Question about Proform Crosswalk 395 Treadmill
I have 395 crosswalk and i was walking and it just shut off
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Pro-Form Crosswalk 395 - Incline goes up and down with no tread movement. Calibration doesn't work - only on display.
test the main board, with the output voltage from board for input voltage motor. If there are NOT voltage the board is faulty.replace see the block diagram, how the main boad control about 80% of the machine motion.
God bless you
Posted on Oct 02, 2012
Proform crosswalk 395 keeps tripping circuit breakers
If it's happening as soon as you press start then you need a controller and a walking belt. If it's doing it after a few minutes of use then you need to replace your walking belt.
Jun 27, 2017 | Proform Exercise & Fitness
Only work incline run only when I push star and up and put the key but when I push down no down is complet stop
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience...
http://electro-medical.blogspot.com/
Mar 17, 2016 | Proform Crosswalk 395 Treadmill
Belt keeps sliding from side to side
You have not properly aligned and / or adjusted the tension. If it is SLIDING then you do not have enough Rear Tension. Once you get the right amount of REAR TENSION, then you have to adjust the left right (balance the belt). Your belt should go straight, right now you have it too far to the FRAYED SIDE. Turn the Machine on, have your Hex Wrench in the Bolt and turn it slowly CW and as the belt come back to Center, watch the adjustment. If it continues to go past, then loosen it a little until you have the right balance. Remember REAR TENSION FIRST... THEN BALANCE for Alignment
Mar 03, 2014 | Proform Crosswalk 395 Treadmill
Knocking noise when machine running
see the video and fix it. This happen because the lack of maintenance according to the schedule. God bless you
Apr 03, 2013 | Proform Crosswalk 395 Treadmill
How do I disable preset workout programmed into Pro-Form Crosswalk 395?
you have problem for LACK of maintenance. LUBE inmediately the DECK BELT, this happen by that reason, The treadmills shut down for to protect the electronic system. Maybe you have worn deck belt.
2) LUBE THE rollers bearing TOO.
3) measure the input voltage motor, if there are the motor need repair.
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the diagram. God bless you
see the video.
Oct 12, 2012 | Exercise & Fitness
God bless you
Sep 29, 2012 | Proform Crosswalk 395 Treadmill
Incline keeps going up and down
Run the software calibration for diagnose, troubleshooting, and fix it.
sincerely. God bless you
Apr 23, 2012 | Proform Crosswalk 395 Treadmill
Broken walking belt
Here is a place to buy a new walking belt for the Crosswalk 500 treadmill. Unfortunately they are not too cheap but compared to the price of buying a new treadmill they are not too bad. I also recommend tacking on the Silk Stick lube kit which through regular maintenance can help lengthen the life of your treadbelt to reduce the chance that you will need to replace the belt again in the near future.
Sep 06, 2011 | Proform Crosswalk 500 Treadmill
Proform Crosswalk 395 Treadmill Logo
59 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
