Question about LG WM-2277HW Front Load Washer
Foam coming out of the back of machine - LG WM-2277HW Front Load Washer
  • 341 Answers
You nay have used too much soap! Try running the washer through a short wash cycle without any clothes or soap in it to rinse it out.
Posted on Apr 18, 2014
How to clean washing machine
Put the machine on a 90 degree wash with nothing in it, wait until it has filled and then pour three quarters of a cup of neat thick bleach into the soap drawer.
Put an old towel under the machine. The bleach will foam up and foam will come through the soap dispenser and all over the floor like a scene from a 1950's "The Blob" movie (The foam will also coat the entire inside of the machine as a result and kill any smelly bacteria).
Once the cycle has finished, throw 4 dishwasher tablets into the drum and put it onto ANOTHER 90 degree wash. At the end of these treatments, you should be a lot closer to a clean machine
Jan 30, 2016 | Bosch Washing Machines
How do I replace the foam padding in my ibm selectric ii typewriter?
The foam was used for sound dampening. Over time, the foam falls apart and can cause problems inside the machine. If it is coming off, we usually remove it with a razor blade. New foam is not available any more. Hope that answers your question.
Sep 01, 2012 | IBM Correcting Selectric Ii Typewriter
Breville Cafe roma milk does not foam
You need practice !
Rules of thumb :
1 - Use COLD MILK, did you ever try to make whipped cream with warm cream ? It's the same.
2 - Use a COLD RECIPIENT to put your milk in.
3 - Foam your milk AT LAST, extract your expresso before, so if you do a not so good foam it doesn't have time to deflate.
4 - If you put any condiment on the foam, it will drop fast, like nutmeg, cocoa or cinamon.
Technique :
a. Put whole milk in a cold stainless steel recipient.
b. Start the machine and let it go for couple of seconds, just to let the first dropplet of water to spat out. When you have a clean and steady jet of steam, it's ready.
c. Swiftly, insert the vapor tube in the milk, if you go too slow, the steam will blow milk everywhere.
d. Go deep in the milk, but don't touch the botttom.
e. Within 5 seconds go toward the surface of the milk carefully, avoiding the big bubbles sound, you are looking for a steady "pcchhhhhh" no grunting, no bubbles, no ear piercing sound. Everytime you loose it, plunge and come back to the surface, eventually you will find the sweet spot.
f. When you are in the sweet spot, keep in mind that the milk surface rise during the process and you have to follow it, so rise slowly, following the path of the foam/milk.
g. If you feel the pot becomming to hot for your finger, you have to stop, milk doesn't like to be heated that much.
h If you succeed you will have a whole pot of foam, the milk wont separate from the foam and when you pour it, it will be like a deep creamy soap foam.
Good luck,
JF
Sep 28, 2009 | Breville Coffee Makers & Espresso Machines
I only get foam after 4 Shots
The only thing that comes to mind is descaling. To me it seems that most of the boiler room is being lost to minerals, so there is less water in there. Try descaling the machine.
May 31, 2009 | La Pavoni Europiccola EPC-8 Espresso...
Can't get milk to foam
How long have you had the machine? Use a straight pin and poke the opening of the wand. It may be blocked. If the bottom of the wand can be removed, use some pliers, and CAREFULLY remove it, soak it in hot water. Rinse it thoroughly, and replace it back on the machine. If you cannot remove the wand, turn the machine upside down, and check the opening to the wand. It most likely is stopped up. Run vinegar and water through your machine once a week. Calcium build up does the same thing. Good luck! Happy Lattes!
Feb 05, 2009 | Cuisinart EM-200 Espresso Machine
Kenmore Front loader Washer Problems
u need to remove the shipping bolts, found in the back of the washer, 4 long bolts used to hold the drum in place while transporting. we had same prob
Nov 29, 2008 | Kenmore 44102 Front Load Washer
My dishwasher has been producing so much foam that it leaks out on to the floor. This has not happened before in the fifteen years we have had the machine. The detergent is the same so how do I stop the...
foam can only come from the detergent!! usual reason is that somebody has used washing up fluid - you may not have known. to get rid of the foam, put on a wash cycle and sprinkle some salt on the foam
Jul 21, 2008 | Zanussi Dishwashers
Kirby Ultimate G Series
Ok, I will try to explain this as well as I can. Please bear with me. Remove the dust bag, cover and all, from the machine. Attatch the shampoo tank to the part where the dust bag attatched on the machine (not on the handle). Remove all attatchments from the front of the machine, and attatch the shampoo foam "collector", ensuring that the belt is over the drive. Connect the small hose between the tank and the foam collector. Mix the water and shampoo as directed on the bottle, in the tank. Turn the knob on the top of the tank to on, then start the machine. I run the foam over about three sections, and then turn the knob back to off, lower the collector, and run back over it to pick up all the foam and dirt. I hope some of that makes sense.
Apr 12, 2007 | Kirby Ultimate G Bagged Upright Vacuum
LG WM-2277HW Front Load Washer Logo
48 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
