Question about Kenmore Refrigerators
How do i know if my water valve gone bad - Kenmore Refrigerators
  • 957 Answers
If the water inlet valve is bad u will not get water to the ice maker or water at the door. The first thing u should do is to check and see if u have water coming to the back of fridge. You can do this by turning the water off. then take the water line loose on back of fridge. find a bucket and hold the water line in bucket and turn water back on. the water should come with force if it is working correctly. if it does then I would replace the water inlet valve. also make sure that your water filter is not restricted. they need to be replaced every 6 mos. they do clog after that much time
Posted on Apr 19, 2014
I am getting a F20 code. I did the auto diagnostics and It says I am getting no hot water. What should I replace?
NO HOT WATER CHECK THE WATER INLET VALVE AS THE HOT COILS MAY HAVE GONE BAD U CAN CHECK FOR VOLTAGE AND FOR OHMS.. ALSO MORE LIKELY CHECK UR WATER TEMPERATURE SWITCH IT MAY HAVE GONE BAD , USE A METER FOR OHMS CHECK
MAY ALSO WANT TO CHECK UR THERMISTOR ON MODELS WHICH HAVE ONE
Jun 09, 2015 | Kenmore Elite HE5t Washer
How do I stop water running into pan after toilet has been flushed &refilled.
If there is water still running into the toilet bowl, there is a problem with your flapper or flush valve. The most common problem, and least expensive to fix, is the flapper has gone bad and is allowing water to escape past it. Replace the flapper and the water should stop running. If not, it is possible the flush valve or one of the seals holding it to the tank has gone bad and needs replaced. Try replacing the whole flush valve. They come in a kit that includes the valve, flapper, and seals.
Feb 26, 2015 | Home
Cold water valve not working
the selinoid has gone bad in ur valve
May 11, 2014 | Amana Washing Machines
How do i tell if my water pump has gone bad
If the water pump was bad, the engine would be over heating. If the engine temp is normal, then the heater core could be clogged or the valve that opens the water flow to the heater core is not opening. You should be able to see if the valve is opening.
Nov 26, 2013 | Cars & Trucks
Water dispenser not working and icemaker not making ice
Make sure you have water to your inlet valve. If you do shutoff water to valve and have valve tested. Chances are the valve has gone bad since both water dispencer and icemaker cant get water.If you have any questions or this does not cure your problem please reply.
Aug 01, 2011 | Hotpoint Refrigerators
Ice dispensor not working
Most likely reason water not dispensing out door 1) You can turn up the temp in the freezer to see if it thaws in a couple of days, 2) Turn on the dispenser light and leave it on, will thaw the line and keep it thawed, 3) the water tank is frozen in the fresh food side (you can defrost with a blow drier) 6) the fill valve went bad or plugged ( power to fill valve but not opening) ($50) 7) Micro switch went bad in the dispenser for the water side 8) Door switch bad 9) Install a heater kit to thaw the line and it will keep it thawed ($35) PN#1381601 10) You can replace the whole door if insulation gone bad in door ( $500 to $800) 11) a broken wire to the fill valve ( no power to fill valve ) 12) with GE refrigerator bad dispenser boards or control boards ($400 and $150) 13) plugged, faulty or incorrectly installed water filter let me know more about you problem and I can help..
Sep 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a Maytag RSW2400 Frig. I just replaced the Dual Water Valve kit.(12001415 kit) I have water going up the the back of the frig. but not into it.I tried to blow air through it but it seems to be...
Sep 26, 2009 | Refrigerators
Ice maker is not getting water supply but water dispenser works
the fill valve for the ice dispenser has gone bad there are two separate fill valves for the water dispencer and the ice maker
Sep 20, 2009 | Refrigerators
My water dispenser is running and will not stop.
Hi, There are 2 options that might be ha[[ening. Wither the water inlet valve has stuck open or the switch in the dispensor has gone bad.
Turn the water off to the inlet valve. Push the water dispenser button and see if you hear the inlet valve buzzing. Release the button and see if the valve stop buzzing. If the valve stops buzzing, the switch is ok. I hope this helps you. Please let me know if I can assist you later.
Vic
Jul 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
WATER TEMP CONTROL PROBLEM i have no cold cold wash rinse cycle,only hot cold and that rinses in hot
Hi, Sounds like the cold water side of the mixer valve has gone bad or has gotten plugged. Do you have cold water in the wash cycle?
Remove the hoses from the inlet valve and see if there is sand in the screens.
Please let me know if I can assist you further.
Vic
Jun 20, 2009 | Washing Machines
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
