Question about Kenmore 91495 Compact Refrigerator
Kemore compact refrigerator
Kenmore Compact Refrigerator model 564.9149910 (4.9 CF) is freezing everything inside, regardless of the temp control. It's a no freezer compartment unit which mean I don't have to defrost. It's great and lasted me 15 years. Do they make this Kemore compact Frig any more? Or should I try to get it fix or will this problem still keep coming up again and again? Is it worth it to have a Sears Tech fix it: $130./tech, $150 for the part = $350/repair as compare to getting a new G.E. 5.9 CF for $349.00 but has a small non-defrost freezer compartment which means I'll have to defrost it every 2 months.
    Problem Solver:
  • 22 Answers
It sounds like the temperature control is inoperative. They aren't too hard to replace, and $150 seems high for a control, but If replacing it is not something you or a friend could do, then a new refrigerator seems like the best choice for you.
Nothing lasts forever, and if you have already got 15 years of service out of it, then it would be a bad gamble to put that much money in a repair. I'd buy a new one and sell your old one on Craigslist to someone willing to fix it. You may find that you can go a lot longer than two weeks between defrosts during drier parts of the year, and the 'fridge isn't going to care if you go a lot longer than you think is necessary between defrost cycles.
Posted on Apr 19, 2014
Testimonial: "Thanks for the solution. The feelings are mixed...pro/con...to get the compact frig fix or not. It's a Kenmore so I called Sears. I got a different quote: I found out it's a one time $95.00/service visit charge. Now that I know from you (before I didn't know) that it's the thermostat, the part is $39.99. With Sears parts, you have to KNOW WHAT PART IS MALFUNCTIONING to do it yourself without a service tech. My dad had GIRLS...so none of us girls married any handyman type husbands. I just went out and bought a G.E. compact frig through Home Depot, free delivery and the 5 year extended warranty for $110.00...comes out to be about $22./yr headache free for 5 years!!! But if I found this website earlier to inquired about the fix it solution, I might have just called Sears and get the thermostat repaired ($150.00 service charge & part) and keep the comp frig going for another 15 years. Yes, I do believe EVERYTHING LASTS forever (at least in MY lifetime) as long as there is a replacement part for it."
  • dougaz40 Apr 19, 2014
    I'l glad you found a comfortable solution to the problem. I have an opinion on extended warranties that I'll share, although it may not be for you. Over the decades, I have made it a policy to never purchase an extended warranty and have never regretted it. Many sources concur, that in the long run you are ahead by skipping them. For most products, the manufacturer's warranty will catch failures caused by defective components, manufacturer's errors, etc. Generally, once you get past the period of likely infant mortality failures, things remain steady until you enter the time when wear-out starts causing problems. Your extended warranty may catch an infant mortality failure outside the manufacturer's warranty, but probably it will have expired when things start wearing out. Recently, I have purchased extended warranties on expensive electronic items that are hard to repair, but I've never had a claim. If you have second thoughts about your extended warranty, but still would like some coverage, check the warranties at Square Trade on the web. You might be able to boost the warranty a bit beyond the mfr warranty to feel comfortable, and save a lot of $ in the process.
  • 110 Answers
SOURCE: Refrigerator freezing over
if you haveno control of the temp. it is the cold control t-stat that is bad, but first i would sett all controls to factory setting and allow to run for 24 hrs to confirm
Posted on Jun 01, 2008
SOURCE: Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Posted on Nov 05, 2008
mastatech
  • 478 Answers
SOURCE: compartment Divider on side by side refrigerator gets very hot
Clean the condenser coil underneath the dust bunnies keep the coil from cooling. What you feel is your elictir running away
Posted on Mar 14, 2009
  • 30 Answers
SOURCE: Crisper draws are freezing produce. Kenmore Trio 795.77562.600
If you can find the duct work behind the draws you might find an air control, if you have a contract with Sears - you can call them back, the part that was replaced has a Garn.T and or 30 days on service, when you ajust the temps it may sometime act up but has a default and will return to that. Cold air drops down. read the manual that came with the Refrig. Buying a service contract might be the best thing for piece of mind - Sears covers everything, even plactic and paint ( scratches). most everything is plastic in the refrigerators today and are very expensive, 3 doors allow more air into the unit then a 2 door because of the seal between the doors, just 2 pieces of rubber overlapping .
Act on this as fast as you can, 30 days on service goes fast and a service call runs about 75 dollars . Oh ! don't put wet veggies in draw and rap everything with Plastic wrap, veggies only least about 4 /5 days then become soft and lose taste and color.
Posted on Jul 15, 2009
  • 45 Answers
SOURCE: My Kenmore refrigerator defrost drain freezes over.
There is a heat probe kit available to help prevent the drain hole from freezing shut. Part # 819043.
Posted on Jan 29, 2010
Sanyo Mini Fridge Freezes Everything
For me I think you have a problem in Thermostat switch contact. Or the rotary switch was not in good contact point, better check it and if still the same, proceed to check your thermocouple if functioning.
Jul 22, 2013 | Sanyo 2.4 Cu. Ft. Compact Mid-Size...
Everything inside is frozen no matter what it is set at
The thermostat is very likely the cause in this case. Finding a model number like this example=> 362.154879 on the Compact Refrigerator will help you find the part number. Or unplug the refrigerator and disconnect the two wires on thermostat along with the mounting screws and then take the thermostat to a local refrigeration parts supplier. They can test and help you find a matching replacement thermostat, Hope this helps, Thanks Sea Breeze
Sep 25, 2011 | Kenmore 91365 Compact Refrigerator
I have a kenmore elite compact refrigerator model 5649149910 and everything inside is freezing on the lowest setting
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
May 07, 2011 | Kenmore Refrigerators
I Have a Kenmore compact refrigerator (No feezer) - everything freezes regardless of the setting - it there a reset button somewhere?
heatman101
Mar 16, 2011 | Kenmore Refrigerators
New kemore compact won't get cold, motor runs ok but won't turn off
If it's new (under 5 years of age) it is under factory warranty, if it's a sealed system failure. Bad compressor, refrigerant leaks, or restrictions in the connecting tubing.
Contact Sears with complete model and serial number.
Nov 08, 2009 | Kenmore Stainless Steel Compact...
My chefmate RS 06DR is freezing everything
temp should be38-40 degree F the tub is for ice maker
Aug 14, 2009 | U-Line 15R Compact Refrigerator
Refrigerator is warm on the inside
hello mam
if the refrigerator is not cooling we should check the freezing coolant in the compressor and if necessary that should be refilled.
Jul 13, 2009 | Danby Compact Refrigerator DCR-101W
Jun 01, 2008 | Kenmore Refrigerators
My fridge stays on and freezes everything inside
not a breathing room issue, if anything that would cause it to shut down and not cool at all, where you got just the opposite, it never shuts off. is it an electronic model, or is there a control knob you manullay turn to adjust temp
Feb 23, 2008 | Sanyo SR-4910M Compact Refrigerator
Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Dec 24, 2006 | Sanyo SR-3620 Compact Refrigerator
Kenmore 91495 Compact Refrigerator Logo
115 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
