...
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Jan 03, 2010 | Washing Machines
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Amana Washmachine (not all water removed during spin) ALW780QAW
you may have blockage in the drain pipe several feet from washer. if you can run spin cycle with hose in different location ex. tub,sink or outdoors. if this works run long snake down washer drain pipe to clean gypsum residual.
Jan 28, 2008 | Amana ALW780QA
The tub never starts to spin when it hits spin cycle.
If your washer functions when the door is shut it cannot be a door problem. The likely thing here is you may have a drain problem....your drain oulet filter (or out pump) could be blocked. This requires cleaning; when the washer goes thru all the functions except spin it is most likely your drain is clogged. Aft u have cleaned the filter & pump check by a small spin. Before you attempt, wall socket off & keep bucket handy to collect water.
Apr 29, 2007 | Crosley CW6000 Front Load Washer
Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System Logo
83 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Robert Siegel
Level 1 Expert
Steven Clarke
Steven Clarke
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
