Question about Hotpoint Dishwashers
D55 hands free telephone
How do i check the hose from the pump
  • Sam Apr 24, 2014
    Hi george smith, I want to help you with your problem, but I need more information from you. Can you please provide the model number of dishwasher as D55 is a Panasonic telephone?
  • Hotpoint Master
  • 3,247 Answers
Assuming you have a typical Hotpoint dishwasher the instructions on how to open the pump unit to get access to hose can be found on this webpage
http://www.appliancerepair.net/dishwasher-repair-5.html
Posted on Apr 24, 2014
I am trying to format an excel cell to do this equation SUMIFS(D55:D56,D55>D56,"=(D56/D55)/100%",D55<D56,"=(D55/D56)/100%") How do I get it to work?
Looks like theres only one if . hopefully this equation is not in d55 or d56. maybe part of this got cut off but parens are also wrong. and quotes are unnecessary excel only writes whats in quotes out. also you cant really operate on two values in the same column. they need to be in separate rows or like you say things flip around
sum might be messing it up to maybe one cell does if and another does sum.
f55
=if(d55>e55,(e55/d55)*100,d55)
this reads if d55 greater than e55 then return the ratio of e55 to d55 as a precent else return d55 to the cell f55.
g55
=f55+e55
then sum the values in a seperate cell
Or if you want the sum in f55
=if(d55>e55,((e55/d55)*100)+e55,d55+e55)
or if eqn is cut off in question maybe its
=if(d55>e55,((e55/d55)*100)+e55,((d55/e55)*100)+d55)
anyway something like that should get you on track
Nov 15, 2016 | Cell Phones
What about 6301 hand free telephone set operating manual
Here you can download manuals for anything you insert in the right description:
http://www.manualsdrive.com/results.php
Apr 01, 2015 | Lands Phones
I have a 2003 trailblazer that is over heating and loosing antifreeze. The only place I can see where its coming out is the over flow hose on the resievor tank.
Check the reservior tank itself, can crack near bottom. One way to check is to rent or borrow a pressure pump for cooling systems, once pumped up bit, look around to see where it's leaking. Autozone lends these hand pumps for free.
Oct 25, 2013 | Power Acoustik PMD103CM 10.4" Flipdown...
I have a Maytag Neptune Model number: MAH5500BWW, Serial Number: 7491213324 and Style: Y7909216 It may have a clogged drain pump which may be clogged so I'm trying to check if it is. I have removed the...
check if there is anything inside the pump try to turn it by hand if its free check the inlet hose maybe clogged if not you need to check the power in the pump side if it is on and pump doesn't work you need to replace it by a new one
Oct 12, 2011 | Maytag Neptune MAH5500B Front Load Washer
LG Turbo Drum Dd WT R902 wont pump out water , I have unblocked it and if i put the hose on the ground the water gravity pumps out, but when i put the hose back up it stops, it will spin but not pump
did you take the hoses off both sides of the pump. turn the pump impeller to make sure it turns free. at radio shack you can get a meter for $15.00 to check for power to the pump if it's getting power and it spins free by hand replace it. if no power during drain time it's a bad wire to it or bad control board
Dec 31, 2009 | LG Washing Machines
Kenmore Washer Model #11082427800 Serial #C73934427
This is either a blocked drain pump/hose or the pump is stuck or broken,I would suggest that you first making sure the machine is off take the drain hose and lay it flat see if the water runs out freely if not then you can try blowing back into it to see if you can dislodge the obstruction/if this does not work you will need to locate the pump (remember there is wate rin the machine so switch off and unplug) whe you locate the pump then look for the drain hose clamp and remove the drain hose then look for a hose normally black that goes from the drum to the pump and remove the hose from the pump check the inside of the hose for any obstuction and clear if need be/then take note of the wiring and remove the pump check in the pump housing for obstuction and remove if any /if all this is done and no block is found then test the pump see if it turns freely by hand,if it does not then it is blocked or broken if it turns free reconnect to the machine and test if it still will not drain and you are sure that all the obstuctions are clear then replace it ..Let me know how you did thanks.
Dec 28, 2009 | Dryers
Motorola sm56speaker phone
If ur connected your telephone line by lan card pls check that link & speed selection.
Sep 03, 2007 | Computers & Internet
Dishwashers Logo
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
