Wtw4800xq4 sensing light flashing,lock light flashing, water fills to proper level then nothing. I replaced the lid switch and motor still nothing.
wagdom
  • 64 Answers
SOURCE: Unable to control water level
Some water may have got into the pressure switch. Remove the pressure switch and see if you can shake any water out. Make sure the cables go back on the correct terminals. make sure the tub is empty when you refit the pressure switch, so no water is allowed to enter the pressure tube
Posted on Oct 29, 2007
  • 207 Answers
SOURCE: My washer fills and doesn't
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Posted on Sep 13, 2011
Testimonial: "Thanks for the quick response. I will replace it tomorrow and let you know if it works."
richroth
  • 9472 Answers
SOURCE: whirpool cabrio wtw5500xw top load washer will not start lid light flashes then goes out and into flashing pause mode
You will need to replace the lid latch assembly. Here is the part to order.
Here is a video to show you how to replace the lid latch.
Posted on Nov 19, 2012
SOURCE: I have a wtw5600xw0 Whirlpool washer. When I press the start button the sensing light and lid lock lights turn on. Then after a few seconds the lid lock light goes off and the sensing light stays fl
Swich off the machine, try some WD40 on the door mechanism (on machine lock, not on the door) and open & shut for a minute or two. Then try the machine, spin only just to try.
Rate pl, if solved, or dont!
Source
Posted on Nov 27, 2012
eb_tabriz
SOURCE: Moffat clothes washer model EEV99430 capacity 2.5
It is the worst washer I ever owned.The best soulution is to get rid ot it!
Posted on Apr 06, 2013
Whirlpool he washer-lid lock light flashing and lid locked. reset by using start/pause/ lock button. start washer-light comes on/sensing begins light starts flashing again and washer stops operating
LID LOCK LIGHT STAYS ON NO START:
Usually either the lid lock mechanism, the lid lock actuator or the board is the culprit even a disconnected capacitor.
MACHINES SAIDS SENSING
When the START button is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer
will slowly spin the dry load to estimate the load size, and begin adding water. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been
added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
Try unplugging the cord a couple of times. See what happens then try going into diagnostic error codes, see what codes are shown. To pin point where the problem is. if you have no display to read the fault codes. Your main control board may be the issue.
Next, while in Manual diagnostics, try to get the unit to spin; if the motor hums for a split second and then shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors.
This is proof that the shifter/sensor actuator assembly is the issue because the optical sensor is not reading the motor speed.
I suggest unplug the washer and check the wire connections on the switch. If a meter is available then you can check the resistance (ohms) of the lock motor.
Note: After performing the manual test and the lid lock works perfectly, or at least as it is supposed to. You can eliminate that as the problem.If the lock worked in the manual test but doesn't in an actual cycle then I suspect the control board is at fault.
A safety feature found on front load washing machine is the door switch and the door lock and strike. On most models, the door switch must be closed and the door lock must be activated before the washer will start. The switch is normally located in the door frame of the washing machine, but may also be part of the door lock assembly. Inspect the strike to make sure that it engages the door lock assembly and that the door remains closed. To check the door switch for continuity with a multi-meter, you will need to disconnect the power and remove the front panel.
The lid switch on a top load washing machine is a safety device designed to prevent the motor circuit from operating when the lOn some models, the water inlet valve circuit is controlled as well. If the lid switch fails, the washer may not start. The lid switch is normally located beneath the main top with a projection on the lid or a pin attached to the lid that will actuate the switch when the lid is closed. Verify that the switch is being activated mechanically and that any levers or actuators are not damaged or sticking. If the switch is being activated but there is no power being supplied to the motor or water valve circuits, then the switch may be defective
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
God is good and that's why I give free advice.
Dec 26, 2016 | Whirlpool Washing Machines
Kenmore 11025102310 washer isnt working. I press the start button, and the sensing button lights up for just a second and there is a couple of minutes of a grinding type of noise but then nothing.
SENSING Page 5
When the START/PAUSE/Unlock Lid is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer will use short, slow spins to estimate the load size. These sensing spins may take 2 to 3 minutes before water is added to the load and you may hear the hum of these spins. If the sensing light is on, then washer is working properly. You will hear the motor turn the basket in short pulses to thoroughly wet the load. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: Avoid opening the lid during sensing. The sensing process will start over when the washer is restarted. The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
If there's no water, then Page 13
Washer won't run or fill, washer stops working, or wash light remains on (indicating that the washer was unable to fill appropriately)
Check for proper water supply.
Both hoses must be attached and have water flowing to
inlet valve.
Both hot and cold water faucets must be turned on.
Check that inlet valve screens have not become clogged.
Check for any kinks in inlet hoses, which can restrict water flow.
Or you have an inlet valve that is not working
Apr 29, 2016 | Kenmore Washing Machines
My Whirlpool Cabrio washer wtw555oxwo turns on, lid locks, then the lid lock light starts flashing and the machine does nothing. Just replaced the lid lock, but nothing has changed. Any suggestions?
adjust the lid lock switch?? seems to me that lid lock mech is not moving far enough to properly be sensed by switch
if machine is over 8 months old id suspect rust in lock arm as cause
Jul 22, 2015 | Whirlpool Washing Machines
Why won't my Maytag Brazos top loader washer, model mvwx600xw1 agitate or spin? Also, the lid lock light blinks once in awhile. Checked lid lock, still no spinning
my first suspicion is in the door lock switch if it goes bad u have no action in wash or spin, next I would first check the water pressure switch as it is the unit that sends the signal to the machine to start wash cycle? if the diaphram does not detect the proper level of pressure due to water level. it will just keep filling and overflow and never start wash cycle. als0 check the water inlet valve, lastly a bad clutch will not allow much in the way of a spin cycle but would not effect the wash cycle? a bad motor coupler on the other hand stops both wash and spin?
Mar 23, 2015 | Maytag Washing Machines
I have a Whirlpool Cbrio top load washer. it won't start it's cycle. Once it senses the load, the lock lid light flashes and it does nothing. can this be fixed?
I would say that the lock has failed. Either the lock itself or maybe the pin or latch that fits into it when you close the door may have cracked / broken. If the machine thinks the door / lid is still open, it wont let you start it.
Jan 03, 2015 | Whirlpool Washing Machines
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
Washer will not spin or agitate Washer will fil and pump water out motor will not come on Have replaced the motor and the lid switch After replacing the motor the washer worked ok for about 4 or 5...
This is sounding like either a timer or a water level switch problem. I would elimnate the water level switch first. Here is why..... You had to tip the unit to change the motor. Tipping the unit would ensure that the small tube that runs from the bottom (side) of the wash tub to the water level control pressure switch cavitated. Once this is clear the water level control was for a while able to sense proper water levels and the diaphragm inside the pressure switch cycled normally. If the sens line had a pin hole in it or the water level control pressure switch contacts have a problem it will present the symptom you currently have.
I cheat.... I hook up an equal sized tube to the water level pressure switch and add pressure and release pressure orally to force the pressure switch to work. (Automotive vacuum line works like a charm!) If it works by physically forcing it to work then the timer is fine. The Pressure switch is probably ok also. The sense tube running from the presure switch to the tub would be the problem. With all water removed... (drain hose lowered too to empty the machine) tip the unit again. Then see if it will fill and agitate on a small load. Also check to see if it spins. IF it agitates and spins... the sense line if most likely the problem. (pin hole chaffed etc)
There is still a remote possibility of the Timer causing the problem OR the contacts inside the water level pressure switch as the problem. If you can find the tech data sheet inside the console there should be a wiring diagram. Check the water level control for power in and out both with water level reached and empty. If the contacts are working on the water level control pressure switch... your probably looking at the timer as the problem.
Thanks for choosing FixYa,
Kelly
Aug 31, 2011 | GE Profile WPRE6150KWT Colossal Capacity...
Error FL
FL= Flood Condition
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for FL to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Note: Press STOP/CANCEL to clear display on all error codes
Causes of flood condition. Inlet valves stuck on, sediment in water level pressure tube, water pressure tubing vibrated off the switch. Bad switch (highly unlikely).
Other codes:
PF power failure
Er control lost settings during PF
LF Long fill Clogged inlet screens
CE Com error between motor and control
Ld Long drain Clogged/slow drain/pump
CA/CI Motor amping up
ob off balance load
Sr relay failure no control to motor
LS Lid switch no signal from lid switch, error occurs if the motor and control disagree as to the position of the lid switch. Usually means corosion is buit up in the switch and the motor knows the lid is shut but the control does not. Code appears when start button is pressed.
open lid= flashing display time If the lid is opened time remaining flashes in display. Close lid and press start to continue.
SL Suds Lock Current draw on motor is sensed by motor control and a suds lock is declared. The control trys 3 times to fix this by doing a mini cycle, SL is displayed if the unit was unable to correct the problem. This problem is caused by:
Bad pump
Extra heavy load
Excessive detergent
or Excessive suds/wrong stuff
Last summer me and my buddy Robert worked on a one of these and took some pix:
CALYPSO REPAIR MANUAL AND SOME PHOTOS
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 19, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
FL code on a Calypso Whirlpool washer
FL= Flood Condition
realize that the trio was due to an
for 30 secondson 30 seconds off untill the
stuck on, Sediment in water level pressure
tube.
Other codes:
PF power failure
ob off balance load
LS Lid switch no signal from lid switch, error occurs if the motor and control disagree as to the position of the lid switch. Usually means corosion is buit up in the switch and the motor knows the lid is shut but the control does not. Cose appears when start button is pressed.
SL Suds Lock Current draw on motor is sensed by motor control and a suds lock is declared The control trys 3 times to fix this by doing a mini cycle, SL is displayed if the unit was unable to correct the problem. This problem is caused by:
Bad pump
Extra heavy load
Excessive detergent
Feb 04, 2010 | Washing Machines
Washing Machines Logo
259 people viewed this question
Top Washing Machines Experts
