Question about Olympus Eye-Trek FMD-700 (Black, Silver) Flat Panel LCD Monitor
Replacement arms One of the arms broke as I was putting it on (I have a wide head) and Im in need of a replacement arm. Where can I find one? Left side if I need to be exact.
0 characters
1 Points
How can I lower the wiper arms?
If the rest position, that is the position that you say is 2" high, is always the lowest the wiper arms go. By that I mean it definitely doesn't go any lower during wiper operation, then on some cars you can remove the wiper arm from the motor shaft and replace it slightly lower. May not be possible on your car, but I have done it on a previous car as the motor shaft is splined like a gear cog and allows for adjustment. Just make absolute certain that the wiper doesn't go too low as this will put undue pressure on the motor action when it is forced against the car body or windshield trim.
Jan 22, 2016 | Hyundai 2012 Sonata Hybrid w/ Leather...
Removing stand arm
Hi all
Thought I'd share this.Lenovo discontinued the excellent L1940P, which had a stand that allowed pivoting as well as tilting and height adjustment.
So I've bought a L1951P and mounted it onto a stand from Ergotron.
Problem: the Lenovo comes with a hinged arm extending below the bottom of the screen. The Lenovo-supplied stand fits on the end of this arm. How to remove this arm so that it doesn't get in the way of a VESA mounting?
Well, I called Lenovo tech support, and they know nothing beyond what's in the manual that I've read. They claim that this arm is an integral part of the case and can't be removed. Wrong. I really love it when the people I talk to in tech support are actually people who know more about their product than I do...
At the top of the arm is a cylindrical plastic cowling covering the arm hinge. Put the monitor down flat on its front (on a cloth is a good idea to prevent scratches), tilt the arm upwards away from the case, and use a pen-light to look into the gap under the arm. You'll see a little tab on each side, inside, which is part of the cowling and locks the cowling onto the main case.
Use a small flat-head screwdriver to gently push this tab outwards - if you can apply a little pressure away from the case (i.e. upwards, as the case is downwards at this point) as well, you'll see the cylindrical cowling come away from the case on that side. Repeat on the other side. Remove the cowling, and you can access the 3 bolts that hold the arm onto the case. Done!
on Nov 02, 2010 | Lenovo ThinkVision L1951p LCD display ...
Can I purchase a replacement stand for my chimei 222H monitor? If so where?
I have broken the mounting arm of my Chimei CMV 222H ...
Nov 12, 2012 - ... the mounting arm of my Chimei CMV 222H monitor, can you getreplacement arms? The locking mechanism - Chi Mei Corporation CMV-222H 22 inch LCD Monitor question. ... Video; Photos; Link; Replacement Parts. Add.
Repair Kit, Chimei CMV 221D, LCD Monitor, Capacitors ... > ... > Capacitors, Inc.
Dec 15, 2015 | Computer Monitors
How to install the wiper arm on an outlander sport
If you don't get a reply from someone who has one or knows it.
Look at the new one, most aftermarket arms have the same lock as the original. Most all are a standard.
There is usually a slot key that slides over to the arm shaft that locks onto the thin part of the arm so the wiper arm does not fall off.
You kinds of need a hook that can grab the key to pull it back so the arm can be lifted straight off the arm shaft.
Look carefully at the new one. Should be close to old one.
Mar 31, 2013 | Mitsubishi 2011 Outlander Sport SE
Hi my monitor has colored horizontal lines all over the screen i have tried checking all the connections change plus the lines are still there when the computer is not connected to...
This is bad news, the problem is the screen panel itself, replacing the display would exceed the price of a new monitor. It is far cheaper to buy new, than to try and fix a unit that will cost an arm and a leg.
Jan 23, 2011 | Dell E228WFP LCD Monitor
Strips of 2 inch wide black and white, running top to bottom
Definately a damaged screen, no way to fix it for less than the cost of a replacement screen sorry.
Jun 16, 2009 | Philips 200P4 (Silver/White) 20.1 in. Flat...
Acer Monitor, Model No. X223W -- I can't get the arm of the back of the monitor (the thing you stick the base into) in order to mount on a multiple monitor stand (quad)... Spoke with Acer Tech Suppoort and...
i have the same problem with the AL1717. After hours figuring it out, i found the solution.. if you slide off the cover holding the back arm, you will expose the screws holding the arm which you can screw off to take off the back arm....
the cover can easily slide off as it is only 'clicked' into place.... gently put your fingers on the cover apply some pressure to slide it out...
Dec 19, 2008 | Acer AL1717 17" LCD Monitor
How to remove the base from the monitor
For monitor or TV bases that have four clips, I found if two people each take two opposite clips, and use thumbs to push in the clips, we can pop the base off fairly easily. It is impossible with one person, since thumb and forefinger can't exert sufficient pressure on the clips.
Jul 18, 2007 | Acer AL1717 17" LCD Monitor
Olympus Eye-Trek FMD-700 (Black, Silver) Flat Panel LCD Monitor Logo
Top Olympus Computer Monitors Experts
William Alequin
Are you an Olympus Computer Monitor Expert? Answer questions, earn points and help others
