Question about ESP Ltd EX-50 Electric Guitar
Not getting enough distortion(esp ltd ax-260)
My guitar was working fine but my amp cab fell on it when moving my equipment from practice and recently since then my guitar is not getting enough distortion kinda sounds like when i have my volume knob on my guitar not turned all the way up. I made sure if it was my amp that was not working but sure enough it is the guitar because my friends guitars run out of it fine and get the distortion i used to get from my amp. any help? My guitar is an esp ltd ax-260 and my amp head is an line 6 hd 75
  • 192 Answers
It's not your pickups. It would be nearly impossible to loosen a wire inside of your guitar by having even heavier than your amp head drop on it. It is most likely your volume pot. The post, if hit hard enough, can virtually distroy your pots. Another possibility could be your jack, al though considering where it's located on your guitar, it would be very hard to damage it by having something drop onto it.
There is little else that could be the problem. Hopefully you didn't damage your guitar too badly. If the guitar was in front of me, it would be a relatively easy diagnosis.
Fortunately, volume and tone pots are inexpensive, and if you're handy with a soldering iron (or you have a friend that is) it is an easy install with four to six solder points, depending on your configuration. I don't want to assume it's a stock setup, but when you take off the rear electronics cover, you will immediately see what configuration you have.
If you have possibly damaged the pickup bobbins (assuming you have the stock humbuckers in your guitar), you would be able to see the damage, It would either look damaged,or work correctly. As you know bobbuns are simply wound wire, and that's not easy to damage. Plus your strings provide a minimal amount of protection, unless your amp head slammed it very hard. Start by replacing the volume pot. Cheapest parts first. There is no way to test the pot with anything like a potentiometer, because there is virtually no voltage that passes through the pot. Additionally, unless you have active pickups, your pickups cannot be either. If you do have to replace your electronics, you can find a large variety and even upgrade your parts by searching eBay. The good thing is that you havce a guitar, and guitar parts are abundant, relatively cheap, and most people change out electronics just to achieve a different sound.
If you are so inclined, most good guitar shops will diagnose your problem for cheap and apply the cost of the diagnosis to the cost of the repair. Good luck, and I hope I have given you some information to work with.
Thank you for using FixYa
Posted on Jul 19, 2009
Check to see if your tone knob is disconnected from your volume knob inside the guitar, and make sure all wiring is connected right.
You say your cab fell on it, and a cab is a lot of weight, and if it hit the knobs or pickups, it could have caused something to come disconnected.
I have had this problem with guitars of mine, and every time it was some sort of wire becoming disconnected issue.
Posted on Jul 07, 2009
    Scholar:
  • 109 Answers
You will not get 100% of your amp's distortion with the guitar's volume rolled down. If its turned all the way up and it still doesn't sound right, I'd try swapping out pickups.
Posted on Jun 19, 2009
Is it the guitar or the amp
Hi, Sounds like you have a bad cable to your amp. Try swapping out the cable. If that is not the problem, The pickup maybe bad.
Hope that helps.
Jan 14, 2014 | ESP LTD MH417 7-String Electric Guitar
My boy has an esp ltd ax 150 bass which has broken E strings at the bridge since new almost 1 a week the bridge was modified by a Luthier which worked for a small amount of time then the problem came
You friends bass has a burr on the saddle. take a small fine file and go along the pacth of the string...Go over the saddle and slowly file lightly..This should get rid of your problem...take it to a service center if you arent comfortable doing this
Apr 08, 2013 | ESP AX-414 LTD 4-String Electric Bass...
My ltd deluxe ec-1000(vintage black) is not producing any distortion on my Marshall mg100hdfx. this is the first time i have had an active pickup guitar, i put a new 9v battery in it but still no change in...
Distortion is not produced in the guitar. Distortion is generated in the amp by circuitry that increses the gain until the waveforms "flat top". This creates higher harmonics and a buzzy sound. If you are getting a very low output from your guitar it is possible that you don't have enough output to get the distortion in the amp to work. Other settings in the guitar add harmonics by mixing more than one pickup. This is not ditortion but adding these harmonics changes the sound immensly.
LOOK AT THIS SITE AND FIND A SCHEMATIC THAT MATCHES THE RESOURCES OF YOUR GUITAR... You might be able to figure where the wire goes... It may be a ground.
http://www.guitarelectronics.com/c=D65u46R1H9tko6CKpPLsjBhiJ/category/wiring_resources_guitar_wiring_diagrams/
Apr 24, 2011 | ESP Ec 1000 Ltd Deluxe Electric Guitar In...
My esp ltd ex-50 have a constant buzz unless i touch the volume/tone knob(s), i re soldered the input but it still does it. any ideas?
Make sure the ground wires are soldered to the metal case of the pots. They should have a jumper running between all the metal cases.
Make sure the CONDUCTIVE paint in the cavity that is used for shielding is contacted by the ground conductor at some point.
Also keep the guitar AWAY from teh magnetic fields produced by the amp.
Sep 22, 2010 | ESP Ltd EX-50 Electric Guitar
I have the esp ltd f-200 with the floyde rose tremlo and i get nothing but static when i plug in changed the batterey for the emg 81's any idea's what this could be ?
First verify the amp AND the cable is good with another guitar. Assuming they are, I would suspect you have a broken wire in the electronics of the guitar. Some of the guitars have a circuit board and that might have gotten a crack. Please do verify your amp first and the cable as these are other common problems.
May 19, 2010 | Music
My ESP LTD AX-50's pickups are messed up. When I went to play, I noticed the one pickup was very low all of a sudden. I went to lift the height, but it wouldn't and the screw just came right out when I...
looks like the pickup thread is damaged, it happens often...
open the pickguard, remove pickup and repair thread flattening little bit pickup flange by small hammer
thread will become usable again
Oct 25, 2009 | ESP Ltd EX-50 Electric Guitar
My guitar volume won't turn off
the problem i analyse is 1) the wires of the volume control (it has three wires wired to the input of the amplifier) wire 2 and 3 have got shortened.
2) the field effect transistor of the preamplifier has got shortened . the fet is in built in certain guitars.3) if its wire wound volume control then it has lost grounding , that is wire no 3 has lost its grounding (usually this is associated with a hum from the amplifier
Sep 19, 2009 | ESP Ltd EX-50 Electric Guitar
I'm think about buying an alexi 200 guitar, but i want to replace the esp pick up for an emg 81. Is there a place for the battery the pickup will require?
There should be enough room inside for the battery. If there isn't you could do some routing to the body to make it fit. I personally don't have this guitar but more than likely you can position the 9v battery to fit. To keep it from moving around, you can put a piece of sponge in the cavity.
Jun 09, 2009 | ESP Ltd Alexi 200 Electric Guitar
ESP Ltd EX-50 Electric Guitar Logo
392 people viewed this question
Top ESP Music Experts
Arora Singh
Arora Singh
Michial Gueffroy
Are you an ESP Music Expert? Answer questions, earn points and help others
