Question about GE WDSR2080D Top Load Washer
Kingston m280 knob
I need the knob for a kingston m280 timer
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
Found it on Amazon for $6... Part number: WH01X10460
Amazon com General Electric WH01X10460 Control Knob Home Improvement
Posted on Apr 18, 2014
Is M280 radio defective, causing battery to drain?
Just remove fuse to radio to see if this circuit is the problem. You can pull fuses one at a time and use voltmeter to see which are drawing current. Could be bad diodes in alternator which can be tested at parts store.
Jun 09, 2015 | 2006 Hyundai Tucson
Need control knob timer dryer doesn't shut off
If you are stating that the timer knob never moves to the off position, then the timer is probably bad and needs replaced. If you can't turn the timer because the knob feels too loose then possibly the knob is just broken. Timer knobs usually just pull straight off so you can look at the back side and see if the plastic around the shaft hole is cracked.
May 11, 2015 | Whirlpool Dryers
The knob on my kenmore elite won't move the timer.
The knob itself turns the switch on . The skirt move the timer position. Try turning the skirt. You probably have a broken knob. On these the knob is held in place with a plastic rod inserted into it all the way. This spreads the tip and retains the knob. To get the knob off to yank out the skirt for a look see you need to pull that rod out a tad to release the knob. 88be11a.jpgThat shaft has a rounded end on it that spreads out and locks the knob on. Clever ain't it? These timers are cheaply made, if you cannot find fault with the knob or the skirt then you is gonna need a timer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 05, 2010 | Kenmore Washing Machines
Timer knob spins freely
check the back of your knob to see if there is a crack. where the shaft of the timer goes if so call the parts store and order a new knob. Will need your model number when you call them. If its not the knob then its your timer.
Oct 31, 2009 | Dishwashers
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Kenmore Series 80 Washer timer knob spins
Something in the timer came apart. Timer needs replaced. When in good working order, the timer should ONLY ever be turned clockwise..Reversing this could break it.
Mar 11, 2009 | Kenmore 24032\24036 Top Load Washer
Removal of the timer knob.
you have two different knobs to replace?..is it the water level knob or the timer knob?
if its the timer knob you need to remove, look underneath the timer and you will find a black plastic pin depressed at the middle. pull it slowly for about 1/4 of an inch.
then you can remove the knob in the front of the timer switch.
in putting it back, install the knob first in the timer and then depressed that black plastic pin to lock the knob.
be carefull not to pull the plastic pin all the way out. it would be very hard to put it back in.
cheers,
drcool
Aug 02, 2008 | Frigidaire GLWS1339CS Top Load Washer
Timer knob
some models you remove center cap on knob and pull pin out others you need to remove screws in console and lean in forward to acess rear of timer push knob in pull small pin in back of timer and then pull knob off
May 21, 2008 | Maytag Performa PAV3200
Sound through tv on M280 portabel dvd player
Do you have both video and audio cables connected? Yellow or S-Video cables are only for video, you also need to connect the red and white RCA connectors on player and TV for stereo sound.
If you have already done this, check the player's menu to see if there is a setting for external or auxiliary audio.
Jan 26, 2008 | Amphion Mediaworks M-280 Portable DVD...
GE WDSR2080D Top Load Washer Logo
321 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
