Question about DeLonghi Esclusivo Gran Dama EASM6600 Stainless Steel Espresso Machine
Water or milk is not passing and water leaks from under the machine
2 Suggested Answers
dutchman05
  • 487 Answers
SOURCE: where does the milk go
Follow this link.
Goto instruction manuals, espresso /coffee combo
BCO70
Posted on Jun 14, 2008
My cappucinatore no longer draws the milk into it. Secondly, the machine leaks dirty water.
You have to use protein dissolving cleaners on all machines that draw milk. We use a product called Rinza in our commercial machines x 6 :>)
It could also be the pump.
Dirty water, especially with grounds in it is caused by faulty seals.
It is time your machine was professionally serviced.
Dec 02, 2016 | Coffee Makers & Espresso Machines
My Cuisinart EM-100 Espresso Machine leaks water from the bottom.
Thanks Joe received ur gasket in mail installed it in 10 minutes and no more leak! The old was caked up above and below.
Dec 03, 2012 | Cuisinart EM-200 Espresso Machine
Leaking from pod holder
I had the same exact problem and my machine started to smell even though I descaled it regularly and cleaned any of the milk that dripped out of the capsule. Finally, we took apart the whole machine and found a TON of dried, rotten milk. It was disgusting. We completely cleaned the accessible part of the machine with a vinegar solution and put it back together. I was hoping that we fixed whatever was causing the leaking, but no such luck. It is still leaking and still smells bad, so we are going to get a different kind of machine. I will not be getting a Dolce Gusto again, because I have called their customer service multiple times about this problem, and none of them ever had a solution. The whole milk thing grosses me out, I think I'll just get a single serve coffee machine and foam the milk myself.
Aug 25, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
Our Saeco Magix Deluxe (old style) has developed a leak. It happens inside the machine, on the left, and is pretty severe, during coffee making. Sometimes there is just a little coffee ground in the...
Hi
When the machine is done brewing some water is relieved into the drip tray. This is the pressure relief. Some coffee residue is also taken into the drip tray. This is normal. As long as nothing is under the machine your OK.
Oct 23, 2010 | Saeco Magic De Luxe Espresso Machine
Hi, the hot water outletpipe( i don`t know how to say it in english) keeps leaking water. If the machine is heating up, tehe pipe allready starts leaking and keeps doing it. The machine is only 8 months...
Do you mean the "steam wand" ? The pipe you would use to steam milk?
That sounds like the steam valve needs replacing or rebuilding. If the machine is only 8 months old it is still under warranty. You should contact the store where you bought it or contact Gaggia service center in your country.
Sep 21, 2010 | Gaggia Titanium Espresso Machine
When brewing a coffee, water 'leaks' out the steam wand so now we have to leave a cup under it at all times. this has been going on for a number of months. More recently, when trying to brew a coffee, the...
The tap in many of the Talea ring models is a dodgy plastic thing. It breaks pretty easily. You can replace them (with a more sturdy metal one that they use these days) but getting the cover off is pretty tricky. Best to get a service guy to do it
May 21, 2010 | Saeco Talea Ring Plus Espresso Maker with...
Water Leaks from the head gasket while heating up to use steam
This is a result of the water temperature in the boiler increasing, thereby expelling water that may remain in the lines out of their respective exit points. A solution may be to place a container under the group head to catch the water, or opening the steam valve partially to allow the water to exit through the steam wand (again placing a vessel/cup/pitcher there to catch the water). This is a problem that even higher end (dual-boiler) models have, due to the necessary purging of water that accumulates in the steam wand during down-time.
Don't look at it as a problem, but simply as a quirk that single-boiler machines have. If you are still irked by the issue, consider buying an inexpensive manual frother (Bodum makes these) to froth and heat your milk (in the microwave after frothing) separately. An added plus is that you can do this while you make your espresso, so if you make primarily milk-based drinks (latte, capps etc.) you'll save on time.
Dec 21, 2009 | Saeco Starbucks Sirena Espresso Machine
Leaking water from steamer
For the grouphead check the basket there might be a slight bump around the edge that is preventing it from making a good seal when it contacts the gasket in the head. If the Double works fine then the gasket is not the problem.
For the steam wand try flushing wand for 3 seconds just before steaming, if that does not help with the watery milk, then the boiler is not getting hot enough to produce steam.
May 18, 2009 | FrancisFrancis! X1 Espresso Machine
Milk island seems to leak water. After milk is frothed and island has been detached fro some time, a pool of water forms under the base of the milk island attachment and on top of it.
Milk island on a vienna class?
Perhaps its a Saeco Talea you have, correct?
First remember that after foaming your milk and have turned the knob back to´off location. wait until you hear a clicking sound from the machine, might take 2 -5 seconds after it set to off.
Then remove the milk container
That sound means it has close 100% and shouldent leak.
If it still leaks after that its the gaskets in the T-pipe that needs to be changed.
Jul 07, 2008 | Saeco Vienna De Luxe Espresso Machine
Where does the milk go
Follow this link.
BCO70
Jun 05, 2008 | DeLonghi Caffe Nabucco BCO70...
DeLonghi Esclusivo Gran Dama EASM6600 Stainless Steel Espresso Machine Logo
55 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
