Question about Sharp LC70LE732U AQUOS 70 LE732 LED HDTV
My Sharp LC-70LE732U has had 3 failures of the LCD Panel Control Unit. What may be causing this?
The board has been replaced twice. After receiving the TV just before Xmas 2013 and plugging it in, all I got was the flashing 2 slow 5 quick sequence. The board was replaced. The TV worked for a short while and the same thing happened again. The board was replaced again. The TV worked for about 2 weeks and died again....same flashing sequence on turning on the TV last week.
    Sergeant:
  • 181 Answers
Hello. To me, it sounds like a factory misshap of a internal grounding conection.
Posted on Apr 18, 2014
    Top Expert:
  • Sharp Master
  • 74,106 Answers
Have you checked the output voltages that comes out from its main power regulator board [SMPS]? If the voltage comes out of it is abnormal (grater than normal); this kind of failure can occur. Contact any service technician, to check it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magzine" will make surf easy Pull up older posts. Surf the site with patience.
  • 33 Answers
SOURCE: Set up only visible for 2 seconds, then black - Aquous lc-37d43u
Unfortunately I can promise you that you CANNOT repair this. Your power and opc lights coming on, but the tv is not coming on. That is a issue within the tv. Give sharp a call and they will have somebody come fix your tv free of charge, if they cant fix it, they will replace it for free. That is the only thing you can do. Sorry bro
Posted on Dec 12, 2008
dsacco86
  • 1077 Answers
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Posted on Jun 03, 2009
  • 8457 Answers
SOURCE: Cracked Sharp LC-46D62U lcd panel.
look up your local repairman they should have part.The part it should cost about $150,labor must ask.
Posted on Jul 01, 2009
circuitworld
  • 335 Answers
SOURCE: Sharp LC-37SH12U LCD TV is 20 months old and would not power on
Your power supply unit needs servicing on some part replacements. bad capacitors, voltage regulators, hi-watt resistors,....etc
Posted on Nov 03, 2009
  • 148 Answers
SOURCE: Sharp Aquos LC30HV4U stopped working
You are in luck!..The units poowerboard is overheating and since you have it taken apart already this is the fix for you!...Check the popped capacitors in the metal box you find on the back of the actual screen inside the unit...This is a very common problem,m so I've helped many this way and wrote a general post on the how to's of diagnosing and repairing the problem, follow these steps and your tv ill be good as new for less than $5.00 before feb 5 th!! :P...Here it goes (please rate if this works out :D).....................The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
If this has helped anyone (or not) then please rate, thank you!
Posted on Feb 03, 2010
Sharp model lc-70le732u no power
Power supply blown strip the tv it's the Capps follow the power cable in the back of the tv to the power supply you will c the Capps will be popped up 1000 uf ans some 250 if 16 v just change them
Aug 27, 2016 | Sharp Televison & Video
Snowey on scrreen
I've been repairing TV's for over 15 years and I would say either a bad Tcon's or main board issue. Theirs no need to replace capacitors these days, you can get the main board from $40-60.
Have you tried using different devices on the unit? If your getting a snowy picture on a satellite receiver, check with your provider for troubleshooting guide their unit. Or let me know the provider and I can lead in you right direction.
Thanks,
Jason
Jun 09, 2016 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Why won't my tv turn on?
Check Mains Cord is ok
Checked power supply board . Replaced Power supply Board
Dec 16, 2015 | Sharp AQUOS LC-70LE732U 70" 1080p LED-LCD...
I have a Sharp Aquos lc-52d64u TV that wont stay powered on.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 07, 2015 | Sharp 52"" aquos lc-52d64u 1080p...
What is causing vertical colored lines on the left 25% of my Sharp Aquos display?
Bad TCON board or Damaged screen. You can try and replace the TCON "Timing Control Board" and see if that helps. Replacing the Screen itself is very expensive and normally about half of what the unit cost new. Here is a video to give you a clue on how to do so, it is pretty easy when you know which board to replace.
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Jan 01, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp lc-60le650u blink codes
Different model number in the link below but I would assume they're the same fault.
(D_POW. Digital 3.3V failure. Power failure details (Flashes slowly twice and flashes fast 3 times. > DET_D3V3(36pin) failure (L). Digital 3.3V is not applied. If error is detected during start-up or operation, the power is turned on again by polling.)
Electro help SHARP LC 40LE810UN LC46LE810UN LC52LE810UN LC60LE810UN HOW TO...
Apr 02, 2014 | Sharp Televison & Video
1/4 of my sharp aqous tv has lines in it
This lines are in colors or black vertical lining in shaping?Yes?These lines are not causes by u or causes by an object by using forces hitting the LCD screen panel itself to causes these problems?Yes than the LCD screen panel are dying and leaking radiation can't be repair only by replacing new LCD screen panel not worth replacing and reparing if require a new LCD screen panel only.If these vertical lines are in colors or black are showing up and causes by the tv itself?Yes.Than the tv have a dying board that call the T-CON board and this board only job are docoding any pictures pixels before it showing up to the tv LCD screen panel.This T-CON board sit at the bottom in the middle of the tv LCD screen panel.Tries websites like Shopjmmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Aug 26, 2011 | Sharp LC-52D62U 52 in. LCD HDTV
Sharp LC -46SB54U will not turn on. The green power light flashes twice, then the green power light and green OPC light flash once together. This pattern then repeats itself over an over again. The tv is...
Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Do take care.....
Jun 16, 2011 | Sharp LC46SB54U 46 in. LCD TV
My Sharp LC-46D62U, power light and OPC light flashes twice, stops flaskes twice, stops and so on. I have read it is the power supply. Can i replace this myself?
Fault protection mode.... More than likely you have blown Uf Caps on the PSB-Power supply board. Recap with new Uf caps. A few bucks, solder and a soldering iron.
Jun 14, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Jun 03, 2009 | Sharp LC-26D43U Television
Sharp LC70LE732U AQUOS 70 LE732 LED HDTV Logo
52 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
