Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Water dispener only drips water
    Prodigy:
    An expert who has answered 500 questions.
  • Frigidaire Expert
  • 650 Answers
Thewre is a good chance your water filter is plugged and needs replacing.
Posted on May 17, 2014
  • 298 Answers
SOURCE: Water keeps dripping after it dispenses water thru the door
When you push the button, the CLICK you hear when the water flows is the Water delivery solenoid opening to let water thru, then snapping shut when U R done. The Spring is weak (prob wrong type, size, strength at factory) or the valve seal is cracked, torn, hardened or crushed.
Since all this is inside the door, you will either have to take it apart to see/fix/replace.
Quick fix: turn down the water pressure coming in(?)
Call Mr. Handyman to fix.
If under warranty - they might fix this for you for free
If this is a factory defect, there might be a recall in place for repair/replacement parts
Googlee both - Make/Model + Dripping Valve + Recall
Good Luck!
Posted on Jan 17, 2009
  • 1214 Answers
SOURCE: water dispenser dripping
The seat in the door valve has probably failed or has some trash in it.
Posted on Jan 20, 2009
woodchuck789
  • 4070 Answers
SOURCE: FRS25R4A side by side. Water drips from the water
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Posted on Sep 07, 2009
toolkits
  • 1099 Answers
SOURCE: water dripping insie the fridge
Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
Posted on Jul 28, 2010
aasc
  • 1606 Answers
SOURCE: Why is water dripping from bottom, near hinge on
Due to it being on the refrig side , it sounds like the water resevoir behind the lower crispers , has a hole it it . Remove the crispers and activate the water ,( with the refrig door open ) and look for leak . If so , the tank is easily replaceable .
Posted on Oct 05, 2010
What water pressure is required for a Kenmore Elite water dispener unit
Water valves require a pressure of 20# to 120# to operate. If you have a filter, make sure it's not restricting the water flow. The same goes for filters in reverse osmosis. It is not recommended to use to filtration systems. Finally, if your supply line comes from a line piercing valve, make sure the pierced hole is clear by closing and reopening the valve.
Aug 07, 2014 | Kenmore Refrigerators
Water dispenser drips sometimes after filling a cup with water. Does not happen every time. If not addressed, the drip continues indefinitely. To stop the drip, I use my index finger to give a good poke...
When water leaks from the dispenser like this it will be caused by a defective water control valve that will not shut properly when off. The leaking water is the same as a leaking faucet. The KSCS25IN uses a=> W10247725-Water Control Valve or HERE
Sea Breeze
Sep 24, 2013 | KitchenAid KSCS25IN Side by Side...
What is a Drip Irrigation System?
According to Wikipedia "Drip irrigation, also known as trickle irrigation or micro irrigation or localized irrigation, is an irrigation method that saves water and fertilizer by allowing water to drip slowly to the roots of plants, either onto the soil surface or directly onto the root zone, through a network of valves, pipes, tubing, and emitters. It is done through narrow tubes that deliver water directly to the base of the plant."
Sep 10, 2013 | Garden
How do i remove a drip pan from a kenmore refrigerator
The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
Instructions
Rear Access
1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
Front Access
4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
6 Pull the drip pan out from under the refrigerator.
Apr 20, 2012 | Kenmore Refrigerators
Water dispenser dripping...
May be you can. Just check if your drip tank is full and if it is forcing the overflow. If it is not that, check the opening to the drip tank and see if it is closed with ice or something similar. If it is not that bath, then i'm sorry but you have to turn off the water supply line.
Apr 22, 2010 | GE GSS25JFM Side by Side Refrigerator
Whirlpool side by side fridge. Water dripping from water dispens
Good day,
If it feeds normally, and then refuses to shut off completely, then the dual water valve in the back bottom of the refrigerator is failing and should be replaced ASAP. It could go wide open and create a real mess.
An option right now, is to shut the water off to the machine, until the valve replacement is complete.
That part is common and available at most appliance parts houses.
Thank you for using FixYa
Jan 08, 2010 | Refrigerators
Model KSRS25FGWH01-water is dripping inside the freezer ice bin.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Side by side dripping
There are several reasons why the dispener would dip. Do you have a filter on the unit and have recently replaced it. Then run a large pitcher or water through the dispenser to make sure all the air is out of the line. Anorther thing that could be happening it the water valve is not sealing properly and causing the dispenser to drip, In which case the valve should be replaced. One other odd problem is if the water tank somehow is not even and you have a little air bubble in it. Just some thinks for you to look for, hope one solves it.
Aug 31, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Dripping water dispencer
Dripping problem is from 2 sources.  Faulty water valve or faulty water connector behind refrigerator.  If the dripping is constant and doesn't seem to end, then it's a faulty water valve.  If the dripping stops after awhile, then the water connector is allowing air into the water line causing the dripping.  Have that connection checked to make sure that it's securely in place.
Nov 12, 2007 | LG LFD22860 Stainless Steel Bottom Freezer...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
