Question about Frigidaire Refrigerators
Water only drips not enough water making litle ice
    Novelist:
  • 150 Answers
Start with replacing your water filter, Frigidaire water filters tend to reach their life's end much sooner than others, regardless if you have a filter reminder light, your filter can get dirtier faster depending on your water quality, the reminder light on the front dispenser is simply a timer and has no idea how dirty your water is. By pass plugs are also avail to take the place of water filters. Pleazer Appliance...
Posted on Apr 18, 2014
  • 42 Answers
SOURCE: ice maker makes ice, but also drips water
cbscarter,
This may sound strange but you will find that the mold coating is peeling off of the aluminum mold. This causes the water to wick (climb) the loose coating and up over the top, leaking out making an ice clump on the ice maker and clumps ice in the container together. It would be easy enough for the average person to replace the ice make. Due to its age that would be smarter to replace than to repair the old one. It is a Whirlpool part #4317943 and comes with some instructions.
If this helped please rate me good, supertechks
Posted on Nov 25, 2008
jonniewalker
  • 1029 Answers
SOURCE: Bosch Side by Side, top shelves dont freeze food, bottom does
majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3).
Posted on Mar 29, 2009
woobie dog
  • 1273 Answers
SOURCE: Freezer is too cold, ice crystals. Refriderator
I'm not sure which one you have, but try this: Look for the area where the air passes from the freezer to the refrigerator side, in the wall somewhere between them. Make sure that there isn't something blocking the passage. This is a good place to start.
Regards,--W/D
Posted on Jul 10, 2009
  • 358 Answers
SOURCE: ice maker dripping water fusing ice cubes
The dual water valve (solenoid) that open and let the water from the line when the ice maker calls for it, is leaking and needs to be replaced.
Posted on Aug 17, 2009
woodchuck789
  • 4070 Answers
SOURCE: Model KSRS25FGWH01-water is dripping inside the freezer ice bin.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Posted on Nov 16, 2009
Water dispenser only drip water and litle bit ice made
If this unit has a solenoid for the water and one for the ice maker, they could be malfunctioning or blocked. Check filter first (if it has one) then check where the water enters the unit. There should be one or two solenoids to allow water to flow to each dispencer. They emit a "click" sound when activated. If not they will be faulty.
Apr 18, 2014 | Refrigerators
No longer making ice
Hello, Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Thanks
Jul 12, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
My whirlpool model # ed2chqxkb05 is not making ice, we can still use the water in the door. its not making ice. Help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Is the freezer cold enough? Should be close to 10 degrees.
Dec 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker stopped making ice
Sep 10, 2009 | Refrigerators
I have a bottom drawer freezer Samsung refrigerator (Model: rb217abw) that is two months old. The ice maker fills with water and I can hear the mechanism drop the water into the ice bucket causing the...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze, blocking or diverting the water.. You can take the water line off the valve and watch to see if it drips.
Aug 25, 2009 | Refrigerators
Ice Maker isn't making ice.
Aug 22, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Aug 19, 2009 | Refrigerators
Under counter ice maker water pickup problem
Most likely your plastic curtain is not keeping the water in the sump area. ( I'm assuming it makes round cubes)? Look under the sump for any dripping if its a pretty steady drip replace your water curtain and the holder that's with it.
If you have a cutting grid type ice machine this is all together different and I need to tell you separately about that.
Jan 01, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Ice maker makes ice, but also drips water
cbscarter,
Oct 11, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
9 mo. old refrigerator will run water; will not make ice.
make sure your water filter is not clogged. Sounds like you are not getting enough water in the freeze tray. (assuning your freezer is cold enough--0 to 5 degrees.
Aug 13, 2007 | Whirlpool GD2SHGX Refrigerator
Refrigerators Logo
43 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
