Question about Roketa 50 Scooters
The scooter wont idle. it runs good. off idle how to adjust the carb
2 Suggested Answers
gregg201
  • 48063 Answers
SOURCE: I had my 06 gy6 roketa 150cc scooter running good,shut it off n now can't get no fire...wont start...new carb,new plug! Any help?
Hi, Jim and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. A severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
13. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
14. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
15. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
16. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
17. Faulty neutral, clutch lever, or kickstand safety switch.
18. Faulty fuel pump or fuse or relay.
19. A stuck bent or burnt valve.
20. Tilt sensor needs a reset.
21. Security system not disarming alarm needs a reset.
22. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
engine cranks spark but still no start
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
MC04A1501
Roketa bali 150 Owner Manual
Posted on Mar 29, 2017
TGB 101S will not idle
Hi, Anonymous you may need to "DIP" the carb and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
13. Faulty auto choke or wiring connection.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
50cc Scooter Won stay running
HELP scooter wont stay running clean carb
TGB Service Manual 101S BH1 303R 50 BR1 Delivery 50 BK1 China scooter TGB TAPO Parts
Please Check First
Mar 25, 2018 | TGB Motorcycles
Yamaha Zuma 50/Cold Start Problem
Hi, James and the usual suspects are:
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
ZUMAFORUMS NET View topic 2005 yamaha zuma yw50t cold start issues
My Scooter wont start if engine is cold scooters
https://www.manualslib.com/manual/781192/Yamaha-Cw50l.html#product
OEM parts for Yamaha
Yamaha ZUMA CW50N Owner Manual
Jan 22, 2014 | 2012 Yamaha Zuma 50F
Scooter carb adjustment
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
Scooter Moped Carburetor Adjustment
How to tune carburetor in GY6 chinese scooter 150 or 50 cc
Scooter Carburetor Idle Adjust
GY6 Enricher Automatic Choke Operation Testing
150cc GY6 Carburetor
Jun 30, 2013 | Benelli Motorcycles
50cc Scooter won't rev up, Keihin PD18J carb
my 50cc scooter will idle at first and rev very well but wont idle what can this be
Jul 08, 2012 | Motorcycles
2008 Keeway Arn 125 high idle
Hi, W32twood and the usual suspects are:
1. Throttle cables improperly adjusted, pinched or need lubrication.
2. Idle adjusting screw needs to be backed off.
4. Air fuel mixture adjusted too lean start with 2 full turns.
5. Intake system air leak.
6. Fast idle choke ramp is not releasing.
7. Faulty automatic choke.
8. Broken throttle return spring.
9. Damaged diaphragm or slide.
10. Faulty MAP, TPS, ATS, O2, sensors or wiring/connector.
11. Multiple carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
think broke my scooter and it my only way of getting to work Please help...
gy6 carb for 150cc scooter engine
2006 Keeway ARN 125 150 Scooter Repair Manual Download Manuals Technical $22
http://www.family-motorsports.net/GY6-50cc-150cc.pdf free
Keeway Scooter Parts Racing Planet USA
http://absolutelyscooterparts.net/pdf/CGEN_dawg_scooter_manual.pdf
Dec 10, 2017 | 2008 Keeway Arn 125
I bought a scooter from Right Way Scooters and it
adjust your idle up slightly, should have a screw on side of carb, turn slowly til' idle is correct
Sep 12, 2009 | Factory bike Chrono SM 250 Motorcycles
Hyosun Scooter Carb Adjustments
Very good thought process on the adjustments. The throttle screw sets the idle speed and the air screw sets the fuel mix at idle speed. The stock setting is 1.5 turns outward. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward.
From this point you adjust the idle speed then adjust the air screw for fastest idle speed at that throttle screw setting. If the idle speed becomes faster than desired after adjustment, just reset the throttle screw and then reset the air screw.
A “very helpful” rating for this answer? Thanks!
Jun 27, 2009 | 2002 Hyosung Comet 125
2000 yamaha zuma scooter
hello, sounds like u need to clean carb, new plug
Aug 22, 2008 | Sport & Outdoor - Others
Roketa 50 Scooters Logo
26 people viewed this question
Top Roketa Computers & Internet Experts
David Payne
David Payne
Are you a Roketa Computer and Internet Expert? Answer questions, earn points and help others
