Question about Whirlpool Kitchen Ranges
E4 F4 oven turns off
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
You don't say if it's electric or gas, if gas check the pilot light at the bottom centre of the oven if it's a very poor flame or is flagged up not burning properly it will cause the thermocouple to drop out and turn the oven off.
Posted on May 08, 2014
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
In mid bake the oven turns off and says F3:E4
F3 - E4 Oven temperature sensor (RTD) opened (lower oven, if double oven)
Replace Oven temperature sensor (RTD)
Sep 25, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
Oven turns itself off
The F4 code is a 'temperature sensor shorted' code. The temperature sensor, is a small metal rod coming into the oven on the back wall, it is a little smaller than a pencil.
May 27, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
Oven control lock beeping along with F3:E4 flashing on the display
Hi-- The code described; F3 E4  indicates an open circuit- oven sensor.  As far as oven problems go this one is easy to fix. -------Unplug sensor and check resistance. Normal is around 1100ohms. ---If open, then replace with new part.  <This will solve the problem>.  You did not provide any other information besides 'beeping' and 'F3:E4'.  A simple Model # from the tag on unit is required for any service or information.  However, since this is a specific fault code, the oven temperature sensor is the most likely suspect. Please acknowledge this post. Solution is to replace the oven temperature sensor.  Thanks-  Ed
Mar 30, 2010 | KitchenAid Ovens
The oven won't turn off and it shows a e3 f4 in the display
Hi There
I have found this for you and hope this is helpful.And let me know how it goes.
F4 Shorted oven temperature sensor Replace oven temperature sensorThank you for writing to fix ya.
Best Regards Richard
Jan 06, 2010 | Ovens
Oven turning off
F3 - E4 Oven temperature sensor (RTD) opened (lower oven, if double oven). You will have to replace this failed sensor to restore normal operations. If your oven is a double version, it will be located in the lower part. If its a single range, it will be located in the oven compartment. The Oven Temperature Sensor has failed.
Please rate and god bless:)
Apr 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Cannot solve game 100 on Professor Layton & the curious village
imagine the dots as a complete grid A-F across the top and 1-6 down the side now join the dots like so A1-B1,B1-B2,B2-A2,A2-A1///C1-E2,E2-D4,D4-B3,B3-C1///D1-F4,F4-C6,C6-A3,A3-D1///
E1-F2,F2-E3,E3-D2,D2-E1///C2-F3,F3-E6,E6-B2,B5-C2///D3-E4,E4-D5,D5-C4,C4-D3///
you should have only 4 dots left to join,good luck
Nov 26, 2008 | Nintendo Professor Layton & the Curious...
F4
Replace the temperature sensor. It is usually located in the upper left corner of the oven (inside). Two screws hold it in place and, if you're lucky, you can pull out the junction to disconnect the old and connect the new one. Do this with the power off, Please!
Aug 22, 2007 | GE JKP86 Electric Double Oven
Kitchen Ranges Logo
41 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
