Question about Grohe Talia Widespread Bathroom Faucet Less Handles - Finish: Starlight
The sink stopper came off on my talia bathroom faucet and I can't get it back on
The stopper in the sink came off and I can't get it back on for the lever to go up and down
    Champion:
  • 216 Answers
UNDER THE SINK ABOVE THE TRAP IS A TAILPICE WITH A ROD POINTING TOWARD THE BACK WALL. IT IS HELD IN PLACE WITH A NUT. REMOVE THE NUT. PULL THE ROD OUT. TURN THE POPUP LOOP TOWARDS THE BACK WALL SO YOU CAN PUT THE ROD THROUGH IT.SNUG THE NUT UP AND CK TO BE SURE IT WORKS. FILL SINK WITH WATER AND CK FOR LEAKS.
Posted on Apr 20, 2014
Remove stainless pop up stopper from bathroom sink?
Look on drain tail pipe, in the back you will find a nut that holds a ball with a short piece of rod going into drain and along piece of rod that is connected to the closure rod mounted in the faucet . Remove clip and disconnect long rod and pull long rod down to raise stopper./ Hold stopper and unscrew the nut and remove rod. Pay attention on the position of stopper piece that the short rod in inserted thru.
Nov 22, 2017 | Plumbing
My son put tp down the drain. How do I remove the sink stopper? Doesn't seem to unscrew?
it unscrews but from the underneath up
you will have to remove the "S" trap only as what ever it is will be stuck in that bend
Jan 04, 2016 | Plumbing
Clogged drain on moen bathroom sink
There should be a stopper valve on the sink's downspout (the first section of drain pipe). You SHOULD be able to loosen the nut holding the stopper valve's lever inside the pipe. Once you remove that nut, you can pull the lever out - that releases the stopper inside the sink, so you should start with the stopper OPEN, and hold it open with a chopstick or pencil or other tool when you remove that lever.
The lever and the bottom of the stopper itself will be wrapped with masses of hair. That's normal. Clean it up and reinsert it, put the nut back on & snug it down, then readjust the stopper.
If that's not enough, you may need to open the trap (the gooseneck-shaped piece of drain pipe under the sink) to clean it out.
Apr 05, 2014 | Moen Tub Drain Assembly, Lift-N-Drain -...
Stopper no longer stays in up position on my bathroom sink
Solution to the most common design...
If you can pull the stopper completely out of the drain with no resistance, do this.
On the back side of the tailpiece that attaches to the bottom of the bowl, there is a rod coming out of the back side that has a nut holding it in. Unscrew that nut and pull the rod out part of the way. There usually is a loop molded into the plastic on the lower end of the stopper where that rod inserts into. Turn the stopper until that loop is aligned toward the faucet and insert back into the drain but not all the way (keep it held up about 1/4-1/2 inch from completely closed). Reach under the sink and feel for the rod while you are holding the stopper in place and push it back in while you "feel" for the loop. You will know it is inside the loop when you can't pull the stopper out with not resistance. Screw then nut back onto the threads and finger tighten it until it has enough friction to hold itself at any position.
Hope it helps...
Oct 02, 2013 | Price Pfister Plumbing
Delta faucet will not hold water
The linkage to the drain stopper has to be adjusted so that the stopper seats when the rod is raised. If the stopper lifts out of the drain, it may be necessary to remove the lifter rod and insert it through the holes in the bottom of the stopper then reinstall. After this, pulling up on the faucet rod will force the stopper to seat rather than drop by gravity. The tradeoff is that you will not be able to remove the stopper without disassembly of the connection
Feb 18, 2013 | Plumbing
When installing do you silicone each piece for example the faucet , the soap dispenser ,the sprayer , and the tap
Hi seawitch678,
If you have a granite or stone countertop/sink, use silicone as plumber's putty will stain the stone. Plumber's putty is petroleum based so it will not adhere to stone. Normally you should use what the manufacturer recommends and where they recommend. When installing a faucet, put either around the base of any piece that goes through the countertop.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 15, 2011 | Price Pfister Marielle Kitchen Faucet with...
Sink pop up waste won't close
When you pull out the stopper is it completely intact? there should be a hole at the bottom of the stopper were a rod goes through. That moves on an axis pulling and pushing the stopper up and down as you pull and push the lever. You have to make sure you get the rod in that hole for the pop-up to work. You can google pop up assembly and look for an diagram. good luck
Jun 30, 2010 | KitchenAid Home
Hair wrapped around the sink stopper. How do I remove the sink stopper to clean? it is hooked on to the little level to open or close drain but don't know how to get it off without breaking.
The lever it's hooked to under the sink it has a nut to loosen to pull lever back. Then the drain stopper will be able to be removed. Check out this link to get a look at the under neath to help you I hope.
http://www.diynetwork.com/how-to/how-to-replace-a-pop-up-drain/index.html
Jun 24, 2010 | Home
Can't Remove Plug
loosen the nut comming out the back pipe attached to sink. pull back on the rod till the stopper comes loose.pull out the stopper but screw the nut back on till you are ready to put the plug back in.You dont have to attach the plug to the rod if you dont want to it can sit freely in hole and be removed just by pulling up on it personal preference
Jun 20, 2010 | Chicago Faucets CHICAGO FAUCET Mixing...
Stopper has dislodged.
Hello. It is probably not broken. In order to fix it, you must go under the sink and above the trap. You will see where the lever for the stopper is attached and can be adjusted. If necessary look under another working sink with a similar set up. Joe
Apr 15, 2010 | Kohler Caxton Undercounter Lavatory Sink...
Grohe Talia Widespread Bathroom Faucet Less Handles - Finish: Starlight Logo
110 people viewed this question
Top Grohe Plumbing Experts
john h
Craig Butler
Craig Butler
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
