Question about Danby DPAC9030 Air Conditioner
Need new external water tank quick release for Danby DPAC9030
The quick release nipple on the large water tank which plugs into the main conditioner unit just 'came apart' when I was connecting it. Anyone know where I can purchase a replacement?
You can order it from Danby directly (you can get their contact online from the Danby website). They cost like 4$+shipping, I had to buy one last summer. They ship to Canada and the US.
Posted on Jun 25, 2009
Really sorry I can not find my manual and It's the first time I have turned it on this summer and I can not get it to cool.
Hi and welcome to FixYa, I am Kelly,
Here are 2 sources for the manual:
http://www.retrevo.com/support/Danby-DPAC9030-Air-Conditioners-manual/id/886bh650/t/2/
(Click on download manual)
and
http://www.ajmadison.com/cgi-bin/ajmadison/DPAC9030.html
(Click on info and guides then download the operation manual)
If you still have problems after downloading the manual just respond here and we can help you.
Thanks for choosing FixYa,
Kelly
Feb 01, 2011 | Danby DPAC9030 Air Conditioner
Remove Water Tank
  • require you empty the unit by hand (usually less expensive units). These have either a removable water tank which must be emptied, or have an internal tank and a drain, where you have to empty the water into your own pan. Sometimes the drain is on the bottom of the unit, making it hard to find a pan that will fit under the unit to drain it.
  • discharge most of the water through the exhaust hose (usually more expensive units). This is called "Auto-evaporation" or "Self-evaporating" feature.
Most units are made so that they can be drained with a gravity hose that flows to a drain inside or outside your house. But the water must drain down. If the drain is higher than the unit, you may need a condensation pump to move the water upward. A few units do include a pump to send the water a short distance through the drain pipe.
do no forget to rate the solution as fixya if it helps you.
thanks.
Jul 02, 2008 | Danby DPAC10031 Air Conditioner
My danby air conditioner/dehumidifier model dpac 8399-4 leaks water all over the floor and never fills the holding tanks what can I do to fix this problem?
Probably needs cleaning. I assume it is on a level surface. Water drips from the evaporator coil into a collection tray of some type and then drains into the holding tank, this tray is either broken or the outlet is plugged.
Good Luck,
Gilsh
Nov 26, 2009 | Danby DPAC8399 Air Conditioner
HOW DO YOU EMPTY THE WATER TANK
Which one? The internal water tank just slides out of its chassis (located on the left side, near the front). You might have slight spillage after a good tug or two.
For the external water tank, located the white "spout" that protrudes from the rear. Inside of this "spout", there is silver clip. Just press the clip inward and that should release the connector that is attached to the external water tank.
Jun 26, 2009 | Danby DPAC8099 Air Conditioner
Connecting a hose to take out condensation Danby dpac7008
you'll have to take it apart their is a switch which will have to be by passed .hook up your hose to a drain good luck . Tom
Jun 18, 2009 | Danby DPAC9030 Air Conditioner
Led display light display is to low to read
As it has been Discontinued and replaced by DPAC90061.
Your solutions are very limited. If you can find a remote that would be the way to go.
found remote here for 12$ US a bit less than the panel and all functions are on it.
Best to you.
https://www.danbyapplianceparts.com/product-category/danby/portable-air-conditioners-danby/dpac9030/
Mar 07, 2018 | Danby DPAC9030 Air Conditioner
Dehumididfier
Here's a link for the manual for your particular unit. Save and print a copy for youself to refer to. It also has basic troubleshooting information.
Hope I was of assistance and this helps. Best Regards!
Aug 16, 2008 | Danby DPAC9030 Air Conditioner
Red flashing light
Had the same problem, thing shutting off after an hour, no water in the tank. I had the external tank attached, was always bone dry. What I didn't know was on the side, there is a slide out tray which acts as the internal tank. The lid to that tank activates a micro-switch which tells the unit that it's full. This tank was dry too, but the switch was getting jostled, casuing it to trip. I've taped down the switch now, and it's fine. I check the tank every few days, just to be safe, but it's never got any water in it. Hope this helps.
Jun 25, 2008 | Danby DPAC9030 Air Conditioner
Danby portable air conditioner
Look into the owners manuals for that problem code. Have you tried to plug it into a different electrical outlet? Problems with P codes general are a power related. Thanks
Aug 09, 2007 | Danby DPAC9030 Air Conditioner
Open Questions:
See all Danby DPAC9030 Air Conditioner Questions
Danby DPAC9030 Air Conditioner Logo
297 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
