Question about Garden
How do I use the soap attachment on a wolfblaster max
Wolfblaster max
  • 29 Answers
Only add half of soap that you think you will use to do the job at a time and flash soap container after use so that sop doesn't control.
Posted on Apr 23, 2014
Soap attachment
if the bottle is external ,attach hose supplied to bottle and pump. soap will only work when low (big hole)nozzle is used.
Apr 18, 2014 | Garden
My windshield fogs up when trying to use heat
does it have a funky smell like antifreeze if it does (and i'm betting it does)you need to get your heater core replaced if not it could posible be the drain for the a/c system plugged up and water is trapped in the duck work
Nov 01, 2013 | 2001 Dodge Ram 1500 Truck 2WD
Craftsman Pressure Washer 580.752160 reagent/chemical not being dispensed when wand in low pressure position.
It is very common for the chemical injector valve on these to get gummed up from residual soap sitting in the valve. To clean it follow the chemical hose back to where it attaches to the pump. There will be a hex headed hose barb attached to it. Remove the barb from the pump. Underneath it you will find a spring and a ball bearing. Rinse the parts thoroughly and reassemble. You should also check the chemical strainer that goes into your chemical bucket. They can also become clogged and should periodically be cleaned.
Sincerely,
Aron Kerr
Landa Northwest, Inc.
www.landanw.com
Mar 07, 2011 | Craftsman 2700 Max Psi Pressure Washer 23...
Duet washer code SUD
Too much soap. Although there is a MAX fill line in the dispenser just a small amount of soap will get the job done. Just run an empty load with no soap (maybe two empty loads) that should get the extra soap out of the lines. Good luck.
Mar 05, 2011 | Washing Machines
Very little pressure
INFO:
Sound like its drawing air through the soap pick up tube.
RECOMENDATION:
Pench off soap pick up tube.
Hope this tip helps.
r/
David
Mar 10, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Power washer problem - water is spraying into my soap dispenser
this can happen if you use the wrong soap, you must use pressure washer cleaner, it does not foam.
Aug 08, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Karcher G 2600 ph
Dear johnny_river,
In general there are many causes why soap is not sucked. In a domestic and various other machines the soap is only sucked in low pressure. So one thing you can try is remove the nozzle or the complete lance from your gun. This will give a low pressure. If you attach a pipe directly to the machine soap inlet, and soap is not sucked, than the soap valve is "stuck closed" with soap. It is important that one must work with fresh water after using soap. This to flash the system from any soap left. So in a few words attach a pipe directly to the nipple at the machine and use low pressure. Important , you do not have to use soap to test....use fresh water. If this works( which it should)...than service the flow control tap or change it altogether.
Regards,
fulltech.
Apr 09, 2009 | Karcher 2500 PSI Pressure Washer
Whirlpool duet empties soap, bleach and fabbice softener as soon
soaps goes right in normal, bleach and fabric softer you can't go past max line line it will dispense."less soap plz"
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Long wash times
I've had this problem, particularly with towels - it's quite annoying & not energy or water efficient at all. According to the manual, the unit has a sensor that senses if there is too much soap & it will continue to wash until the soap is removed. I found that this happened frequently on the "cotton" cycles & max spin. I've tried to make sure I use less soap, but I also use the perm-a-press cycle & the spin 1 down from max. Hope this helps
Sep 07, 2007 | Bosch WFMC 3200 Front Load Washer
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
