Question about Amana Refrigerators
After cleaning frige and plugging it back up it blows air but not getting cold I can here what I think is the thermastat clicking on and off
It is a Amana refrigerator it was doing fine until it was taken outside and cleaned.
    Novelist:
  • 150 Answers
You are most likely hearing the compressor overload device tripping and resetting as the compressor is probably not starting. remove the rear lower panel of the unit and verify your possible buzz/click is coming from the compressor. If this is the case you can replace the starting and overload device to see if this fixes the issue, if not your compressor may be in need of replacement. Pleazer Appliance...
Posted on Apr 20, 2014
HVACRH20
  • 237 Answers
SOURCE: Freezer is cold but refrigerator is not.
If the fan is still working (and it sounds like it is, then the evap coils are frozen up. A typical failure is the defrost bi-metal t-stat but I've also seen LOTS of the adaptive defrost circuit boards fail on this model. I would lean toward the circuit board first as the culprit. See part 711 http://www.partselect.com/Schematics/Maytag/32266.gif http://www.partselect.com/xq/aspx/Inventory.51814/qx/PartDetail.htm?SourceCode=5&ModelNum=ARSE66MB
Posted on Jun 03, 2007
fridgetech
  • 473 Answers
SOURCE: Amana refrigerator only not working
Few questions first. 1.  What is the entire model # on the sticker inside the fridge section?  2.  Is the fan in the freezer running?  3.  Is there a thick frost build up on the back panel in the freezer (look at the bottom half for a side by side)?
Posted on Oct 20, 2007
Krazytech
  • 725 Answers
SOURCE: REFRIGERATOR
Sounds like a defrost problem or a plugged drain... to get it to work temporary defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Posted on Aug 10, 2008
tborn6
  • 700 Answers
SOURCE: Refrigerator is warm (no air blowing). Freezer seems to be OK
http://www.appliancerepair.net/apnet/frameset?''
http://www.appliancerepair.net/apnet/refr/ch05.htm
this site can help you out just click on it and then read
Posted on Jan 23, 2009
aasc
  • 1606 Answers
SOURCE: I have a model ARB2257CSR Amana frige (freezer on
Sounds like the overload/relay is going out . If the noise is a " click " , replace the o/relay after checking the 3 terminals on compressor for continuity and each terminal to ground ( copper tubing ) .
Posted on Jul 15, 2009
Testimonial: "thanks Mike. it worked at that time, a year later we had more problems and had a new compressor put in and today something else is wrong with it. It is on and sounds normal but is not cooling at all, then when it shuts off there is this screeching noise that comes from it for about half a minute or so."
Window airconditioner cycling on and off too much but blows cold when running
Eliminate the possibility that the cold air from the unit is not blowing directly on the thermostat temperature sensor.
The air conditioner may be extra large in capacity for the space being used for.
Aug 20, 2014 | Kenmore Heating & Cooling
Kenmore refridgerator not blowing cold air.
You need to replace the overload/relay . This is the piece plugged onto the side of the compressor , with 2 or 3 wires going to it . It is easily replaceable . Take your model number with you when you get the part kit , so you get the correct replacement . DO NOT use a 3 in 1 hard start . This item is used by inexperienced technicians , and will only last a short time . Get what is called for , for your refrig .
Nov 04, 2009 | Kenmore Refrigerators
Freezer and frige not that cold
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | Neff K3965XO Side by Side Refrigerator
Doesnt get cold enough ,thermastat gets to 42 degrees but i dont think its cold enough ,can it be set to get colder
check the recirc vents on the freezer part of the fridge , sometimes they condensate and freeze plugging these ports for cold air to circulate
Aug 22, 2009 | Whirlpool Refrigerators
Freezer is working good but the frige is 52
OR
Aug 17, 2009 | Refrigerators
I have a model ARB2257CSR Amana frige (freezer on bottom) and the freezer is not working I think. there is a sound that comes on and off like the motor maybe is trying to come on... the sound comes from...
Jul 15, 2009 | Amana ARB2257CSR Bottom Freezer...
Frige freezing solid
Jul 03, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Ive got a beko frost free frige freezer,the fridge is at the right temp but the freezer has all of a sudden started to warm up? the fan is going round and blowing out cool air but not cold enough to...
all working fine now, i took everything out of the freezer and turnerd it off for an hour then i cleaned it out and hoovered round the back and swiched it back on and straight away it was blowing freezing cold air, its still going now so i think its ok! thanks.
Jul 05, 2008 | Refrigerators
Freezer doesn't get cold enough yet fridge section o.k.
pressure on your system is low may needs service or clean the condenser located on the back of the fridge that may help if not add some more gas to compensate the pressure
Jan 01, 2008 | Refrigerators
Refrigerators Logo
170 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
