Question about Axis Communications Axis 216fd Network Video Camera/cam 0240-004 Gadget
Axis 216fd bad video - Axis Communications Axis 216fd Network Video Camera/cam 0240-004 Gadget
My wheeel is calibrating in the turning position
This problem is with axis touch panel in the internal side, seems like you turn it hard while playing game and the axis touch misaligned or damaged and it needs to open and repair.
Thanks
Sep 25, 2013 | Microsoft Wireless Racing Wheel for Xbox...
Bad disc
The disc is scatch up real bad or verry dirty, Then they will not work.
Nov 27, 2012 | Axis Planet Audio P9765B 7 Tft Motorized...
Find the equation of the hyperbola which satisfies the given equation center(1,-2) transverse axis to the x-axis transverse 6 and conjugate axis 12
I am not quite sure how the major axis of your hyperbola is directed and i do not know if the lengths you give are measures of the major and minor axes or the measures of the semi-major and semi-minor axes. So I am giving you the equations and the graphs so that you can decide for yourself what is appropriate for your problem.
Major axis parallel to the X-axis
Equation and graph
Center is at x=1 and y=-2, semi-major axis length is a=6, and semi-minor axis length is b=12
Major axis is parallel to the y-axis
Equation
Center is at x=1 and y=-2, semi-major axis length is a=12, and semi-minor axis length is b=6.
I trust you can customize the equations to fit your need.
Mar 24, 2011 | Office Equipment & Supplies
When we connect an Ethernet connection from the switch to the encoder, the net light goes orange. The switch end is green. It seems the encoder is transmitting, but it is not receiving. Is there a setting...
check the password make sure its exactly how you provided to your ISP internet service provider make sure the Caps lock is on/off which ever applies to your ISP contract
check your computers settings ie: firewall to allow your internet connection also your antivirus
check the leads from the router whether usb,ethernet make sure they are not bad/faulty and have secure connections and try different ports
hope this helps
Mar 18, 2011 | Axis Communications AXIS Q7404 VIDEO...
I need a power supply where can i get one
Your product takes a 7 volt ac power adapter. Those sort of adapters can be picked up at any local store, like Best Buy, Circuit City, or Fry's Electronics.
If your still having problems, please comment on this.
Thanks,
Brandonmxb
Dec 12, 2009 | Axis Communications 10PK AXIS 2400 and...
Axis & Allies video game will not play on my computer? I'm running windows vista.
Is it an old game? If so, try right-clicking the icon and clicking run as administrator
Dec 02, 2009 | Video Game Consoles & Games
The x-axis on my x52 flight control system doesn't work
try runing the install new hardware wizard then try and redownload all your drivers.
Jul 31, 2009 | Saitek X52 Flight Control System
Xerox Workcentre c2424 Error Code "37,030.48"
Hi Ian_a_nicol:
error code # 37,030.48 means X-axis motor disconnect. The X-axis motor (second phase) is not drawing the expected power from the power supply. you can do the following to determin if the X-axis motor is bad.
1. Run the X-axis Drive test and if it passes
replace the electronics module, if not see #2.
2. Check the X-axis motor wiring for damage
or replace X-axis motor.
3. Call Xerox to have them come out and run the test and determin if it is the electronics module or the X-axis motor, but is one or the other.
pdouglasss
Oct 24, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Axis Communications Axis 216fd Network Video Camera/cam 0240-004 Gadget Logo
43 people viewed this question
Top Axis Communications Home Security Experts
Lawrence Oravetz
Are you an Axis Communications Home Security Expert? Answer questions, earn points and help others
