Question about Westinghouse Refrigerators
Where is the circuit board located in a westinghouse rs643 refrigerator
The light doesn't work where is the fuse located
  • 884 Answers
I don't believe the light has a separate fuse. Isn't there a switch that operates the light when the door is open? Check the contacts make when door opens
Posted on Apr 30, 2014
On a LG LSC26905TT need circuit board location to replace fuse
How do you know the fuse has blown if you haven't accessed the board? Check the mains incoming power first, and power to the compressor. The pcb is usually in the top above the door frame.
Apr 27, 2014 | LG LSC26905TT Side by Side Refrigerator
Replacing a fuse on a circuit board of a westinghouse rs643 refrigerator
as far as i know , there is no fuse on any board in rs643 models !!
Apr 18, 2014 | Westinghouse Refrigerators
The light is not working on my Westinghouse rs643 refrigerator,I have replaced the globe
Check the switch inside the door frame is being contacted when the door is closed, and opens when the door is open
Internal refrigerator light not working
Broken or burnt wire somewhere. You'll have to find it or hire someone who can
Nov 17, 2017 | Refrigerators
Does not cool on gas or 110 volt
Do you have any lights working on the front panel? If not most lower circuit boards have a small fuse on the circuit board. shut down ALL power before checking for the fuse.The lower board has both 115 volts as well as 12 volts. If the lights are working on the front panel then most likely the lower circuit board is faulty and will need to be replaced.
Mar 08, 2014 | Dometic RM2652 Refrigerator
I have a westinghouse sk32h240s. wont turn on and no amber light.
First try a new power cord for the TV. If that doesn't solve the problem, the power supply has failed. (Possibly one or more capacitors on the power supply board have failed. Alternatively, a fuse, zener diode or resistor that works as a fuse has failed) You will need to open the tv and inspect the power supply. Westinghouse TVs use a number of different boards. If you want to replace the entire power supply, you will need to note that exact part number on the label. ShopJimmy has refurbished and used power supplies for this model: http://www.shopjimmy.com/westinghouse-sk-32h240s . The used ones are from TVs that were damaged in shipping and thus have minimal use. http://www.partstore.com/Model/Westinghouse+Digital+Electroni/Westinghouse+Digital/SK32H240S/Other+Remotes.aspx also has replacement parts.
I hope this helps.
Oct 03, 2011 | Westinghouse SK-32H240S Television
Fthe tail light works but the brake light doesn't work, it probably is the module that has a circuit board. I have replaced it 2 or 3 times on my 2004 XL Envoy ... can I get a part number and location...
First let's determine which brake lights are not working. Does the high mounted brake light work? Do both left and right brake light not work? If none of the brake light work, the problem could be the brake light switch at the brake pedal OR fuse #12 in the underhood fuse panel.
If only the bake lights at the corner lamp assembly don't work, check fuse #34 in the rear fuse panel.
The module your are referring to is the circuit board located in each of the corner lamp assemblies, check on website www.compnine.com for the part number of this item. I don't believe this is your problem though.
Jul 25, 2011 | 2004 GMC Envoy
I have a westinghouse rs643 that is freezing in the fridge evan on the lowest setting ,could it be the thermostat.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 10, 2011 | Westinghouse Refrigerators
Westinghouse 33001 won't turn on power pack has green light could it be a fuse or a switch that needs to be reset?
The green light means the 5v standby circuit is working, yes it can be a fuse for the main power supply section that gets the control signal from the main board to turn on, so it can be the main power supply or the main control board.
Nov 03, 2009 | Westinghouse W33001 30 in. HD-Ready LCD...
Dometic rerigerator won't work on electric keeps blowing fuse on circuit board
Have you tried locating the connectors on circuit board for the AC (hydro) element and removing them from circuit board and see what happens when you turn it on hydro then? Follow them back from element if necessary. If fuse doesn't pop, then I'd suspect a shorted element and change the heating element. Double check fuse is correct amperage as well. If it's a 3 way fridge, make sure it's the AC element and not the 12 volt you remove.
Sep 03, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
