Question about Lanier Ld228c Ld232c Ld238c Copier Fuser Unit
Where is the used toner bottle located on a lanier ld232c copier
    Champion:
  • Lanier Expert
  • 208 Answers
Behind the front door, lower left. Just dump it and put it back
Posted on Dec 14, 2014
  • 990 Answers
SOURCE: Full Waste Toner Bottle in Lanier LD040
Hello sir; I believed you talking about LD045, am I right? In this model it doesn't have waste toner bottle, the only place you can clean is imaging transfer unit, after you cleanup the message will be disappear.
Posted on Apr 10, 2009
EmmettPinger
  • 63 Answers
SOURCE: lanier LW324 waste toner bottle full
Open the machine and to the right under the drum you should see the the black powder (toner) going down into container the right lower side  cover must come off. probably a service call will be needed
Posted on May 01, 2009
M2Tech1
  • 313 Answers
SOURCE: How do I clean the transfer belt on my Lanier
The transfer belts on these generaly cant be cleaned if you know how you can just remove the transfer belt unit and take the cleaning unit ou this is positioned on teh leaft hand side just under the belt at the top there is screw take this out then press the small brown lever and and pull teh unit out carefully make sure you press the lever in as jif you dont you can damage the belt..vac this out and wipe the blade with a soft dry cloth.. if you are savy with the machine the main area to clean is the alloy or chrome roller at the top.. you will have to take the belt off to clean this.. the id sensors read off this to get reg and colour calibration right so it coulld cause problems if this is dirty..let me know if this helps or if you need more info..Good Luck A
Posted on Jun 29, 2009
cartridgecon
SOURCE: How do I reolace the toner in a lanier 7313
It was very easy. I just had not seen the machine when I posted the question. Thanks
Posted on Jan 09, 2010
  • 903 Answers
SOURCE: How do i empty a waste toner bottle on a lanier
What kind of copier is it? On many of the Lanier color copiers, the waste toner bottle is located on the lower left side inside the front door.
Turn the copier off first. Pull the big front door open and turn the bottle with the oil to the left -- the waste toner bottle is the plastic gray tank behind that. Slide it out (carefully) and dump it in a plastic trash bag, then reinsert it.
If you have a different kind of copier, please specify the model and I'll tell you how to get to the waste toner bottle.
Posted on Jul 18, 2010
How do I adjust print margin in service mode
I figure it can be done on the computer settings for the printer.
Jul 16, 2015 | Lanier Ld228c Ld232c Ld238c Copier Fuser...
How to replace used toner bottle on an LD245 and where is it located on the machine?
No bottle, it is inside the transfer belt unit that hangs on the inside of the right hand door. Dump it and put it back.
Jun 24, 2014 | Lanier Ld345 Ld335 Ld245 Ld235 Ld145 Upper...
Full waste toner bottle Lanier LD540C
The boys at the office figured out how to get out and empty... Thanks for all your input... I had sent it on to them.
Jan 21, 2013 | Lanier Office Equipment & Supplies
Can you please tell us where the waster toner bottle is located on a lanier 2145; can't find it anywhere
Hello!
I suppose that it is a printer.
In this printer the toner waste goes to the Transfer Unit.
Open the right door and you will see the trasfer unit. You have to take it out and open it. Then just empty it to a bag.
Take a look at this picture
Jul 21, 2011 | Lanier 1205 Copier
Lanier 6720 U14 error on screen
U14 is a user code for waste toner full.
Open front cover and you will see a clear plastic bottle at the bottom of the machine; lift this out and dispose carefully of waste toner (do not reuse). When fitting back into machine, make sure that inside of bottle is clean as the detection sensor looks through the bottle to see if it is empty and if toner is covering inside of bottle, the message will remain.
Apr 20, 2010 | Lanier 5235 Printer
How do i empty a waste toner bottle on a lanier color copier
Feb 25, 2010 | Lanier 1205 Copier
Lanier LW324 waste toner bottle full
Apr 20, 2009 | Lanier Office Equipment & Supplies
Apr 10, 2009 | Lanier Office Equipment & Supplies
Copier
good day, it wont print, coz you must pul the waste toner out. and replace a new waste box.
Jul 21, 2008 | Ricoh FT5832 Copier
Lanier 7320 - Makes only all black copies
Was the toner bottle removed before you moved the machine?
Jun 09, 2008 | Office Equipment & Supplies
Lanier Ld228c Ld232c Ld238c Copier Fuser Unit Logo
60 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
