In my Mac Book Pro, when I am trying to securely empty the trash, it is saying that unable to do so because of the files which are locked
  • 47 Answers
  1. Use the app What Keeping Me to determine which process your Mac is running which is keeping you from emptying your trash. (If there's only one file in your trash, look for the file under the heading Files in Trash in the What's Keeping Me app).
  2. Click Search Selection.
  3. Take note of the name of the process that appears.
  4. Open the Mac app Activity Monitor (it's in your Utilities folder, which is in your Applications folder).
  5. Search for the process you noted earlier, then click the Quit Process button (or press these three keys: option+command+Q.
Posted on Sep 03, 2014
KenKaBob
  • 89 Answers
SOURCE: mac book pro is currently locked to region 1,
Home Index DVD Region Codes
In order for you to view a DVD's content, the region code on the DVD and the region code for DVD Player must be the same. Your DVD drive is automatically set to a region code the first time you play a coded DVD. If the region code for a DVD does not match the current region code for DVD Player, a dialog appears for you to change the code for DVD Player.
IMPORTANT: You can set the region code for DVD Player only five times (including the original setting). The fifth time you change the code, it will be permanently set. The following map and table indicate the code for the various regions. Some DVD discs can be played in any region, and are sometimes referred to as having region code 0. These discs can be played regardless of the region to which DVD Player is set.
Posted on Apr 01, 2009
  • 739 Answers
SOURCE: what courses the hard drive to file on a mac book pro laptop.
Hi Stephanie
This is one of those questions that's virtually impossible to answer, it could be anything.
Your best option is to take to a mac specialist (the dealer where you bought it) or to an Apple Store if you have one near by.
It may not need a new hard drive, it may just be corrupted and need sorting out. On the other hand it could have failed mechanically and will need to be replaced - check your warranty. There have been a number of reports of HDs failing in some models and Apple have replaced them free of charge as there was a manufacturing fault at the HD factory that didn't come to light until the drives had been running for about a year.
You have been using Time Machine to back up your work haven't you?
Posted on Jul 28, 2009
  • 50 Answers
SOURCE: Error Message 10810 When I try and restore Time machine Backups, and where do I look for files for 1 Password and Address Book?
open adress book it have all your address and keychain access have all your password stored. rate it please
Posted on Aug 12, 2009
  • 7 Answers
SOURCE: My mac book pro is password locked by another user
In order to override/reset the root level password on your system you can boot up from a system disk (insert disk and restart holding down "C" key). If you don't have a system disk, there are other ways to do it: http://www.macosxhints.com/article.php?story=20080414140636495
Posted on Mar 29, 2010
Testimonial: "wow, this is great, can't wait to try it when I get home! "
  • 9 Answers
SOURCE: Lost install disk for Mac book pro My 13" Mac book
You will need some install disks to even begin working on your issue.
Your options:
  • Find someone with the same model MacBook Pro and borrow the disks.
  • Buy a copy of Leopard (10.5) or Snow Leopard (10.6) and use them. If you are going to buy a set you might as well update to Snow Leopard (10.6)
  • Check eBay for install disks but make sure they are for the same model MacBook Pro.
  • Contact an Apple service center and purchase a replacement set of install disks.
Once you have a install CD, I would recommend backing up your system by making a disk image of the hard drive to an external drive. Then doing a clean install and then using the Migration Assistant to restore your user files to the clean install on your hard drive.
Posted on Apr 24, 2011
How do I fix error code -8072 in OSX when trying to deleteitems fro Trash bin
If you can't empty the Trash on your Mac Try these solutions if you can't empty the Trash or move a file to the Trash.
If your Mac says that the file is in use
  1. Quit any app that you were using with the file, then empty the Trash.
  2. If that doesn't work, the app might have one or more background processes that are using the file. Restart your Mac, then empty the Trash.
  3. If that doesn't work, you might have a startup item or login item that is using the file. To temporarily prevent such items from opening automatically, start up in safe mode by holding down the Shift key while your Mac starts up. Then empty the Trash and restart your Mac normally.
If you can't delete the file for other reasons
  1. Start up from macOS Recovery by holding down Command-R while your Mac starts up.
  2. When the macOS Utilities window appears, select Disk Utility and click Continue.
  3. In Disk Utility, select the disk that contains the file that you want to delete. Then use the First Aid feature of Disk Utility to repair that disk.
  4. Quit Disk Utility, then restart your Mac and empty the Trash.
Jan 02, 2018 | Computers & Internet
How to delete files on a mac
You can either single click on the file and drag it to the trash can located on your dock or single click on the file then go to the file menu and select Move to Trash or single click on the file and click on the cmd key and the delete key at the same time. Once they are in the trash to get rid of them totally go to the finder menu and slect either empty trash or secure empty trash (this one totally purges the file and it will not be able to be recovered. Hope this helps.
May 01, 2013 | Apple Mac Pro A1186 Desktop
Need to unlock obsolete document to throw it away (iMac).
Put the file into the trash as normal then..Hold down the Option key (Alt key) and select empty trash while holding it down. You won't get any warning but the trash will empty and your file will be gone.
Dec 29, 2012 | Apple iMac G5 Desktop
Delete locked files
Improve the FixYa experience for everyone by voting. I personally welcome your constructive criticism so that I can upgrade my knowledge base. Fee free to contact me for any additional advice you might need.
My name is Ben.
I'm going to recommend two programs that should solve your problem(s).
AppTrap for Mac will force a removal. Examine the review and free download by CLICKING HERE
Amnesia for Mac will clean up anything that your Mac considers a locked file and refuses to send to Trash. Examine the review and download by CLICKING HERE
I have no financial interest in any products that I recommend.
May 24, 2012 | Apple MacBook Pro Notebook
My trash is always full when i turn on my macbook pro
Try securely emptying your trash. After turning on your computer, hold down the 'option' button, click the 'Finder' menu in the upper left and choose 'Secure Empty Trash.'
May 16, 2011 | Apple MacBook Pro Laptop Computer with...
I need to delet all files in mcbook pro
drag the files that you want to delete to the trash can and "control + command" click the trash can and secure empty the trash can.
Sep 12, 2010 | Apple MacBook Pro with 17" Display
Unable to:open file:file may be locked or in use to access privileges be incurrect
It is quite simple. You will have on your hard drive, where your data file is located some locked files. they will be called lock .flk or maybe even one called access. When you see these files, drag them to the trash and empty the trash. If the trash cannot be emptied. Shutdown your computer and restart.
This should release the lock. These files are normal to see when you are in MYOB but if you crash out they should dissappear, occassionaly they will not.
Apr 13, 2010 | Myob Accounting Plus (BPJUBC00) for PC,...
How do I empty a Mac downloads' file?
Ctl click on downloads/Open in finder/ select the file/files you want to delete. Drag to the trash and drop. Then go to finder menu File/Empty trash. OR* select the one you want gone CMD click for mutiple items then press CMD+Delete. to empty trash press CMD+Shift+Delete.
Nov 20, 2009 | Apple MacBook Pro Laptop Computer with...
Can't download music - says device full
Easy fix, just did it. Talked to Oakley customer service. If your using a MAC when you delete the files off the Thump Pro, you must empty the trash. For some reason, with MAC the files are masked into the trash, so unless you empty nothing is going to change. Mine worked perfectly when I did this, after days of frustration. Good luck.
Dec 14, 2008 | Oakley Thump 2 MP3 Player
Creating space on external hard drive
When you move files to the Trash on a Mac you are just marking the files to be deleted next time you empty the trash. You are not actually deleting them when you move them to the trash. They will continue to take up space on your drive until you empty the trash.
Emptying the trash will delete everything in the Trash folder regardless of which drive it is stored on. If you have files you are not certain you want to delete that are located on your internal drive, open the Trash folder and move them temporarily out (like to the desk top), then empty the trash to delete all the ones on the external drive that you do want to clear off.
You will see that the free space has increased on the external drive. Now put back in the trash the files from your internatl drive you were thinking of deleting but not certain you wnated to (if that is your reason for not wanting to empty the trash. I'm not clear on why you would not want to delete them.)
Apr 04, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Open Questions:
Need help! Backed up how do I restore and what restores 'Cloud Backup For Small Business Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Server Cloud Backup Solution their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Cloud Backup For Small Business companies with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in mind. To provide Online Backup Pricing optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
Jul 18, 2018 | VIA Computers & Internet
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
