Question about Dell Inspiron One 2305 Desktop Computer (AMD Athlon II X2 GB3GB) (DDPCEZ1P)
Dell inspiron one 2305 black screeen with one flashing light
When i power up it first say f2 or f12 then goes to black screee with one blinking light
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 24 Answers
Dell Inspiron One 2305 (all-in-one) that will not power on. ... to reboot, I saw a faint white flashing light and heard a faint clicking noise. .... but I still have the black screen and my 2305 model remains essentially "dead".
Posted on Oct 17, 2016
asingh1225
  • 122 Answers
SOURCE: Inspiron 530 Dell desktop
hello, how long have you waited for something to happen before restarted the system?
in any event, try resetting the BIOS. this is how: unplug the power from pc, wait 10 seconds then open up the side panel of the PC. First thing to do is to make sure you r not carrying any electrostatic charge (sound complicated? well its not) before you touch anything on motherboard in the computer just touch the metal part the casing and you are done.
now, locate the round ( coat button size) battery and gently take the battery out with paper clip, then look around and your will a jumper around that battery area. note the jumper position, if jumper is on first two pins, remove it and put it on last two.
Now plug the power back to PC (yes battery is still out)and press power switch (note PC may power on or may not) then 3 seconds later pull the power cord back out.
now, move the jumper back to its original position and put the battery back in, plug the power back and test computer.
hope fully this would do the trick, and if not, we might have to perform other tests like bad memory chip, BIOS update etc...
Post your results, good luck
regards
Amar Sondhi
Posted on Dec 04, 2009
james klgr
  • 362 Answers
SOURCE: Boot fails at Dell Inspiron logo at half way mark
you need to reset the processor and test your ram, one last thing make sure your dvd rom is working check cable make sure its connected
Posted on Apr 16, 2010
Testimonial: "Resetting the processor is something that would not come to my mind as a resolution. However, I did along with most others. It worked. Thanks!"
PuterCare
  • 226 Answers
SOURCE: Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Posted on Jul 02, 2010
  • 44 Answers
SOURCE: On powerup of Dell Dimension 5100 running Windows
try this:
Power the PC off, open the case cover, remove/reseat the video card in the slot.
* Power the PC off
* Disconnect the PC power cord from the rear of the PC
* Remove the computer cover
* Move the RTCRST (Clear CMOS) jumper from pins 1/2 and place it on pins 2/3
* Press the PC power button
* Move the jumper back to pins 1/2
* Remove/reseat the video card in the slot
* Replace the power cord and cover and then power the PC on
Hope it helps
Posted on Nov 05, 2010
SOURCE: my Inspiron one 2305 is
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
SAFE MODE
At start up press F8 go2 SAFE MODE thn type at run chkdsk,chkdsk/f/r & thn restart pc
Else Repair XP
Else clean ram BY RUBBER
Posted on Mar 17, 2011
I have a Dell Inspiron ONE 2305 All in One. The power supply tested bad so I replaced it, however the computer still will not turn on. When plugged in and pushing the power button, the power button flashes...
When a power supply goes it can do all sorts of other damage. You will need to get the system tested properly, to check the processor, RAM and drives. The PSU can also fry the motherboard. You could try some known working RAM in place of your own, This will eliminate at least one problem.
Sep 05, 2013 | Dell Inspiron One 2305 Desktop Computer...
Dell Inspiron 6000 turns on but does nothing else.
From the description the hard drive has failed or windows has corrupt files. Unplug power supply from laptop and remove main battery, press and hold power for 2 minutes to remove residual voltage. when finished install battery and power supply now power up.
May 03, 2012 | Dell Inspiron 6000 Notebook
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
My Inspiron one 2305 is not working. I turn the power on and the light is solid white but after a few seconds it turns solid amber, and all i can see on the screen is the dell logo. and on the lower right...
Repair PC
go2 BIOS option
F10 SAVE
RESTART PRESS F12
SAFE MODE
Else Repair XP
Mar 16, 2011 | Dell Inspiron One 2305 Desktop Computer...
I HAVE A DELL INSPIRON 1200 NOTEBOOK AND WHEN I WENT TO RESTART IT. IT WON'T START UP AFTER THE DELL PAGE IT BRINGS UP A BLACK SCREEN WITH A BLINKING WHITE LINE. I HIT F12 FOR BOOT MENU, IT DIDN'T WORK I...
ok well if that is all it dose then you are going to have to restore the computer back to factory settings and then try it but befor you do that have you tryed starting up in safe mode that might work.
please rate my help to you.
thank you.
Apr 21, 2009 | Dell Inspiron 1200 Notebook
Dell Inspiron One 2305 Desktop Computer (AMD Athlon II X2 GB3GB) (DDPCEZ1P) Logo
96 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
