Question about Canon Pixma MG8120 InkJet Printer
Replace pixma printhead
Printer will not print magenta
  • James Agans
    James Agans May 11, 2014
    I recently saw a Utube video where the guy removed the printhead and completely submerged it in his ultrasonic cleaner, took it out after about 20 minutes, rinsed it, dried it with a hair dryer and it printed like new. I wish I saw that video a long time ago. It could, of course, also be the Mag cart that is the problem.
  • 101 Answers
Print heads on this model run about $80 on ebay. Your best bet is to first replace the magenta cartridge even though it may appear to still have ink in it. After that, go into the maintenance menu and run a full cleaning cycle several times. This may clear your clogged print head.
Posted on Apr 19, 2014
  • 7 Answers
SOURCE: Canon Pixma IP5000 wont print cyan or magenta
Think you need to clean the sponge that the ink cartridges sit on in the head tray they are probably blocked with dry ink. You can remove the print head and tray by lifting the lever and gently lifting it out..... go here http://www.inkjethelper.com/
to see how to carefully clean it with compressed air. I had to do this too.
Posted on May 02, 2009
cene765
  • 787 Answers
SOURCE: printer does not print magenta and cyan. Change
The print head is clogged.Try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around
with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0049.
Posted on Nov 12, 2009
Buffalo12980
  • 625 Answers
SOURCE: pixma iP4000 problem
the printhead is shot. I've replaced my printhead twice on my pixma ip6000D in just over two years.
Posted on Aug 21, 2007
  • 615 Answers
SOURCE: Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Posted on Mar 28, 2010
SOURCE: Error: The type of Printhead is incorrect, Install the correct printhead.
Ok i know this is kinda old, but i found a solution.
First to those people to state I found a solution from hp, cannon etc etc and not give out the direct link, or instructions, then whats the point fing posting????
This error happens when you install an oem cartridge onto your system. Or havent used it in a while, so the machine is somehow misfigured.
This solution is for canon mp800, simply switch off printer. HOLD stop/reset and press and HOLD on/off button. release stop/reset. Now press stop.reset twice. then release on/off button, press stop/reset 4 times, wait 20 seconds, press on/off button twice.
switch machine back on and the printer should find the cartridges.
This method maybe the same for your mp*** if not google RESET CANON PRINTER MP*** and you'll find the correct buttons to press.
here's a printer on reseting a bunch of canon printers http://tricks-collections.com/reset-printer-canon-mp140-mp160-mp180-mp210-mp220-mp460-mp470-mp500-mp510-mp530-mp600-mp610-mp800-mp820-mp810-mp830-mp960-mp970/
good luck.. and FU canon for adding you scamming chips into cartridges.
Posted on Jun 11, 2010
Tried to print something today after not using printer for about 3 weeks. First go all colours were present but streaky. Did the nozzle alignment but on testing found that Magenta was completely missi
Hi Mandy
1) confirm there is ink in the magenta cartridge first - by removing it from printer and looking through the ink 'window'.
If you can't see the ink level, it's either empty or very close to it. If so, replace the cartridge.
2) If ink level looks ok, install it back in printer then set out a full page of magenta (or red) background or large graphic and print few pages on high print quality setting until the magenta starts to print. This works better than printhead cleaning/deep cleaning because it wastes less ink.
3) If it still doesn't print red after 2-3 pages, the printhead is blocked. Take it out and rinse under hot water tap. Keep washing it until only clean water is coming out. Shake any water off then DRY the electrical contacts really well. Don't install a wet printhead back in printer - or you may damage it. Run one or two deep cleans and print a nozzle check. With bit of luck all colours will work now...
good luck!
Jan 13, 2015 | Canon Pixma iP3600 InkJet Photo Printer
I have been given a canon pixma MP160 with no ink cartridges. what sort do I look for in the store.?
This printer uses 2 ink cartridges.
  • Ink Cartridge Configuration 1 black cartridge, 1 color cartridge (cyan, magenta, yellow)
You need to purchase the cartridges that suit this model printer.
If the printer does not print properly then the printhead may be faulty and needs to be replaced, BUT these are expensive. It may be better to put your money towards a new and better printer as a new printer is not much more expensive than the cost of a new printhead.
Jun 13, 2011 | Canon PIXMA MP160 All-In-One InkJet...
MP530 all in one printer - bought Staples magenta & blue inks but printer won't print those colors but did print older Canon inks not needing replacing; bought new Canon magenta & blue inks but...
What you can do is take the ink cartridges out of the print head and remove the printhead. Hold the print head over a trash can and take some 409 cleaner and spray the little pads inside the print head til you start noticing the colors dripping into the trash can. You will them want to dry off the print head as much as possible and litely wipe off the outside and the bottom of the print head with a paper towel. Then reseat the printhead back into the printer and the inks. You will then want to run a nozzle check from your printer software or from the printer properties. If the inks still are not showing up run one or two cleanings. If the issue still persists then you might have to replace the printhead. If this is the case you can look up part number: QY6-0059-000 online to replace the print head.
Jun 30, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I have a iP4500 and it won't print the magenta. I
You need to try another cartridge before anything else, some generic carts. don't fit right in the printhead, the ink pad is too far up inside the cartridge. You may have a defective printhead, or possibly the purge unit is not cleaning properly. I can't tell without seeing the printer.
Aug 12, 2009 | Canon Pixma iP4500 InkJet Printer
PIXMA MP 600 PRINTER EVERTNING PRINTS GREEN
Usually I see that when you put in photo magenta when it should be plain magenta.Otherwise you need a new printhead.
Jul 03, 2009 | Canon Pixma MP600 Printer
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
HP D135 - replaced printhead - still doesn't print in that color
try this link : I followed the directions and fixed the problem. the instructions that came with the new printhead weren't really complete.
Here's essentially all I did for my fix - Opened the printer top, turned the printer off. Removed the "bad" printhead, cleaned the metal contacts on the printhead and printer with windex. Closed the printer. Turned it on. waited for it to reset. Opened the printer. Turned the printer off again. Installed the printhead. Closed the lid. Plugged the printer in again. When it was ready I accessed the HP toolbox and alligned the printheads and cleaned the printheads. It worked. Here's a link with photos.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&lc=en&cc=ca&dlc=&product=64986
Oct 18, 2008 | HP OfficeJet D135 All-In-One InkJet...
Canon ip4200 colour magenta
the colors transfer to the printhead by gravity. the felt on the inktank must make intimate contact with the stainless steel filter in the printhead. I have a pixma ip 6000D that I had to replace the printhead inside of two years three times. the bubblejet circuitry in the printhead got burned out. New heads cost from $55 to over a hundred.
Sep 10, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Pixma iP4000 problem
Aug 20, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon Pixma MG8120 InkJet Printer Logo
89 people viewed this question
old marine
old marine
