Question about HP Photosmart C5180 All-In-One InkJet Printer
Problema di bloccaggio HP C5180, errore inchiostro 0xc18a0107
HOLA!
YO TUVE EL MISMO PROBLEMA CON MI IMPRESORA HP PHOTOSMART C7180 ALL IN ONE ,,,,Y LO QUE HICE FUE LO SIGUIENTE:
1.-ESTANDO ENCENDIDA LA IMPRESORA, DESCONECTE EL CABLE POSTERIOR(EL DE ATRAS DE LA IMPRESORA)
2.-PRESIONE LA TECLA DE "OK" Y "AYUDA" AL MISMO TIEMPO COMO UN MINUTO
3.-VOLVI A CONECTAR EL CABLE POSTERIOR
4.- LUEGO PRENDI LA IMPRESORA
5.- CAPTURE LOS DATOS QUE ME PEDIA, POR EJEMPLO: IDIOMA ESPAñOL, PAIS MEXICO, ETC.
6.- Y EMPEZO A TRABAJAR CORRECTAMENTE
MUCHA SUERTE, ESPERO LES SIRVA ESTO QUE A MI SI ME FUNCIONO! SALUDOS REBE!
Posted on Aug 11, 2009
  • bkTek Jul 13, 2011
    For those of you that don't understand English, I have translated the steps...
    1. With the Printer on, disconnect the power cord from behind the printer.
    2. Press the "OK" and "HELP" keys at the same time and hold them for about 1 minute.
    3. Reconnect the power cable to the printer. ( I didn't release the keys when I reconnected the power. The display also flashed a code and then the printer shut off. I then released the keys before turning the printer back on. )
    4. Turn the printer back on.
    5. Enter any preferences you need like language, country, etc.
    6. Enjoy :)
    I hope this helps others as it has helped me.
  • 628 Answers
Se potresti comprendere inglese, leggi la seguente dal HP:
  1. Spegnere il stampante.
  2. Scollegare la spina dal dietro dello stampante.
  3. Tirare tutti i cartucci di inchiostro.
  4. Attendere 2 minuti.
  5. Collegare la spina di nuovo.
  6. Press the On button to turn the printer on.
  7. Installare i cartucci quando in panello ti avvisa.
Se non vedi piu' l'errore e' risolto. Se no, allora bisogna portarlo alla assitenza. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Posted on Jun 19, 2009
SmartBase MP360 appena avviata per qualche secondo fa rumore di pettine contro acciaio e non funziona
Questo rumore clunking / rettifica di solito ? un ingranaggio inceppato o una barra di controllo provocando qualcosa da cedere il passo (di solito l'elastico con i denti su di essa dietro la testa). Ho risolto i problemi simili su HP e Epson e ogni volta che ha bisogno di una striscia gi? e un attento esame delle lavorazioni. con Epsons di solito era un ingranaggio che aveva saltato un dente e poi la tempistica era fuori causando un inceppamento. Con polipi iperplastici, di solito un frammento di carta nelle opere o inchiostro schizzato su uno dei tanti sensori ottici, facendo accadere le cose nell'ordine sbagliato. Il mio MP360 inceppata con i capi in sosta (ma senza clunking). Ci? ? stato causato da inchiostro secco mescolato con polvere di rendere il meccanismo di pulizia pigro e (in qualche modo) jamming la testa. Ho preso le coperte per spegnere la stampante (un lavoro lento) e pulito tutto, ri-ingrassate. problema scomparso. Attualmente ho le teste ammollo in una miscela di alcool, detersivo liquido e acqua per sbloccare le teste di nuovo.
Jan 19, 2011 | Canon Office Equipment & Supplies
Ink system failure message on HP photosmart c5180 all in one
tengo una impresora photomart c5180 hp y me produce un error 0xc18a0107
Nov 07, 2009 | HP Photosmart C5180 All-In-One InkJet...
Hi no harm in trying I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 15, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error: 0xc18a0107 Printer HP C5180 All in One
I had the same problem for a few days.
Each time, I switched on my HP C5180 printer, the Oxc18a0107 message was displayed.
I tried the solution that I found on the net (power off, power on while holding on OK and HELP keys) unsuccessfully ...
Then I bought new ink cartridges and I put them after resetting the printer.
No more error message ... It works well now.
Abbesses
Apr 09, 2009 | HP Photosmart C5180 All-In-One InkJet...
JIRO
See if this helps to solve your issue, it is a link directly to the support page that speaks of this 0x...errors.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00489814&dlc=en&lc=en&jumpid=reg_R1002_USEN
It explains a way to possibly restore factory defaults on the unit. If unsuccessful they suggest to contact HP for further assistance.
Jul 07, 2008 | HP Photosmart C5180 All-In-One InkJet...
Boot password
how to fix printer hp photosmart c5180 has system error 0xc18a0107 help me please
Jun 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
1,202 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
