Question about Dell Inspiron One 2305 Desktop Computer (AMD Athlon II X2 GB3GB) (DDPCEZ1P)
Dell inspiron one with black screen one blinking light
When i power up it says f2 or f12 then goes to black screeen with one blinking light
asingh1225
  • 122 Answers
SOURCE: Inspiron 530 Dell desktop
hello, how long have you waited for something to happen before restarted the system?
in any event, try resetting the BIOS. this is how: unplug the power from pc, wait 10 seconds then open up the side panel of the PC. First thing to do is to make sure you r not carrying any electrostatic charge (sound complicated? well its not) before you touch anything on motherboard in the computer just touch the metal part the casing and you are done.
now, locate the round ( coat button size) battery and gently take the battery out with paper clip, then look around and your will a jumper around that battery area. note the jumper position, if jumper is on first two pins, remove it and put it on last two.
Now plug the power back to PC (yes battery is still out)and press power switch (note PC may power on or may not) then 3 seconds later pull the power cord back out.
now, move the jumper back to its original position and put the battery back in, plug the power back and test computer.
hope fully this would do the trick, and if not, we might have to perform other tests like bad memory chip, BIOS update etc...
Post your results, good luck
regards
Amar Sondhi
Posted on Dec 04, 2009
PuterCare
  • 226 Answers
SOURCE: Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Posted on Jul 02, 2010
  • 44 Answers
SOURCE: On powerup of Dell Dimension 5100 running Windows
try this:
Power the PC off, open the case cover, remove/reseat the video card in the slot.
* Power the PC off
* Disconnect the PC power cord from the rear of the PC
* Remove the computer cover
* Move the RTCRST (Clear CMOS) jumper from pins 1/2 and place it on pins 2/3
* Press the PC power button
* Move the jumper back to pins 1/2
* Remove/reseat the video card in the slot
* Replace the power cord and cover and then power the PC on
Hope it helps
Posted on Nov 05, 2010
  • 117 Answers
SOURCE: Inspiron 530s freezing up. Goes to dell logo and
I am a Dell Certified System Expert and a Dell Advanced Resolution Expert Certified. For this issue, First I recommend to check all the keys on the keyboard, as it might be there are pressed key that can cause keyboard lock up and encounter your issue, also might be try to use a good known working keyboard. If the issue persist I highly recommend to contact Dell Support as this pertains to hardware issue, might need to reseat some hardware in the computer such as memory or hard drive.
Click this link to know the contact number of Dell Support:
http://support.dell.com/support/topics/global.aspx/support/dellcare/byphone_prod?c=us&l=en&s=gen
Hope this will help you.
Thanks for using Fixya.
Posted on Feb 27, 2011
lars_olsson6
  • 3400 Answers
SOURCE: Have Dell Inspiron 531S and am receiving boot error Diskette drive 0 seek failure.
if,windows try the installations disc.boot from it to repair windows.
Posted on Apr 01, 2013
Dell inspiron one 2305 black screeen with one flashing light
Dell Inspiron One 2305 (all-in-one) that will not power on. ... to reboot, I saw a faint white flashing light and heard a faint clicking noise. .... but I still have the black screen and my 2305 model remains essentially "dead".
Apr 18, 2014 | Dell Inspiron One 2305 Desktop Computer...
Dell Inspiron 6000 turns on but does nothing else.
From the description the hard drive has failed or windows has corrupt files. Unplug power supply from laptop and remove main battery, press and hold power for 2 minutes to remove residual voltage. when finished install battery and power supply now power up.
May 03, 2012 | Dell Inspiron 6000 Notebook
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
I HAVE A DELL INSPIRON 1200 NOTEBOOK AND WHEN I WENT TO RESTART IT. IT WON'T START UP AFTER THE DELL PAGE IT BRINGS UP A BLACK SCREEN WITH A BLINKING WHITE LINE. I HIT F12 FOR BOOT MENU, IT DIDN'T WORK I...
ok well if that is all it dose then you are going to have to restore the computer back to factory settings and then try it but befor you do that have you tryed starting up in safe mode that might work.
please rate my help to you.
thank you.
Apr 21, 2009 | Dell Inspiron 1200 Notebook
Trouble booting past the BIOS Screen
Remove the cmos battery and unplug comptuer for about 15 to 20 minutes. install battery working battery. make sure you didn't knock any cables loose
Check ram is seated
Check video and audio cards are seated properly
Then try booting pc.
Jan 22, 2009 | Dell Inspiron 6000 Notebook
Laptop won't boot up properly
Boot to recovery console using the XP CD, once there run CHKDSK /R
Jan 19, 2009 | Dell Inspiron 2200 Notebook
Will not go past startup screen
I think u need to updrage ur bios and RE-INSTALL UR WINDOWS
Oct 26, 2007 | Dell Inspiron B130 Notebook
Dell Inspiron One 2305 Desktop Computer (AMD Athlon II X2 GB3GB) (DDPCEZ1P) Logo
mukhtar21 shaikh
mukhtar21 shaikh
