Question about Ovens
I have a St George oven, when oven is on and turned off after use until cooled down oven gives out a load buzzing noise - any suggestion whats wrong
SOURCE: Rattleing noise when either oven is turned on
It could be a loose screw that has fallen from inside your back panel.... Be sure to turn off all power sorces before you access the panel to avoid electrical shock!
Posted on Dec 30, 2006
barkencoa
  • 3463 Answers
SOURCE: Baumatic B180ss Electric oven problem
It sounds like the overheat safety stat is cutting the oven off.
This is prevent the oven overheating and catching fire.
They can go faulty and operate prematurely, causing the prob u are experiencing.
If it is built in , make sure it has adequate ventilation, as this can cause the prob.
Also check to see if it has an external cooling fan fitted, these can fail, and again cause the prob.
They are usually fitted under the top cover of the oven, and designed to keep the oven cool.
It should come on shortly after turning the oven on
These things are the most likely cause of the prob.
plz rate my solution.
Thanks.
Posted on Dec 31, 2008
Larrysito
  • 73 Answers
SOURCE: noisy fan once oven at temperature, this continues
copper rings (used as bearings) r out that is the problem od the air flo is jamed that is y is then owen fan owerheated....and copper is loose not tight anough
Posted on Jun 08, 2009
  • 234 Answers
SOURCE: oven turns off if too hot
There is a temperature switch that shuts the power down if the temperature goes too high. This is to prevent a fire if your thermostat sticks on. Sometimes the switch will become weak and open the circuit at too low of a temperature. Replacing the switch should solve your problem.
If you need more assistance, post a comment with the model and s/n of your stove.
Thanks,
Tim
Posted on Jun 28, 2009
SOURCE: turn off the timer on an old imperial st george
I have this exact same oven and this "feature" annoys me no end. To turn it off ... turn the clock dial to PAST the time that the timer dial shows. EG: If your timer dial is showing 6, turn the clock dial so that it rolls past 6 o'clock. This will pop out the timer dial and thus turn off the timer, allowing you to use the oven normally.
To stop accidentally pushing/turning that timer dial, I removed the knobs. Good luck.
Posted on Oct 03, 2010
Hi I have an old 1970's St.george imperial wall oven and I can't turn the roast light off which makes the oven heat up to under half the heat it normally does. How do I turn the roast light off?
since I have no model or serial, I assume this is an electric oven based on the description provided. this is usually an indication that the heating element has gone bad. possibly having a short to ground which completes a partial circuit in turn giving you heat and a light. I would look in this direction first.
Jan 04, 2018 | Imperial Ovens
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
My AEG competence oven is making a loud buzzing noise coming from the top fan? The food tonight was either burnt or under cooked? The buzzing is also loud when switched off/cooling down? Any ideas please.
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
Dec 12, 2010 | AEG D4101-4 Electric Double Oven
Hotplate won"t turn off st george cc-600 cooktop
I have a St George glass cooktop with temperature sensor light.It takes forever for the light to go out when I use the main element and that section often feels like it is still heatinglong after it has been turned off.Can there be power leakage through the switch for the main element
Aug 21, 2010 | Ovens
Hi the temp on our st george oven, model ueo-8 has become unreilable?
if digital the replace the oven control / if dial then the dial is at fault . mm
Jul 12, 2010 | Ovens
I used the self cleaning feature and halfway through got f2 (too hot). we turned off the power and let the oven cool down. now it is making a buzzing noise when the door is closed and the oven is off and...
Sensor inside oven towards the back two screws remove and unplug sensor replace with new one. Sensor burns out when using the self clean feature. New sensor $15-$20
Jan 24, 2010 | GE Profile JTP56 Electric Double Oven
Oven turns off if too hot
Thanks,
Tim
Jun 28, 2009 | Ovens
Ovens Logo
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
