Question about Vehicle Parts & Accessories
Hatch on 2002 vw beetle wont open, with door button or key fob. I have switched the gas tank and the hatch components that are inside the door panel and it did nothing. My gas lid opens fine and the locks (well driver side) work fine. There is no noise coming from anywhere. I have removed the only two screws in the panel under the rear window but have no idea how to remove the two rectangle rubber things that are a few inches from the window. I think I'm headed in the right direction, but don't know where to go from here.
  • 840 Answers
SOURCE: passenger door on 04 beetle
if you can open the door its the lock actuator from handle to lock that may be off need to pull off the door trim panel /please rrate my response thank you very much
Posted on Feb 02, 2009
  • 17 Answers
SOURCE: Remote key & AutoDoor opens/closes driver side, not other doors.
try the door relay
Posted on Jul 30, 2009
  • 6468 Answers
SOURCE: trunk (rear lid) wont open 2001 2.0 beetle
look for a round plug on the cover remove the plug and you will see a lever inside to push
Posted on Aug 23, 2012
  • 499 Answers
SOURCE: Does any one know how to remove the extended cab chevy 2010 rear door panel
remove the screw from the bottom of the handle then twist the handle off . next remove the small square cover that was behind the handle . there will be a screw , which you need to remove . remove any other screws in the panel and it should pop off .
Posted on Feb 14, 2014
SOURCE: Power Door Locks - 1996 Honda Accord Wagon - Rear Hatch
I had the same problem. A weather mat got stuck when the hatch closed. After freeing the mat, the hatch would not open. The lock button would go up and down, but the hatch stayed locked.
What happened was the the plastic holder for the metal arm that connected the lock button to the mechanism broke.
There are no screws holding the inside panel, just metal tab clips.
First, I took off the inside close handle--2 bolts. Then I had to work my way from the center tail light, unscrewing it and popping off the left and right trim pieces--metal tab clips. These were covering the back panel. Now the hard part was getting the back panel off. It does pop off and I found it very hard to get something behind the edges.
The plastic holder that held the metal connector in place had broke. I used two plastic pull ties to hold the connector in it's place. Reversed the procedure and it works again.
Posted on Apr 10, 2014
Where is the inside trunk release on a 2000 vw beetle. Trunk lid will not open with key, fob, or door release.
Trunk won open even with manual release there is good info here C24OF
Dec 21, 2016 | 2000 Volkswagen Beetle
Jeep door wont open with the key
Make sure you have the right key. Check and see if it works in another door or the rear hatch. If it works you could have something rusted or sticking. Does it go all the way in? Will it turn freely both ways? If so then something could be broken inside. If it does not go all the way in or sticks try spraying some WD40 or rust out, or penetrating oil into the key slot. If that does still not work you will have to take the inside door panel off. Hope this helps.
Jul 11, 2015 | 2006 Jeep Grand Cherokee
Locked trunk
The release contact switch must be dirty and will have to jiggle the rear hatch...when trying to open again...when open spray the hold down bracket, and the under side of the hatch that makes contact...the best spray for this is PB Blaster, available at Walmart auto parts section...this will not hurt the electric you still cannot open the rear hatch, you will need to remove the inside panel of the rear hatch to expose the release arm on the inside of the hatch. Hope this helps.
Mar 24, 2014 | 2006 Saturn Vue
01 vw beetle.battery died.recharged now remote wont lock or unlock doors.lights flash,switch inside works????????
You need to reprogram your key to the car. Also you have to reset the electric windows by putting them fully down..hold button for 5 sec...put fully up and hold for 5 sec.
I cant, of hand recall the reset for the key fob, but i dont think it needs a diagnostic tool, just a procedure.
check out the vw forums...bound to be in there.
Mar 07, 2014 | Bosch 01 Vw Beetle 1.8lt Turbo Mt Ecu Ecm...
Vw polo key fob locks all doors but will not open them have to do it manually any suggestion thanks
Press unlock 1 second
Manually lock/unlock,should reset.
Make sure all doors/hatch are closed
Dec 31, 2009 | 2004 Volkswagen New Beetle Convertible
Where is the release lever for the gas lid on a 2000 vw beetle. i can't find it in the trunk.
Its not in the trunk,Its either in the glove box or on the floor left side of drivers seat
Jul 06, 2009 | 2000 Volkswagen Beetle
VW Beetle door won't open
2002 VW Beetle doors wont open from outside after changing battery
Dec 08, 2008 | 2002 Volkswagen Beetle Turbo S
Electrical problems with trunk gas door and ac
the first problem with you fuel door is most likely the rear actuating motor or cable. remove the right rear trunk lining, and loosen the 2 silver phillips head screws, and remove the actuating motor. i would suggest replacing both the motor and the cable, as both of these parts have superceeded to a new improved part. the AC problem is caused by a faulty fan control unit. this part not only receives the switch signal and processes the information to control the compressor, but also controls the fans, their speed, the compressor,and the hi/lo pressure switch. both of these parts a a common problem for the beetle.
Jul 04, 2008 | 2000 Volkswagen Jetta TDI
Vehicle Parts & Accessories Logo
78 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
