Question about Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
How much is a water valve assembly - Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
    Top Expert:
  • Jenn-Air Master
  • 35,645 Answers
Ask an appliance parts supplier or Jenn-Air.
Posted on Apr 18, 2014
Whirlpool duet 8E error code, what is the cause?
F8E0Steam valve failureCheck the water supply hoses for kinks. Check for a restricted screen in the water valves. Replace the steam valve if defective.
Steam valve
F8E1No water detectedMake sure that both water supply valves behind the washer are fully open. In winter, check the fill lines for freezing. Check the drain system for a siphon problem. If the water valve assembly is defective, replace it.
See the repair guide to fix it yourselfWater valve assembly
F8E2Dispenser failureThe dispenser can't move into position. Unplug the washer and check the mechanical linkage on the dispenser housing. Repair or replace any damaged dispenser parts.
Dispenser assembly parts
F8E3Overflow conditionUnplug the washer and, if the washer is overfilled, check the water valve assembly for proper shut-off of water flow. If the water valve assembly is defective, replace it. If the washer is empty when this error code appears, replace the water level pressure switch.
See the repair guide to fix it yourselfWater valve assembly, water level pressure switch
F8E4Low water flowThe flow meter detects a long fill time. Make sure that both water supply valves behind the washer are fully open. In winter, check the fill lines for freezing. Check the drain system for a siphon problem. If the water valve assembly is defective, replace it. If water flows normally, replace the flow meter.
See the repair guide to fix it yourselfWater valve assembly, flow meter
F9E1Long drainRemove excess suds; the washer can't drain excessively sudsy water. Check your house drain system for a clog. Check the drain hose for kinks or clogs. Replace the drain pump if defective. If the washer drains properly, replace the water level pressure switch because it isn't accurately detecting the water level.
See the repair guide to fix it yourselfDrain pump, water level pressure switch
Oct 16, 2016 | Whirlpool Washing Machines
Water full
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
please see the diagram attached, and test with VOM the part that is suspected. God bless you3a10238c-31de-45fe-a0e8-1cf960673779.gif2e2dc2e9-fdb9-4489-a42b-42c2dbe1e233.jpg
May 25, 2013 | Dishwashers
It's asking to check water and won't start to wash
Guessing the water system is turned on and all velve open. There is an electic water inlet valve on the dishwasher, thet maybe clogged from sand in your water supply. The valve is located where the water enters the dishwasher on the buttom, the valve has a strainer filter that gets clogged sometimes. (if your not on a city water system this is a common problem) You will need to turn the power off to the dishwasher, and remove the inlet valve assembly(blue in color some machines) when you get the valve assembly out remove the inlet, and outlet hoses form it, check the inlet orafose for sand etc, and clean this in warm soapy water, even let it soak in a pan for a while. re assemble in reverse order, see if you get water into the dishwasher when you get it re-assembled and powered up.
Nov 06, 2012 | Dishwashers
Water not entering washer
Hi
If the washer won't fill you'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 03, 2011 | Maytag Bravos MTW6600T Top Load Washer
My whirlpool duet washer fills with water when not in use. How do I replace the water valve...is this the best solution?
Yes, replacing the valve assembly is the best solution to your problem. You should do it as soon as possible to avoid a flooding condition. It's pretty easy... the valve assembly is a single component that can be easy removed / replaced using simple tools. Here's how:
1. UNPLUG THE WASHING MACHINE AND TURN OFF BOTH OF YOUR WATER VALVES
2. Remove the top from the washer by removing the (3) screws from the rear face and pulling the top backward and slightly upward.
3. Unhook the electrical connections and hoses from the valve assembly
4. Remove the valve assembly by removing the (1-2) screws holding it in.
5. Buy a new valve assembly at your local appliance repair shop.
6. Reverse the removal instructions to assemble.
Good luck and happy washing!
Feb 11, 2011 | Washing Machines
The electronic cold water inlet valves at the top of the machine are leaking. My manual does not list the part and i need to replace it. I dont know the correct part name or number
Water Inlet Valve Replacement Procedure
Cold water inlet valve assembly: Part # 5221ER1003A
Hot water inlet valve: Part # 5220FR2006H
  1. Safety first. Unplug the machine.
  2. Close the water supply valve.
  3. Remove the cold water fill hose and drain the residual water into a pan or bucket.
  4. Remove the two screws on the back of the top panel securing it to the cabinet.
  5. Slide the top panel to the back of the machine and lift it off the cabinet.
  6. Disconnect the wiring harness connectors from the valves. Mark the connectors to make sure you reconnect them to the right valve.
  7. Unscrew the valve assembly from the cabinet and pull it out.
  8. Loosen the hose clamps and remove the hoses from valve assembly.
  9. Connect the hoses to the new valve assembly. Reinstall the valve assembly and the top panel in reverse of the steps above.
  10. Reconnect the fill hose and open the water supply valve.
Jan 26, 2010 | LG WM-2277HW Front Load Washer
Tub completed cycle and wouldn't shut off the water
Is your machine a FAV6800A or FAV9800A? Can you confirm the Model Number and the first two digits Serial Number?
Does water flow into the machine with the 120VAC power plug pulled from the machine?
If it does you have a stuck water valve. If it doesn’t you could have a stuck pressure switch and I can walk you thru how to check in diag mode for that condition.
I know you are frustrated but with some basic troubleshooting we can determine if the issue is a stuck open Water Inlet Valve or a defective Pressure Switch. Because this board doesn’t ask for the Model Number or Serial Number we need to start there.
Here is where the Model and Serial number info is located on the back of your machine.
Jan 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water drips into the bin after spin cycle
It sounds like the cold inlet valve is sticking.
The only solution would be to replace the inlet valve.
Jan 20, 2010 | Washing Machines
Water pooling in washer in between loads
The problem is caused by a leaking water inlet valve and the only way to solve it is by replacing the water inlet valve assembly. It is an easy "do-it-yourself" fix that only requires a minimum effort.
  1. Remove the three screws at the back of the machine holding the top cover.
  2. Slide the top cover to the back and lift it from the washer.
  3. Put a bucket or pan under the inlet valves.
  4. Remove the fill hoses from the machine and drain the water into the bucket or pan to avoid flooding your floor.
  5. Remove the screws holding the water inlet valve assembly to the back of the machine.
  6. Use a pair of pliers to press the spring clamp holding the inlet hose to the inlet valve assembly and move the spring clamp away.
  7. Install the new water inlet valve assembly and all other parts disassembled in reverse order of the procedure above.
  8. Make sure to clean the fill hose filters, if there's any, before attaching it to the water inlet valve assembly.
Jan 20, 2010 | Kenmore Elite 45986 Front Load Washer
Water will not stop running
Hi, there is a water pressure sensor located on the water valve assembly. this sensor is malfunctioning. i would make sure that the water valve Assembly's wire connectors are not corroded and the wires are attached. if the wires are ok and the contacts are not corroded, replace the water valve assembly.
Please rate and god bless:)
Apr 16, 2009 | Washing Machines
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator Logo
44 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
