Question about Garden
Soap attachment How do I use the soap attachment on a wolfblaster max?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
If the bottle is external ,attach hose supplied to bottle and pump. soap will only work when low (big hole)nozzle is used.
Posted on Apr 21, 2014
2 Suggested Answers
wmpcs
  • 100 Answers
SOURCE: I have a Coleman pressure
Correct nozzle to use
Repairing chemical injector
Posted on Nov 01, 2010
Only add half of soap that you think you will use to do the job at a time and flash soap container after use so that sop doesn't control.
Apr 18, 2014 | Garden
Tip
Greasy hands cleanup / REALLY CLEAN HANDS
If you use strong hand cleaners and scrub brushes you can avoid both.
Soap will attach itself strongly to grease IF it is given a chance.
Typically people first wet their hands with water then add soap.
The water acts as a barrier to the soap to some degree.
Use any liquid dish soap. You only need a few CCs (cubic centimeters).
Apply the liquid soap to the palm of one hand and then rub your hands together
to spread the soap somewhat evenly. Then use your fingertips to work the soap into the grease for about 10 - 30 seconds per hand. The soap has now chemically bonded with the grease. Place your hands under running water while using a sponge with soft nylon mesh (usually white, not green) to remove the soap. The water will now bond to another part of the soap/dirt molecules and pull them off your hands with the help of the mesh.
This concept can be applied to bathing your body. A little soap, a lot of rub.
Frank in NC
on Oct 27, 2013 | Esca Tech Incorporated D-Lead D-Wipe...
LG tromm washer soap not empty after wash cycle
I have a front load He LG Tromm model 2455 HG. I never use more than 3 tablespoons for any load. This soap is so concentrated that is all you need, which really isn't very much. Too much soap could possibly cause foam to back up. Starting with the basics, could this be your problem?
Feb 19, 2013 | Washing Machines
Duet washer code SUD
Too much soap. Although there is a MAX fill line in the dispenser just a small amount of soap will get the job done. Just run an empty load with no soap (maybe two empty loads) that should get the extra soap out of the lines. Good luck.
Mar 05, 2011 | Washing Machines
I have a John Deere AC2600Gh power washer and I can't get the soap to work everything else works great it just won't **** the soap up when I am pressure washing I know that it must be something simple to...
Soap will only siphon into hose if there isnt any pressure in the hose attached to the wand.Remove tip from wand and see if it draws soap into hose,back pressure in wand hose will cause the spring and ball to seat/close off the inlet line for the soap otherwise water would blow out of soap line.
May 17, 2010 | Karcher 2500 PSI Pressure Washer
Very little pressure
INFO:
Sound like its drawing air through the soap pick up tube.
RECOMENDATION:
Pench off soap pick up tube.
Hope this tip helps.
r/
David
Mar 10, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Power washer problem - water is spraying into my soap dispenser
this can happen if you use the wrong soap, you must use pressure washer cleaner, it does not foam.
Aug 08, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Karcher G 2600 ph
Dear johnny_river,
In general there are many causes why soap is not sucked. In a domestic and various other machines the soap is only sucked in low pressure. So one thing you can try is remove the nozzle or the complete lance from your gun. This will give a low pressure. If you attach a pipe directly to the machine soap inlet, and soap is not sucked, than the soap valve is "stuck closed" with soap. It is important that one must work with fresh water after using soap. This to flash the system from any soap left. So in a few words attach a pipe directly to the nipple at the machine and use low pressure. Important , you do not have to use soap to test....use fresh water. If this works( which it should)...than service the flow control tap or change it altogether.
Regards,
fulltech.
Apr 09, 2009 | Karcher 2500 PSI Pressure Washer
Long wash times
I've had this problem, particularly with towels - it's quite annoying & not energy or water efficient at all. According to the manual, the unit has a sensor that senses if there is too much soap & it will continue to wash until the soap is removed. I found that this happened frequently on the "cotton" cycles & max spin. I've tried to make sure I use less soap, but I also use the perm-a-press cycle & the spin 1 down from max. Hope this helps
Sep 07, 2007 | Bosch WFMC 3200 Front Load Washer
Garden Logo
212 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
