Question about Canon PIXMA iX7000 Inkjet Business Photo Printer
Cleaning the inkpad of an ix7000
Ink pad is full. I want to know how to take it apart to clean the inkpad.
CAM THE MAN
  • 20 Answers
SOURCE: waste ink absorber
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
There you go.
Posted on May 27, 2008
  • 421 Answers
SOURCE: canon ip4300 ink absorber is full
You need to reset the waste ink counter. The printer doesn't know that you have replaced or cleaned the pads you need to tell it.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Hope that helps, if it does please rate my solution.
Thanks
Posted on Nov 14, 2008
SOURCE: mp390 waste ink tank...how do I get to the ink tank pads to clean them
Best solution-Reset counter. Mine has never leaked!! These Ink pads are large and dry out on their own..so they hold alot more than it says. Just reset the counter and keep printing. The printer will break or be obsolete before it the pads are full.
Reset counter per these instructions:
1) Printer on, press Additional Functions, Scan, Copy, Scan buttons.
(Now you should be in Service Mode)
2) Select Test mode (last selection) and push Set button.
3) Select #8 Printer Test (does something like cleaning) should now say "8-2" or "8-3"
4) Use + or - bottons to select "8-3" and push Set button.
( Should show "EEPRON Clear").
5) Select Ink Count (option 0) and press Set button.
6) Press Stop/Reset button followed by the Power button and wait for printer to restart.
7) Go have a good drink for solving this problem!
Posted on Dec 09, 2008
SOURCE: Waste Ink Near Full
waste ink full
Posted on Sep 21, 2009
SOURCE: MP760 - how to disassemble? (waste ink absorber almost full)
You really don't have to disassemble it. What would be helpful tho is some sort of long needle-nose forceps. Tho I bet you could get by with a pointy chop-stick in a pinch. There are two waste-ink absorbers on the right, and one spongy thing on the left. With the 'hood' open, allowing you access to the cartridges, you should be able to see the pads. Get a Petzl light on your forehead, you'll need a lot of light! The sponge on the left is covered by a small clear plastic trough that channels the ink into the sponge below. With enough poking and prodding you should be able to get all these out, rinse with water, dry with a hair dryer, blot out the pad areas with a kleenex, and pop them back in. Good Luck!
Posted on Nov 14, 2009
What does alternate red and green flashing lights means
Ink pad full. Reset waste ink counter using epson resetter. Replace inkpad or extend the pipe of head cleaning mechanic to outside printer.
Jan 01, 2011 | Epson Stylus Photo 1290 InkJet Printer
Tip
Tips for the epson R300
<br /> <a href="http://www.fixyourownprinter.com/forums/inkjet/68993?rate=1&ing=p"></a><br /> The message on your printer saying that "some parts have reached their life expectancy" or "service is required" followed by a shutdown of the printer has caused many people great anxiety. Some users have even sworn never to buy another inkjet printer from the manufacturer. If you interpret the message to mean that the mechanical parts of the printer have worn out, this feeling is normal. After all, who wants a printer that wears out when maybe only two years old? The message really should say, "The ink waste pads are full and must be replaced." With the Epson, R300 printer the problem can be solved as follows: <br />1. You can buy a new printer. <br />2. Reset the inkpad counter to zero by holding down both the Power and Stop buttons for at least 10 seconds. Then redirect the waste ink to an outside receptacle. Open the panel located on the right hand side of the back of the printer near the serial number location. It is held by a single screw. The ink waste tube can be fished out of the printer through this opening and lead into an outside receptacle. You will never have to replace the inkpads. <br />3. Reset the inkpad counter as above. Take the printer apart and replace the inkpads with new pads, if you can buy some. If you can't buy new inkpads, wash the used inkpads with soap and water. Let them dry and put them back in the printer. You can also replace them with absorbing materials like Huggies, Kotex, etc. <br /><br />Fortunately, I chose the first method before becoming aware of the other solutions. Buying a new printer is actually cheap and this is probably due to the manufacturer's desire to keep you as a customer. At the Epson online Store, under refurbished printers, I bought an Artisan 50 printer for under $60. When you figure that six new ink cartridges come with the printer and you don't have to buy inkpads it is essentially free. In addition, the new software is better than that on the R300 and the CD/DVD tray is smoother. The software is also compatible with files made by the R300. <br /><br />Since the R300 was no longer needed, it was used to look at the other methods for solving the inkpad problem. <br /><br />The second method was the cheapest and quickest solution. However, it potentially has a disastrous problem. The ink waste is pumped through the plastic waste tube by compression of the tube. This puts motion on the ink and it is unbelievable how easy it is to have the ink leave the receptacle. If this happens, clean up any ink spill with Resolve carpet cleaner. In addition, if you have kids or pets the ink receptacle may not always stay where you put it. <br /><br />The third method is NOT recommended unless you just like to take things apart or have other problems, like a clogged ink head that requires the removal of the ink carriage. See the PDF on web site. <br /><br />Every time a site was found that purported to have a service manual for the Epson R300 printer it couldn't be delivered, even for a steep price. Therefore, I decided to make a "Take a Part" document for the Epson R300 and try all of the methods shown above for inkpad and other repairs. This "Take a Part" document is available as a PDF.I will be pleased to email it to you. I am not a printer technician so please forgive any errors in nomenclature. The photos should identify the part. <br /><br />Washing the inkpads for reuse is, in my opinion, the worst operation imaginable. DON'T DO IT. If you can't find new inkpads, use one of the materials mentioned above to replace them. In the "Take a Part" document, two layers of Moddess Hygiene Pads are shown as the substitute. Do not take the pads apart, but be sure the bottom layers are placed with the water resistant layer side down and the upper layers with the water resistant layer side up. There are certain parts of the printer that should not be disassembled if you only want to change the inkpads. These include removal of the ink carriage and its shaft, removal of the waste ink pump, and removal of the CD/DVD print mechanism. <br />
on Jul 15, 2011 | Office Equipment & Supplies
Tip
EPSON PRINTER INKPAD RESET COUNTER
There are issues on printers especially with epson is the dreaded error " PARTS INSIDE YOUR PRINTER IS AT THE END OF ITS SERVICE LIFE"<br /><br />This error is caused by a full ink pad or the ink pad reset counter needs to be reset.<br /><br />to resolve this, for north american customers you can download a program called the inkpad reset counter. this is the site: http:www.epson.com/ipr<br /><br />from there just fill out the required spaces then submit. install and follow the wizard. make sure that your printer does not leak because it means you need to replace the ink pads. and its another question.<br /><br />hope this works and help you out<br />
Have an error ''waste ink container full''. How can I get Ink counter resetter?
Hi there
You need to be handy with your hands, you will have to open up all the printer to get inside it where you will see the ink tank with pads in it need to clean all out and after that you will need to reset it with the MPTools resetter.
Ok I have put a MP-Tools in my website for you to try out this tools are for reseting your inks plus it can do much more.
The MPTools can reset it in till you get time to clean the inkpads.
Click on the link to download it.
Click Link = http://www.4all2sell.com/reset-tools/MPTool.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
May 06, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Waste ink tanks are full on my 130 pixma printer what can i do Les Hill
Hi there
Mar 13, 2010 | Office Equipment & Supplies
Epson stylus cx9400fax; only the black wont print corrct, gaps, missing, illegible. all other colors work fine, have done nozzle check, head cleaning, and replace cartridge. can I take this thing apart and...
You may need to replace the inkpad, it is located under the cardrige park. Also clean the rubber sqeegee blade.
Wear cloves and use a tweezers to remove the ink pad, new ink pads are available online and thru the reatiler that sold you your printer.
Mar 11, 2010 | Epson Stylus CX9400Fax InkJet Photo...
Pixma 150 printer will not print out using the blue ink ( which is full!) it will only print with pink n yellow.Have deep cleaned etc! help?
Hi there
Mar 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink absorber is almost full
Hi there
Mar 01, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Clean out the inkpads
Hi there
You will need to get inside the printer some time to clean out the ink pads.
Feb 26, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Printer acts normal , no error codes, prints but no color
Without a computer, you can print a test page by holding the resume button until the green light flashes 2 times, one flash will do a printhead cleaning. If you enter the mode where you did the reset, and press the resume 2 times and the power button once, it will printout a page of printer data.
Sep 15, 2009 | Canon BubbleJet i560 InkJet Printer
Canon PIXMA iX7000 Inkjet Business Photo Printer Logo
old marine
old marine
