Question about Panasonic VIERA Televison & Video
TV cuts back off after I turn it on
Then I have to unplug it, re-plug and turn it back on. Sometimes I have to do this a couple of times before it will stay on. I switched the locations of the Panasonic and an old Hitachi from bedroom to living room. The Hitachi has never had that problem in either spot.
    Top Expert:
  • Panasonic Master
  • 74,251 Answers
It sounds that the start voltage to SMPS [Main power supply regulator board] has some problem. It should be checked. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Posted on Apr 18, 2014
  • 718 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
  • 44 Answers
SOURCE: Philips 42 inch HDTV - "FlatTV" Plasma -- does not turn on.
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
SOURCE: My 42HDS69 Hitachi has a recurring problem of not
MY TV KEPT GETTING WORSE EACH DAY ALSO. BUY A CAN OF SPRAY AIR WITH THE EXTENSION SPRAY TUBE. WHEN YOU GET THE TV RUNNING SPRAY THROUGH THE HOLES IN THE BACK RIGHT ONTO THE FAN BLADES OF BOTH FANS. THE DUST WILL FLY OFF THE BLADES. A VACUMM HOSE WILL HELP PULL OUT THE DUST. ALSO SRAY THE POWER SUPPLY BOARD FOR DUST. I APPEARS THE FANS SLOW DOWN WITH DIRT ON THEM AND THE EXTRA HEAT BUILD UP JUST AFTER THE TV IS SHUT DOWN IS CAUSING THE POWER SUPPLY TO BE IN A SHUT DOWN MODE WHEN POWERED UP THE NEXT TIME. BEEN TWO WEEKS NOW AND WORKS PERFECTLY NOW AGAIN.
Posted on Feb 11, 2010
SOURCE: TV looses picture and sound. Will not turn back on
www.plasma-television-repair.com/Sample-Preview-Plasma-Tv-Repair-Training-Manual.pdf -
Above is a training manual, this should help you find and fix the problem if you wish to DIY. If you DO, decide to DIY, you MUST MUST get a Service Manual, for your exact make & model. it will be similar to the Training manual, but explicitly for your set. I do not recommend it however.In my professional opinion, you should contact Vizio and ask for an approved local service center, then, get a "Quote" for repair.
With faults such as this, it is important to leave them disconnected from the wall, as it is entirely possible, for a faulty, TV, to cause a fire, an explosion, or both. Anytime one hears any sort of "pop" similar or not, is grave cause for concern, as usually this means some sort of component failure, in a high voltage area.
Posted on Apr 29, 2010
SOURCE: TV turns off by itself & won't turn back on til unplugged, then plugged back in
panasonic 50" th50 turned off and wiil not turn on again.
Posted on Sep 08, 2010
Hi, I have a Sony KDL-46XBR9 LCD Digital Color TV. This morning my son was watching cartoons and it clicked itself off. It has sometimes done this in the past, so we did something else for a couple of...
This tv have a power supply board is the causes and the problems.Ur tv power supply board finally gave out and not supply the right voltages to the tv system anymore.That the board,where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 06, 2010 | Televison & Video
My Tv won't come out of standby mode. When I try to turn it on, it blinks a couple of times and cut right back off. I've tried unplugging it and replugging it in different sockets, but to no avail. This is...
Try the tv unplug,replug it back about an hour.See,if the tv reset itself.It should work,not than the power supply board have problems.That the board,that where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Aug 27, 2010 | Emerson LC195EMX 19 in. TV
Tv turns off on its own. power light now blinking red, tv not on
Unplug,replug,push the popwer buton couples time,see if stable green LED light,should get tv pic& suond back, not replaced the backlight video board it some how die.
Nov 26, 2009 | Televison & Video
Tv just cuts off and the power button blinks 5 times and stops
According to the service manual the lamp needs to be replaced.
Hope this helps,
Skyassoc
Jul 18, 2009 | RCA Scenium D40W20 40" Rear Projection...
TV turns itself off
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Dec 08, 2008 | Akai LCT3201TD 32 in. LCD Television
TV Pops & turns off
There are no tubes; generally the pop happens because of high voltage. It is being shorted out and the pop is either the flyback transformer or the horizontal transistor oscillator. these two are reponsible for creating the high voltage cycle for your television; when either of them or their circuitry is shorted out you hear that "pop" which is the emergency cut off circuitry coming into play to protect the rest of the television.
May 17, 2008 | RCA Televison & Video
Ws 65909
I had a half power outage where everything turned half off, how I still dont know. Anyways I unpluged it and didn't plug it back in until the next day. When I did the timer light was blinking for an hour. I unpluged it for a couple hours more, then I plugged it in and waited for 1 min, unplugged it and repeated, then I plugged it and unplugged it 3 or 4 times in a row, plugged it back in and waited. 1 min. then poof the tv worked. YAAAAAA HOOOOOO!!!!
Dec 30, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
323 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
